Member # 8273
203/205 doubler in an FJ40?
How feasible would it be to put a 203/205 doubler in an FJ40? My current drivetrain is a 350/SM465/TLC t-case. The Cruiser is sprung-over with the rear springs flipped to extend the wheelbase.
I will be installing a centered rear soon, and I had planned on using a 465/205 combo. I have a friend with a 465/203/205 set-up that he needs to sell, so I thought about it buying it. I think it would be too long for my current wheelbase though. Has anyone done the 465/203/205 in an FJ40 without pushing the rear axle way back? |
Here is jack rice's writup for that setup, says his wheel base was 105" at the time.
http://medusa.ih8mud.com/NP205/Doubler.html
FJ40 |
Member # 12349
The 465/205 stock is very very tight, done one, and ya have to have the fixed rear output to attempt it then.........so no it won't fit without moving the axle back, in fact we ended up going back on the rig I did and moved the axle back later..... it ate rear u joints.......another thing, it hangs low unless you body lift/cut to move it upwards
Conflict is inevitable..... Combat is optional.... Tires are like boobs, they always look big until you have played with them for a while, then you just want a bigger set. [URL=http://www.lslc.org/]Lone Star Land Cruisers[/URL] [URL=http://www.khyi.com/]Support Texas Music[/URL] |
Member # 12028
Like mentioned above- it's gonna be tight. I have one in my 45 (SM465,203,205), rear driveshaft is like 20" long. And that's with a longer wheelbase than a 40. I can send pictures if you want. Can't post them here- because I let my star membership lapse (on purpose). Luke
Cruiserless :( |
Member # 6816
yeah, that's gonna be really tight in a 40. it's run an atlas or stak instead. lighter, less spline lash and much longer rear driveline.
another option: keep the offset stock diff and put an orion in it!
Maybe you outta stick to legos! Last edited by orangefj45; 10-11-2006 at 08:53 AM. |
#6 (permalink) | |
What about running a single mini truck case with 4.7s?
[URL="http://www.pirate4x4.com/forum/showthread.php?t=521909&highlight=numtel"]105" FJ40[/URL] - [URL="http://www.trailbusters4x4.org/"]Trailbusters 4x4[/URL] - [URL="http://forum.ih8mud.com/forumdisplay.php?f=101"]Toyota Rocks TLCA Chapter[/URL] |
Member # 6816
whoops, fixed it. that's what happens when i get on the puter before 7am and the cup of joe has'nt kicked in yet.
![]() mini case in a set up cruiser = input shaft
Maybe you outta stick to legos! |
