Moderhater
Member # 16980
front and rear landcruiser axles
SOLD SOLD SOLD SOLD SOLD SOLD
front axle: 72 housing, cut and turned knuckle gussets and supports fully rebuilt w/ new trunion bearings wheel bearings, shims, gaskets, felts 4.88 yukon gears w/ toyota flange lock right poly performance PIG 2.0 shafts longfields disc brakes w/ cross drilled and slotted rotors V6 4x4 4runner 4 piston calipers new pads 4x4 labs high steer 1/2 inch thick wall tie rods and drag link w/ 1ton tie rod ends. 1/2" extended wheel studs and lugs aisian hubs rear axle: sprung over, pinion turned 4.88 yukon gears welded rear cross drilled and slotted 1/2 ton chevy rotors 1/2 ton chevy calipers ruffstuff specialties disc brake conversion new bearings and seals 1/2" extended wheel studs and lugs BOTH AXLES HAVE NEVER BEEN RUN LOCATED in houston tx. shipping is your problem. will trade for a dana 60 front chevy (passenger drop) 1000 for the front axle 500 for the rear axle
Im your BMW huckleberry https://www.facebook.com/BMWdoctor can you do me a favor and like/share my page? If you like/share, you get free washes/discounts/other neat stuff for you car! gun facts that will blow your mind: http://www.gunfacts.info/pdfs/gun-fa...6_1_screen.pdf Last edited by Halogrinder; 02-27-2008 at 04:42 PM. |
Moderhater
Member # 16980
pics
Im your BMW huckleberry https://www.facebook.com/BMWdoctor can you do me a favor and like/share my page? If you like/share, you get free washes/discounts/other neat stuff for you car! gun facts that will blow your mind: http://www.gunfacts.info/pdfs/gun-fa...6_1_screen.pdf |
Moderhater
Member # 16980
so buy my junk, fukers
![]() i need a chevy dana 60!!!!
Moderhater
Member # 16980
i just got a quote to around 'frisco with yellow freight, was about 250 bucks, so think about it
Moderhater
Member # 16980
well im just giving you an example of how much shipping might be
