Member # 17744
I have a welded rear and it is holding up just fine. Go to IH8MUD.com and go to tech links. There is a article and how to do it instructions. If welded correctly it will hold up fine.
[url]www.tlca.org[/url] [url]http://www.urbandictionary.com/define.php?term=Geiger[/url] |
Member # 10011
I welded up the rear of our mini truck a couple of years ago. It works great. You should be able to get 10 to 15 thousand miles out of a new set of tires also.
------------------------ aw ------------------------ |
#6 (permalink) | |
DEAR MADAM: THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE. YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY. PLEASE SELECT ANOTHER ITEM. THAT'S OUR FIRE EXTINGUISHER |
Member # 104239
Weld it all (except the pin in the center than you cannot get the clip on the axles)
1978 FJ40,383 stroker, 350,205,corp 14,dana 60 detroits 5.13's 42" Irocs, and a little tubing. 1974 FJ40-metal tech tubing, 4.88, Detroit rear, Arb front, 60 outers 1967 FJ45-Mater http://www.rubiconfriends.com/ http://www.laketahoehilos.com/ http://www.badrap.org |
Member # 14712
I always just filled in several teeth on the spiders and side gears...never welded tham togather or to the carrier. It makes them serviceable and also gives just a little bit of play between the rear axles so it turn a tiny bit better. JMO
Needed: Bed for 79 F150 (shortbed) |
