Member # 49733
engine mounts
i am doing a 350/th350 swap in my 40 and i can't find anywhere to buy a decent 350 engine mount kit for a FJ40. has anyone found one? if so where?
same goes for the tranny mount
NEED ONE 16/38.5 X 16.5 Swamper TSL (20-30%)to complete set PM if you have one!?!?!?! Last edited by godyilla; 10-16-2007 at 05:58 PM. |
Member # 80999
I'll be intersted to see the replies on this one as well, since I'll be doing this soon too. I'm pretty sure AA has some but not sure of the others and most buildups I've been seeing have them custom fabbed to be similar to the chevy mounts. One thing I'm worried about is clearance for the Chevy power steering I just installed. The joint the box barely clears my existing motor mount and I wanted to move the new v8 foward.
Member # 18907
I used some universal mounts first but am tearing them out now.
Get some 3 hole plates that mount to the engine and them some poly bushings and weld some tube to it. This way is better because it puts less stress on the engine. Buhings http://ballisticfabrication.3dcartst...p_15-1197.html Plates http://www.aa-mfg.com/pdshop/shop/item.asp?itemid=169 OR http://www.aa-mfg.com/pdshop/shop/item.asp?itemid=642 |
Member # 49733
they look they have seen a bit of loven over the years
have they held up?
NEED ONE 16/38.5 X 16.5 Swamper TSL (20-30%)to complete set PM if you have one!?!?!?! |
Member # 49733
i found the same thing
http://www.tperformance.com/street_r...e_motor_mount/ or there is someone i saw who used this: http://www.tperformance.com/street_r..._motor_mounts/ but i don't know if the lower bar would get in the way
Member # 1525
ya know, asside from building something trick, advanced adapters mounts are tried and true. their new bushings are allot better than the ones from YEARS ago. keep your exhaust and fluids away from the pucks, and they will last a looooong time.
my vote, AA ![]() edit: AA= Advance Adapters
NCRD |
#8 (permalink) | |
Member # 1525
the first wont give you much for adjustment (side to side) I have seen the second ones used a couple times,.... I guess it depends how low your rig is if it will clear or not? hmmm I still say AA
NCRD |
Member # 49733
you mean AA's
http://www.aa-mfg.com/pdshop/shop/item.asp?itemid=642 fh187 which part# are to referring to that you would suggest ?
NEED ONE 16/38.5 X 16.5 Swamper TSL (20-30%)to complete set PM if you have one!?!?!?! Last edited by godyilla; 10-16-2007 at 06:29 PM. |
Member # 52099
You're really wasting your time asking my wife for directions! |
Member # 49733
are you running those? cause so far those are the ones i'm going to pick up
#13 (permalink) |
Member # 49733
ok cool i was going to say the ones from AAmfg kinda look cheap and kinda shity
NEED ONE 16/38.5 X 16.5 Swamper TSL (20-30%)to complete set PM if you have one!?!?!?! Last edited by godyilla; 10-16-2007 at 06:44 PM. |
#14 (permalink) | |
Member # 1525
![]() they have allot of really trick stuff, but most of it is light weight sprint car stuff
NCRD |
#15 (permalink) |
Member # 11458
Build your own
![]() 1/4" flat plate with the bolt pattern, .125 wall tubing, bushing mount, and tabs coming off the frame to the bushing mount.
Propane Powered 2f Metal Tech Production Manager [url=www.metaltechcage.com]Metal Tech Cage[/url] |
#16 (permalink) |
Discount!
These are what I've used on my last couple engine conversions.
http://www.tperformance.com/street_r...TOKEN=80351315
Jeff Fretwell 72 FJ40 67 FJ45 83 Toyota 4x4 LB |
#18 (permalink) |
Member # 24859
My vote is for the ole school AA units as well. Thats what I run and so far so good. The rear crossmember at the t-case is where you want to invest your time and thoughts.
Mellonhead |
#19 (permalink) |
Member # 10429
That isn't old school..
I have a horseshoe mount in the garage that mounts to the stock engine mounts.. It actually worked pretty dang good, and hell, it was on there for 7+ years.
Rich Q. FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/ORI's/42's |
#20 (permalink) |
Member # 5600
TTF Fab in LHC did mine
I got two things for sure in this world..My word and my balls..I'm not breaking them for anybody! Missing my 40 ...Shoe leather express jonesTLCA Member #13409 |
#22 (permalink) | |
Member # 474
Those things are OK if ya don't actually wheel the rig.... ![]() ![]() ![]() ![]() How do I know this?? 'Cos I don't actually wheel mine ![]() ![]()
Rock on with the RockDogs! |
#23 (permalink) | |
Member # 11458
I will use 1/4" plate at the motor, 2" x .125 DOM SRA for the tubing, an XJ bushing pressed into a hub shell and then scab plate the frame with tabs running off of that.
