Member # 4811
LockRite on it's Way Out??? Need Opinions
Ok. Moved the lock rite from the rear to the front a few months back and everything worked fine till I fragged a hub climbing a sand hill. Now I get an awful clunking noise (vrs. the ratcheting it used to make in the rear) sometimes not so bad, others - well. It's not that noticeable when the hubs are locked in and 4WD is engaged (power applied); but it's downright nasty when the hubs are locked and I'm in 2WD (no power). I know the lock rite should make some noise when no power is applied, but this is a little bit louder and clunks? Normal metallic greyish material on drainplug magnet - even ran a magnet on a stick thru the drain/fill holes and nothing unusual came out.
I'm almost totally deaf (literally) so I've had a few friends listen and they all agree it's coming from the diff. and it's not a birfield. Is the lock rite possibly slowly losing it's teeth thru wear, or is this something more sinister? Leaving for SC and NC Friday for 9 days of wheeling. Should I just run it till it quits working, or should I put the spiders back in know? Sorry so long Any input greatly appreciated.Bill C. in Florida |
Member # 7588
Sounds like you have broken at least one of the 'pins' that hold the couplers in alignment...
I would pull it out and check them before you have a little piece of the broken pin chewing up the R+P or the bearings... FYI you can make new "pins" out of a couple of correct size drill bits... just cut them out of the part that normally would be put in the chuck...
1948 Willys 1952 M37CDN Powag |
If needed the replacement springs and drive pins are available directly from PowerTrax. The sent me sets for both front and rear, No Charge when I called and asked about them. Got them surprisingly quick too, Thumbs up for their Customer Service!
Mike "SpaceGhost" Smythe R U gettin' it? UROC Team #180 running: BFG's 37" Krawlers, Gordon Beadlocks, HP60's, T-Max w/Blue Diamond Rope, Green Filters, Marlin's ToyBox, 3.8 Atlas II, and "I got the shaft from Jesse" but I couldn't have done without Badlands Machine Shop (765-762-2981)! |
Member # 4811
Thanks for the feedback. Never thought about the pins breaking. I'll pull everything and check - may have to wait until Saturday when I get to SC as I'm out of time with work and family...
Moderating Midget
Sounds EXACTLY like a broken pin. Been there, done that!
A guy in our club got a spring kit for free from 4WPH when he went in and asked to buy a set. If you have one in your area, you may want to try it. Don't go to Tellico without a front Locker!! Have fun!
Nolen Grogan 1997 FZJ-80 Land Cruiser, 37's 2010 RZR-4 www.cottonlandcruisers.com www.rockmidgetphotography.com USAF Veteran 1988-1998 GOD Bless America |
Member # 4811
Thanks Nolen,
Found an extra set of pins and 3 spring pairs while packing my trail spares last night I just spent the last 2 weeks finishing my roll cage (till 4am one night), the prior few months doing the SM420, last year I added ps and 16/35 Boggers, plus I had to skip GSMTR 2001, so the damm lock rite (front) better work Praying it's just the pins and no major damage... |
Member # 11442
Another possible worn component may be the side gear shims. When worn they cause similar symptoms.
Dann
'78 FJ40 - Wheeler (Chev-V6 4.3L, 2.5" Lift, 32s, EZLocker, 8274); '88 FJ62 - Beautiful (bone stock); '89 FJ62 - Wheeler (roll-over), 32s; |
Member # 4811
Hey Dan,
I'll drop off the d-ring and hooks at UPS tomorrow at noon, per your e-mail. At this point, the parts are free just reimburse shipping since it's taken so long. As to the thrust washers (shims), they were well within tolerances just a short while ago so I can't imagine they've worn that much. I've got a few spare sets of different sizes in my spare box just in case... |
Member # 11442
Thanks Bill but USPS not UPS (please please please - brokerage fees!!)
Dann
LockRite
I had a LockRite, It broke. The pins basically became shavings, chewing up the side gears as well. I had it for maybe 6 to 8 months. With the help of a friend, I even tried making a spool out of it. Like anything else it just depends on how hard you're thrashing it. Personally, I saved and paid the extra money for Detroits. Good luck.....
"If you're gonna do it, ATV!!" [URL=http://www.stormwaterprograms.com ]stormwaterprograms.com [/URL] |
