Grinding sm420 clearance for L/C t-case - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-19-2006, 11:06 PM   #1 (permalink)
NORCALFJ40's Avatar
Member # 51625
Say a guy was grinding a sm420 with a 3speed l/c case for d-line clearance, and they were grinding and went all the way through, Could a guy weld a patch on the tranny housing? Is it cast steel or iron? oh yeah btw .. that brilliant guy that did this was me. Any help would be great. Flame on! Kodi
NORCALFJ40 is offline   Reply With Quote
Old 09-19-2006, 11:11 PM   #2 (permalink)
Moderator
RustyNailJustin's Avatar
Member # 8568
Yea, no biggie weld away. SM420s dont care about much
They are cast iron, but there wont be any force on the hole so just a hot weld will work fine.
2012 KOH Team CrossedUp, ADS, Artec, Mike Klensin and Justin Reece. 9TH Place.
2011 LCQ to KOH Team CrossedUp Mike Klensin and Justin Reece. We finished 40th
2010 KOH Team CrossedUp Mike Klensin and Justin Reece.
2009 KOH Team 435 Finished 35th.First Full Frame/Full Body To Finish KOH.
TLCA# 5305
RustyNailJustin is offline   Reply With Quote
Old 09-19-2006, 11:19 PM   #3 (permalink)
Member # 45843
they dont make J-B weld for nothing
[url]www.4x4him.com[/url]
weak-link is offline   Reply With Quote
Old 09-20-2006, 01:04 AM   #4 (permalink)
NORCALFJ40's Avatar
Member # 51625
Jb weld would work , but i want a more permanent fix. Can you weld to cast iron? Anything special needed to do this? Thanks
Old 09-20-2006, 07:20 AM   #5 (permalink)
Moderator
Member # 8568
Did you see my first post?
you are just patching a hole, depending on size you could just fill the hole with weld or weld a plate over it.
Welding to cast is no biggie like I said before, especally what you got going there, its not like there is force on what you are your weld there. Weld a plate and be done with it.
TLCA# 5305
Old 09-20-2006, 08:24 AM   #6 (permalink)
orangefj45's Avatar
Member # 6816
damn, you're the first guy i've ever heard of who actually grounf thru the housing. NOT!
clean the crap out of it with brake clean and then carb clean, preheat and burn baby burn.
Maybe you outta stick to legos!
orangefj45 is offline   Reply With Quote
Old 09-20-2006, 08:39 AM   #7 (permalink)
GloNDark's Avatar
Member # 2482
We fixed my buddies with JB weld 6 years ago, he wheels hard every weekend.
GET IT Dave!!
save me a spot bro......i'll miss you...
GloNDark is offline   Reply With Quote
Old 09-20-2006, 10:05 AM   #8 (permalink)
HANGTOWNCRUZR's Avatar
Member # 21
I just had my dad's repaired, driveline lost 3 bolts and knocked a hole in the case where it was clearanced. Tried JB Weld failed after a couple of days most not have been cleaned well enough. Took it to the local heavy equipt. repair guy and had it welded up works fine.
David Thomas,
Toys on the Rocks
TLCA #1723 KJ6CXR
RTF BOD
/|_,[___],
|---L(o--o)
()_)()_)--)_) 1965 FJ40
HANGTOWNCRUZR is offline   Reply With Quote
Old 09-20-2006, 10:40 AM   #9 (permalink)
cruzila's Avatar
Member # 6650
I had mine welded and it cracked around the weld, preheated and everything. I guess it cooled too fast. Still works, just drips slow.
Scott Johnston
Rubicon Trail Foundation
Founding Director and Past President 2010-2012
WIN a fully built Toyota pickup at Cantina 2013
Davez Off Road and Trail Gear are supporting Rubicon Trail Foundation
Racer Jack tm
Almar Mfg 530-333-2496
Find us on Facebook
cruzila is offline   Reply With Quote
Old 09-20-2006, 02:00 PM   #10 (permalink)
NORCALFJ40's Avatar
Member # 51625
Great. thanks for all the responces, It really helps. Gonna head out now and weld it up. Kodi
Old 09-20-2006, 02:01 PM   #11 (permalink)
NORCALFJ40's Avatar
Member # 51625
Old 09-20-2006, 02:01 PM   #12 (permalink)
NORCALFJ40's Avatar
Member # 51625
Old 09-20-2006, 05:45 PM   #13 (permalink)
texican's Avatar
Member # 12349
I would braze it, buy some fluxed rod and clean and go.
Butch
Conflict is inevitable.....
Combat is optional....
Tires are like boobs, they always look big until you have played with them for a while, then you just want a bigger set.
[URL=http://www.lslc.org/]Lone Star Land Cruisers[/URL]
[URL=http://www.khyi.com/]Support Texas Music[/URL]
texican is offline   Reply With Quote
