Member # 24876
2F to and auto??
Can it be done? i'd swear i have seen it done on here or 'Mud...
I've searched and searched and can't find anything. Did i imagine this?
[COLOR="Lime"]'85 Toyota ext cab. 4 cyl. 5.29s. Chromoly birfs. dual cases. hi-steer. OBA. front ARB. rear welded. cage.[/COLOR] |
Member # 22259
Downey offroad made a 1 off adapter to put that combo in there FJ45. They changed direction on the project and I think the one and only adapter was sold.
78 fj40 350,nv4500,35's 65 fj45 350,sm420,4wdb,35's Alcans 2007 Black FJ Cruiser 1966 M416 -Mike |
Member # 474
Yup, the FJ62 has an excellent auto tranny - way over-built for the vehicle. The only down-side is that it is an expensive tranny to fix/rebuild, and robs power. The FJ62's are total dogs; mating it to a 2F would make it worse.
Rock on with the RockDogs! |
#5 (permalink) | |
Member # 24876
he said it would be better off to buy a 62 and take the drivetrain from it.
#6 (permalink) | |
Up-n-over used to have an adapter plate as well. But IIRC they stopped building it.
DEAR MADAM: THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE. YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY. PLEASE SELECT ANOTHER ITEM. THAT'S OUR FIRE EXTINGUISHER |
Member # 24876
Stupid.. If i could just get my wife to drive a 5 spd. i'd be fine
I found a sweet deal on a FJ62 with an auto we'll see how it turns out. I guess it would be less than ideal anyway, a 2F has tons of grunt down low where a auto it least efficient. it seems like it would be kinda worthless
Member # 474
Interesting - I was under the (mis) impression that the F blocks were all the same
![]() I would not bother with the Toyota drivetrain (especially out of an FJ62 - (speaking as a non-purist ) just go with a Chevy motor/tranny and adapt to a Toy Tcase - cheaper, more power, better economy, etc. etc.
Discount!
Maybe you could use a Ford c-6 (removable bell housing) and custom fab an adapter. But would'nt it be much easier to just swap a GM drivetrain in... That's why everyone else does it. Simple + most cost effective.
Jeff Fretwell 72 FJ40 67 FJ45 83 Toyota 4x4 LB |
#12 (permalink) |
Member # 12349
The FJ62 trans will bolt up to a 2F with the cast adapter that they use to bolt it onto a 3FE, and the trans is not computer controlled.....
Butch
Conflict is inevitable..... Combat is optional.... Tires are like boobs, they always look big until you have played with them for a while, then you just want a bigger set. [URL=http://www.lslc.org/]Lone Star Land Cruisers[/URL] [URL=http://www.khyi.com/]Support Texas Music[/URL] |
#13 (permalink) | |
IIRC butch is right
#15 (permalink) | |
#16 (permalink) |
Member # 12349
The reason I know is that I have all the stuff to couple them together here and a good used A440/t case....thought it would make a cool buggy powerplant.......If I live long enough to complete all the bitchin' projects my mind dreams up it will be a miracle.
#17 (permalink) | |
Member # 34369
If you do like I did and quit going to work then you might have a chance... ![]() Chris
[COLOR="Magenta"][QUOTE=Earl_of_Burl] Q: What is Hell? A: A place that is without God. Q: How do you find God to avoid Hell? A: Through his son, Jesus Christ. Q: What does this mean to me? A: If you are living your life without accepting Jesus Christ as your personal savior, you are on the road to Hell.[/QUOTE][/COLOR] |
#19 (permalink) | |
Member # 14712
Needed: Bed for 79 F150 (shortbed) |
#20 (permalink) |
Member # 50672
What are you wanting to put it in?? It is a long ass transmission for a 40. I was putting a drivetrain from a 62 in my 40 but it left the rear shaft about 8" long. The whole combo is not going to happen for me, its now in the shed. Now I'm going with a 4.3 4l60e and 3speed t-case with downeys adapter. Should have around 18" of rear d-shaft.
#23 (permalink) | |
Desert Rat
Member # 27432
That would make #6 for the WT then, wouldn't it?
MarksOffRoad.net Originally Posted by lc tpi ...if I have to buy them from Trail Gear I guess I dont need them. 65SWB45, 64LWB45, 68FJ40, 72VJ40, 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer tlca #1086 member: Trail Crew-L.A. TLCA, Elwood Chapter, TLCA |
#24 (permalink) |
Member # 24876
I wanted to put it in a '55.. but since i found a killer deal on a '62, i wont be buying the '55
#25 (permalink) | |||
Member # 1858
you would either have to drill/tap your crank for the bigger bolts or use some sort of spacer inside the holes of the flexplate. This might not be an issue on every LC auto flex-plate, but I know when going from a H55F to a 3FE you have to drill out the holes on the flywheel for the bigger 3FE bolts. On the two setups I've dealt with, we had to just that... so one could assume you would have to do the opposite while going the opposite direction (F/2F to A440)Quote:
I think the issue I was referring to was rigging a kickdown cable to your carb, not impossible but something to do none-the-less. Quote:
Kurt Williams Cruiser Outfitters - YOUR CRUISER PARTS SOURCE! - ARB - OME - Engel - Helton - AdvAdapt ExpeditionUtah.com U4WDA - Member TLCA #10662 Wasatch Cruisers #028 Mountain Yoats Red Rock 4 Wheelers #789 Mojave Underground kurt@cruiseroutfitters.com |
