FJ 60 snorkle template - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-30-2007, 10:19 PM   #1 (permalink)
Mike El Paso's Avatar
Member # 15059
I purchased a used snorkle for my FJ . Does anyone have a template I can use? I called ARB and the send me a homemade handdrawn three page something that does not make any sense. Especially put next to the fender. Thanks.
Mike El Paso TLCA 8009
1985 FJ 60
1977 FJ 40
[url]http://community.webshots.com/user/mep1811[/url]
Mike El Paso is offline   Reply With Quote
Old 05-31-2007, 05:30 AM   #2 (permalink)
45
rugburn's Avatar
Member # 45
Mike,
You have to drill 5 holes.
In addition, you must remove the washer bottle to gain access to the inner fender to tighten the fasteners.
Four for the studs to mount to the fender and one large hole for the duct to pass through.
Center to center on the four mounting points is pretty easy.
Drill those out to .375" dia.
The duct hole gets holesawed to just under 4".
Placement of the snorkel main body to the fender and up the A pillar is as simple as aligning to a good visual.
Tape off the fender and start measuring relative a known edge and go for it!
Be certain to deburr all sharp edges and paint to avoid rust.
Good Luck!
john
John Runberg
rugburn is offline   Reply With Quote
