Socket size of da Crank pulley bolt - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-16-2002, 10:23 PM   #1 (permalink)
Member # 3786
Send a message via AIM to rufio
Anyone know what that is??? I need to pull the crank pulley off cause my timing cover is pissing out oil! Damn...
Thanx,
Cruiser-B
WTB Fj40 a cheap double steering arm for my mini truck knuckles; going SOA soon!
rufio is offline   Reply With Quote
Old 05-17-2002, 07:50 AM   #2 (permalink)
fj40guy's Avatar
Member # 9576
1 & 13/16" sticks in my head. Seems pretty close to a 46mm.
Can someone SPOT ME on those numbers?
I found a "deep enough" 3/4" drive socket at SEARS. Catch is the damn "crank starter nose". Too shallow of a socket, and it doesn't clear. Too deep and it gets in the way of the frame. Just long enough, and you can slip it on and get to it with a LONG breaker bar.
Don't overlook that gasket BEHIND the timing case cover, and check for groves on you the crank pulley. Crank Pulley is easily repaired with a "Speedi Sleeve". Can't recall the part number off hand, but can be found at most bearing supply stores.
Tom
Too many projects, never enough time nor money.
fj40guy is offline   Reply With Quote
Old 05-17-2002, 09:27 AM   #3 (permalink)
Member # 3786
Thanx for the info and the heads up on the pulley seal. I'm pretty sure it's the gasket behind the timing chain cover though. Anyone else want to confirm that socket size, I'm going to sears to buy the stupid thing...
Cruiser-B
Old 05-17-2002, 10:02 AM   #4 (permalink)
GloNDark's Avatar
Member # 2482
Got a big ass pair of channel locks?? I got my crank off (hahaha) with a big pair of channel locks, some and 2 or 3 good full muscle pulls.
I am a cheap ass bastard and I hate buying a huge sock that I will use once.
GET IT Dave!!
save me a spot bro......i'll miss you...
GloNDark is offline   Reply With Quote
Old 05-17-2002, 10:07 AM   #5 (permalink)
Member # 6863
45mm or 46mm is what I used, cant recall for sure but a six point 46 should be great.
I have enough projects for the next decade. Need two?
cruiserbrett is offline   Reply With Quote
Old 05-17-2002, 11:21 AM   #6 (permalink)
Member # 3786
I've tried the channel lock method once...I just don't like the look of the bolt after I'm done...
Cruiser-B
Old 05-17-2002, 01:18 PM   #7 (permalink)
Member # 39
I had a similar leak from behind the timing chain cover and I did not want to mess with pulling off all of that stuff just to repair a gasket. Nor did I want to buy a one-time-use socket. So, I looked into my toolbox and pulled out my magic fix all sealant.....FPIG Black from Toyota and slathered it behind the timing chain cover without removing anything. It hasn't leaked a drop since.
Eric
Parts for Sale --> D44 shafts, 6 lug rims, air tank
Eric is offline   Reply With Quote
Old 05-18-2002, 12:31 PM   #8 (permalink)
Member # 11341
the craftsman 1 13/16 socket works fine
goldenarrow is offline   Reply With Quote
Old 05-18-2002, 04:01 PM   #9 (permalink)
Member # 3786
Thanks goldenarrow!
Cruiser-B
Old 05-18-2002, 06:04 PM   #10 (permalink)
Member # 11341
hey what collor is your cruiser i have probly seen it arround town
Old 05-19-2002, 12:54 AM   #11 (permalink)
Member # 3786
Yellow! But I'm going to sand it down soon and go back to the og. baby blue.
Old 05-19-2002, 07:56 PM   #12 (permalink)
Member # 11341
is it Yelllo like a lemon or bannana or is it a brown green yellow?
Old 05-19-2002, 11:17 PM   #13 (permalink)
Member # 3786
It's banana yellow.....
