Member # 85289
newbee needs help!!!
hey there,i have a 78 LC,putting in sbc with sm465,but bought aa parts,motor mount and cross member,question is where to weld plate for L-braket 8" to 12" the book say's. Who done it and how it work out thank great place for info!!!
Desert Rat
Member # 27432
Whose instructions are you using? Chances are, they have a tech line, and can interpret their instructions for you.
I personally would only use their instructions on placement as a rule of thumb to guage your own measurements by, and would not weld the brackets in beforehand. I would assemble the powertrain first, use a couple of floorjacks and a cherry picker to move the assembly around IN THE FRAME .....WITH THE TUB on the frame to check YOUR INDIVIDUAL TRUCK's clearances to the steering box, exhaust manifolds, firewall and floorboards, etc. Much less likely to end up grinding the brackets back out when you discover that you 'overlooked' something! Best Mark A.
MarksOffRoad.net Originally Posted by lc tpi ...if I have to buy them from Trail Gear I guess I dont need them. 65SWB45, 64LWB45, 68FJ40, 72VJ40, 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer tlca #1086 member: Trail Crew-L.A. TLCA, Elwood Chapter, TLCA |
