Broken inner axels? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-27-2002, 12:11 AM   #1 (permalink)
Metal-tech'in
helocat's Avatar
Member # 10420
Broken inner axels?
Ok fill me in here: I keep reading about pepole braking inner axels on the front ends of their rigs. (Yes yes I know running "Longfeilds") Yikes! So what side tends to brake first?
If it is long side axles, I will have to kick myself for using them as welding table legs! (got a doz. or so stacked up from robbing Birfields out of mini's, so I put a few to work )
Mark
Metal Tech Made in the USA! ALL Active duty US Military get 10% off Metal-tech brand – thank you for your service!
helocat is offline   Reply With Quote
Old 06-27-2002, 02:35 AM   #2 (permalink)
Member # 922
Go ahead and use the mini-truck inners as table legs. They won't fit in your FJ40. They would fit in your FJ62, but I am assuming your '40 is the trail rig with the greater possibility of axle-breakage.
FeCamel is offline   Reply With Quote
Old 06-27-2002, 05:30 AM   #3 (permalink)
Eskimo's Avatar
Member # 10429
From a physics and "what-i've-seen" standpoint, the short sides tend to go first. The long side can help absorb more of the shock..
But, if you have the left tire wedged, turned, and in reverse, plan on the long side going pop before the short side.
And yeah, what Camel said, the long sides won't work on your 40.
Rich Q.
FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/ORI's/42's
Eskimo is offline   Reply With Quote
Old 06-27-2002, 10:30 PM   #4 (permalink)
Metal-tech'in
helocat's Avatar
Member # 10420
Thank's fellas. here's to you!
Must have been one of those one leged squirrels that live in the junk yard that told me they would fit a 40.
BTW they make outstanding table legs! Now what to do with all the short sides...
Mark
Old 06-27-2002, 10:50 PM   #5 (permalink)
Member # 922
Mark
Coffee table?
Old 06-27-2002, 10:57 PM   #6 (permalink)
texican's Avatar
Member # 12349
Click on the 4x4 tech link at the top, the go to the mini/4 runner
Butchforum and post them up for sale!
Conflict is inevitable.....
Combat is optional....
Tires are like boobs, they always look big until you have played with them for a while, then you just want a bigger set.
[URL=http://www.lslc.org/]Lone Star Land Cruisers[/URL]
[URL=http://www.khyi.com/]Support Texas Music[/URL]
texican is offline   Reply With Quote
Old 06-28-2002, 06:48 AM   #7 (permalink)
Member # 1599
Location: Indianapolis, IN. Home of the Brickyard 400, Indy 500, and USGP!
Send a message via Yahoo to SpaceGhost
Short side 2-1 in my case. That assumes equal load on both sides. If the short side is in the air, it won't break, haha! Longer axle absorbs more torsional stress/force before it gives up.
Bobby Long shared this with me yesterday. He cut (openings) in a housing up so he could see whats going on inside. I gathered he was trying to see how the steering stop adjustments effect the breakage of the inners. He witnessed the tweaking of the outer end of the axle if the stops were too far out. He suggested tightening them up some to prevent this.
Thats my plan, since I had been running them just tight enough to keep the tire lugs off the springs!
Mike "SpaceGhost" Smythe
R U gettin' it?
UROC Team #180 running:
BFG's 37" Krawlers, Gordon Beadlocks, HP60's, T-Max w/Blue Diamond Rope, Green Filters, Marlin's ToyBox, 3.8 Atlas II, and "I got the shaft from Jesse" but I couldn't have done without Badlands Machine Shop (765-762-2981)!
SpaceGhost is offline   Reply With Quote
Old 06-28-2002, 09:55 PM   #8 (permalink)
Metal-tech'in
helocat's Avatar
Member # 10420
Originally posted by FeCamel
Coffee table?
That's it! Yes I will weld up one you can leave your cold sitting on and not worry about the ring... heck just whip out the grider and resurface the bugger!
Old 06-29-2002, 03:44 AM   #9 (permalink)
Member # 922
I'd actually put a table made with axle parts in my living room. I might even wipe the grease off first.
