Member # 83276
71 disc brake conversion problems..help
i did a front disc brake conversion from a 81 fj60...and a rear conversion from jt outfitters..i bled the brake lines and i have rear brakes ok, but the front calipers dont put enough pressure on the pads to do any good...anyhelp would be appreciated.also installed new brake booster and master cylinder..
chuckee |
Member # 75104
just wondering if the rear locks up when you get on them, asking this because most disc swaps on the rear reqiure a proportioning valve to cut the pressure down on the back to equalize the pressure front and back. i have discs on the back and have one. i turned it down to when (im emty of all gear except usual stuff )the back just starts to lock up but doesnt. this could be the problem if you dont have one. also the rear brake port on the master cylinder has a residual valve in it that keeps pressure in the line for the drum brakes. if this is still in there it can cause the discs to drag. hope this helps.
Member # 83276
help
i dod not bench bleed the new master cylinder...matter of fact i didnt know you had to bleed the master cylinder...as, i have enough pressure on the rear disc's..its the front calipers that arnt working properly...the calipers do squeeze a little but not enough to stop the truck.......i will attempt to bleed the master cylinder, and hope it is the problem..any other ideas?
chuckee |
Member # 5999
Did you get the same year master cylinder? I put a 85 Supra on my 70 FJ40.
1/71 FJ40 350/700R4/NP203/TLC3SP 95 FZJ80 04 5.3L/4L60/FJ62 TCase, 6" Ironman, 37s on the way... |
Desert Rat
Member # 27432
Here's a thot. Don't try this for any distance away from home tho. Try plugging off the rear brakes and see how the front brakes by itself without the hydraulic resistance of the rear possibly affecting the piston travel inside the master.
MarksOffRoad.net Originally Posted by lc tpi ...if I have to buy them from Trail Gear I guess I dont need them. 65SWB45, 64LWB45, 68FJ40, 72VJ40, 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer tlca #1086 member: Trail Crew-L.A. TLCA, Elwood Chapter, TLCA |
