Member # 106678
lockers in a FJ60
I have a 1984 FJ60 that I would like to add front and rear lockers to. I am considering ARB but is it possible to transplant the e lockers from an 80 series? Does anyone know of a good place to purchase a rebuilt 3rd with lockers allready installed?
Thanks. Scott |
Member # 278
For the front, yes. It is possible to install the REAR 80 series elect locker. Two longer studs and maybe some grinding on the housing and then a long spline shaft for one side. I forget who sells them.
For the rear of your FJ60, no idea. I don't recall if 60 series had C clips or not. If it does have C clips, no
Member # 1858
Its been awhile.. guess its time for this thread again
![]() As pointed out above, the 80 Series Rear E-Locker WILL fit in the FRONT of the 60, with slight mods, longer studs and a long-spline inner axle shaft (Longfield or OEM). The rear, no, unless you have our install a full-float axle. ARB's start looking cheap when you add up the cost of the FF swap and custom shafts
Kurt Williams Cruiser Outfitters - YOUR CRUISER PARTS SOURCE! - ARB - OME - Engel - Helton - AdvAdapt ExpeditionUtah.com U4WDA - Member TLCA #10662 Wasatch Cruisers #028 Mountain Yoats Red Rock 4 Wheelers #789 Mojave Underground kurt@cruiseroutfitters.com |
Member # 15144
Here's a quick lil read that might help answer a few questions...
80 Series E-Lock Diffs Retrofit for FJ60 -Ferg- |
#6 (permalink) | |
Member # 14670
Not really sure what a fellow cruiser head meant when he claimed the toyota elocker to be weaker in a certain area than the ARB?
Ride it like you stole it. |
#7 (permalink) | |
Member # 92812
Long live the Aussie Locker!
1984 Toyota FJ60 Turbo Diesel Land Cruiser Last edited by Ducks; 02-07-2008 at 07:04 PM. |
Moderator
Member # 8568
I will tell you this from experience. ARB's are about the easiest way to have a reliable, selectable locker. I have had them is many different axles and have never once been let down or dissatisfied. From stocker DD Cruisers to Dana 60ed, getting it trail rigs ARB is my tried and true choice.
2012 KOH Team CrossedUp, ADS, Artec, Mike Klensin and Justin Reece. 9TH Place. 2011 LCQ to KOH Team CrossedUp Mike Klensin and Justin Reece. We finished 40th 2010 KOH Team CrossedUp Mike Klensin and Justin Reece. 2009 KOH Team 435 Finished 35th.First Full Frame/Full Body To Finish KOH. TLCA# 5305 |
