101
Member # 114
I just put the 3speed idler gear and shaft in the 4speed t-case. There is 0.015" of slop between the case and brass spacer, is this acceptable?
Any other advise on this procedure is appreciated.
Dead chicks are hot. |
Member # 582
Per Factory Manual...
Limit is .0187" Standard is .0049 - .0187" Cory
FJ-40 HP 2F SM420, 4:88, Locked F&R, 98" WB, Sawsalled, Welded, dented, 36" SX's, 3spd gears in a 4 spd case, Newfields, Lots of other mods all done by Me... Towed to the trail with a 97 Crew cab 4X4 PSD (slightly improved) |
101
Member # 114
My factory manuel says the limit is 0.015". I am usally not this anal about conforming to factory specs but Ive heard that when doing this gear swap you need to add spacers to the idler gear because the 3speed case is narower then the 4speed case. When I put mine together I had only the 0.015" gap and I wasnt sure if this is the space that I am supposed to eliminate. Guess I should put away the feeler gauges open a beer and put the fawk'n thing together.
Thanks
Member # 582
When I did this swap,
I had to re-shim the idler to reduce this clearance. Cory I think I had .02XX" before the shim change.....
101
Member # 114
I went ahead and ordered the next thickness up spacer from toyota to reduce the clearance to .010". It was only $3 and Im not in a rush.
How did your conversion turn out? Any gear whine?
Member # 582
No gear whine yet....
Hope to actually put the system in the truck this weekend Cory
