Member # 25058
go for it what would the problem be,besides being a landcruiser.....
9/74 FJ40 CORVETTE RED,V8/350,SM420,3SPD T/C,4 WHL DISC BRAKES, LONGFIELDS W/HUB GEARS,ARB FRONT/DETRIOT REAR SPRING OVER/OME SPRINGS,WARN 9500i WINCH/ AMSTEEL BLUE, (PSC) RAM ASSIST STEERING,HIGH STEER, 1TON TIE-ROD ENDS, PROJECT STARTED 1/1/01 SO FAR 1/1/11 =10 YEARS RICK SMITH |
Member # 52537
I need more info? the 68 axle could be a ball and claw and coarse spline and the 74 axle is fine spline and has a berf.
"If my calculations are correct, when this baby hits 88 mph you're going to see some serious shit!" |
Member # 24859
74 might be fine spline at third but may still have 6 spline drum birfs. The driveline bolt patterns may be different as well. The brake line fittings will be different and the steering end at bottom of drag link is different.
Hey rick , we drove around 50 togehter for Rubithon , thanks for waiting.
Mellonhead |
