FJ40 suspension lifts - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-24-2002, 01:20 AM   #1 (permalink)
Member # 8967
My friend is looking to buy a 4" susp. lift. He doesn't want to do a SOA right now.
What major things will he have to do to put say a 4" skyjacker lift on his FJ40?
I heard you have to do a shackle inversion or something. Also any other usefull information on lifting FJ40's is appreciated.
Thanks.
cexodusk is offline   Reply With Quote Quick reply to this message
Old 06-24-2002, 03:50 AM   #2 (permalink)
Moderating Midget
wngrog's Avatar
Member # 1154
Send a message via AIM to wngrog
For a basic FJ-40 SUA kit, a Skyjacker is as good as any.
He will be able to run 35's with no problems if he has cut out the rear fenders.
I have seen them installed with extended shackles and stock shackles and in my opinion, the stock shackles work best.
Extended brake lines should be the only modification you will need if you stick with stock shackles, otherwise, spring shims will be needed to correct the caster.
If you stick with 35 x 12.50's you will not need to limit uptravel as they will tuck into the fenderwell.
Here is my truck with 35 x 12.50 MTR's and a stock 4" lift and 1 1/2 over stock shackles.
Nolen Grogan
2016 4Runner TRD Pro
1998 Land Cruiser
1984 FJ-60
2013 RZR-XP4
USAF Veteran 1988-1998 GOD Bless America
wngrog is offline   Reply With Quote Quick reply to this message
Old 06-24-2002, 05:24 AM   #3 (permalink)
Member # 770
I have seen the skyjacker suspentions on a bunch of trucks and they hold up well. I have had a few friends that have had a problem with the rear shackle actually sitting on frame, and have had to relocate the mount a little, (as per www.ih8mud.com's tech site) but I think that wngrog may be right in that that can be avoided by leaving the factory shackle there...the probs that I have seen were with the con-ferr or extended shackles.
My oversized hat won't fit your humungous head.
rabid is offline   Reply With Quote Quick reply to this message
Old 06-24-2002, 08:08 AM   #4 (permalink)
texican's Avatar
Member # 12349
My daughter's truck, Lil Red has the 4" Skyjacker, run the lightest shocks you can buy for a smoother ride, we have KYB on her's.
The tires are 36 1250 15 TSL/SX's 8" wheels
Butch
Conflict is inevitable.....
Combat is optional....
Tires are like boobs, they always look big until you have played with them for a while, then you just want a bigger set.
texican is offline   Reply With Quote Quick reply to this message
Old 06-24-2002, 10:47 AM   #5 (permalink)
Member # 8967
So you can use the stock shackles in the stock location with the 4" lift and the only thing you have to really do is the brake lines?
Old 06-24-2002, 11:16 AM   #6 (permalink)
texican's Avatar
Member # 12349
Yes and you can do the Redneck Texan method on them, merely drop the hard lines off the frame a few inchs, use metal strap (exhaust type hangars) to lower 'em.
Butch
Old 06-24-2002, 02:33 PM   #7 (permalink)
peiserg's Avatar
Member # 9598
well don't forget someone mentioned the suspension shim you need, which is a little wedge goes between the axle and the spring... majorly easy to place with the axle dropped for the suspension anyways.. i had a driveline vibration which mostly went away with a 4 degree shim, but most people say 2 degrees is adequate... really what you need to do is drop the driveshaft and check your take off angle for the diff and the TF case and shim them as close as possible..you may not actually need a shim at all if you stick with stock shackles..
peiserg is offline   Reply With Quote Quick reply to this message
Old 06-24-2002, 09:51 PM   #8 (permalink)
Member # 10010
Aren't the shims meant to correct the caster angle ? I suppose if you install them to correct driveline angle, you worsen the caster angle by the same amount ? What are your feelings about this ?
BTW, I run 4" springs with no mods. The brake lines are stock length, but I admit my springs may be a little stiff, still.
I'll see what happens when I open the 3 clamps on each pack...
(redneck French engineering method
Bye,
'71MS75 '73DW15 '75BJ40 '75KE20 '79FJ55 '84BJ45 '88LN65 '90HDJ80 '92LN85 '95UCF20 '98CE110 '01UCF30
Stupid frnch jackasS is offline   Reply With Quote Quick reply to this message
Old 06-26-2002, 03:31 PM   #9 (permalink)
peiserg's Avatar
Member # 9598
shims in front are for castor. shims in the rear are for the problem (if you run into it) of the angles of the driveshaft differing where the DS goes into the diff vs. where it goes into the transfer case... for me, the TF angle was 88 degrees (pointed DOWN by 2 degrees) and the diff was at 96 (pointed 4 degrees UP), which was a 4 degree difference. I shimmed the diff down by 4 degrees, and now it points UP 92 degrees, which matches the 2 degrees down that the TF runs at..that cured most of the problem, but my shaft was running at 17 degrees, whichi was told is too close to the binding angle of my U-joint, so i am getting a CV shaft.
Old 06-26-2002, 06:36 PM   #10 (permalink)
Member # 12325
I have used (on many trucks) correction kit in the front (2.5") plus a 2.5" spring with a 4: spring in the rear. If you want more lift use 4" springs all around with the correction kit and extended shackles in the rear. SkyJackers are good springs too. Dont forget the drop pitman arm and the power steering and the V8!
lowrider is offline   Reply With Quote Quick reply to this message
Old 06-27-2002, 06:46 AM   #11 (permalink)
Member # 9851
Make sure that you use the brass castor shims or have some steel ones milled out , aluminum will crack/bend and fall out over time. If you cant find brass ones where your at, E-mail me and I will get you a set!
-Scott
"CRUZILA" 75 FJ40.....with some stuff done to it.
Cruzilla is offline   Reply With Quote Quick reply to this message
Old 06-27-2002, 07:25 AM   #12 (permalink)
Member # 554
I ran a 4" Skyjacker on my FJ40 for my first trip thru Rubithon. Worked great and flexxed awesome for a SUA lift. Only thing you need for the lift is to extend the brake lines or relocate the frame mount as Butch suggested.
Good luck and have fun.
Bruce in Redding, CA
'97 FJ80 - 40th Anniv Edition #4564
FJ4ZROX is offline   Reply With Quote Quick reply to this message
Old 06-27-2002, 07:40 AM   #13 (permalink)
Member # 260
Send a message via Yahoo to woody
I ran the softride suspension for a couple years. With 4" rear springs and all mounts in the stock location and running a stock length shackle, the spring eye could flex back enuf to hit the shackle mount on the frame. This was because the shackle was not long enuf. The length of the mount points PLUS the length of the shackle was LESS THAN the flattened/compressed eye-to-eye lengh of the spring itself. You want the length of the mount points PLUS the shackle to be slightly LONGER than the flattened eye-to-eye spring measurement.
You should run longer shackles to maximize travel and keep the spring eye off the frame. Relocating the mount for the shackle per my tech site means an even longer shackle should be used....but then you get much more travel since you force more arc from the springs at droop. Compression should remain unchanged.
Brian 'woody' Swearingen - IH8MUD Inc.
'74 FJ40, '95 HZJ75, '96 FZJ80, '03 2500 DMax, '09 RZR
woody is offline   Reply With Quote Quick reply to this message
Old 06-28-2002, 10:35 PM   #14 (permalink)
Metal-tech'in
helocat's Avatar
Member # 10420
-Scott
Agreed re: aluminum shims, to risky for the front end!
You can get steel shims from Bendz Springs in Portland OR. They run about $25 a set. Don't forget to also lengthen the spring pack bolt heads for the thickness of the shims. Bendz has these as well for cheep. I will track down a phone number if you wish, I am sure they will ship them. (They are a big Spring Mfgr.) Just PM me for it.
Mark
Made in the USA! ALL Active duty US Military get 10% off Metal-tech brand thank you for your service!
helocat is offline   Reply With Quote Quick reply to this message
Old 07-02-2002, 09:31 AM   #15 (permalink)
bernefj60's Avatar
Member # 10474
Butch
Butch,
how tall is your daughter's truck? I need to know how much lift and tires i can put on my 40 and still get it into my parking garage.
Thanks!
Rob
Rob Blumel
Alexandria, VA
87 rust free Sami project (in fewer pieces - for sale), 10 MBZ ML350, 07 Denali XL, 91 B250 (4x4 conversion?)
bernefj60 is offline   Reply With Quote Quick reply to this message
Old 07-02-2002, 11:32 AM   #16 (permalink)
Moderating Midget
wngrog's Avatar
Member # 1154
Originally posted by bernefj60
Butch,
Thanks!
Rob
http://www.pirate4x4.com/forum/showt...threadid=62626
Look through the measurements on this thread, you should find your setup there....
Nolen Grogan
1998 Land Cruiser
1984 FJ-60
2013 RZR-XP4
Old 07-02-2002, 06:05 PM   #17 (permalink)
texican's Avatar
Member # 12349
I don't have a clue on the height of her truck......she keeps it in a garage that comes with her condo in Irving, I'm sure it is a standard garage door opening......looks tight, but fits.
Butch
