FJ60 Build - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-29-2008, 07:37 PM   #51 (permalink)
brokenparts's Avatar
Member # 71152
Send a message via AIM to brokenparts Send a message via MSN to brokenparts Send a message via Yahoo to brokenparts
my NWF shipment came... 1 ton/th400/203/205 junk is BEEFY. I LOVE IT!
I am offended by reality all the time.
My 1 ton fj60 build:
/forum/toyota-land-cruiser/708363-fj60-build.html
brokenparts is offline   Reply With Quote
Old 09-30-2008, 12:15 PM   #52 (permalink)
Member # 912
$$$$ those tripple shifters are nice, but $$$. i almost went that way but decided to build my own....
Nice pile of parts, why did you decide on the NWF adapter?
sixty is offline   Reply With Quote
Old 09-30-2008, 02:12 PM   #53 (permalink)
Member # 71152
I am bound and determined to get this thing back on the road in a hurry so I'm trying to eliminate some of the tedious stuff... not that the shifters are too difficult to build but I really like the NWF trip sticks anyway so I went for it. Same thing with some of the brackets I'm going to use building the front link setup. I'll be putting in a call to Ballastic fab here pretty quick when I figure out the parts I need.
I went with the NWF for pretty much the same reason you did... clockablilty. There is a lot of question marks on where everything is going to end up so having the option of being able to have some of my set up "flexible" seemed like a good idea.
http://www.pirate4x4.com/forum/showthread.php?t=708363
Old 10-03-2008, 09:52 PM   #54 (permalink)
Member # 71152
so, I'm playin with the 4 link calc and I'm getting most of it but the COG is pretty hard to determine. I've read that a good general read on it would be the top bolt of the tranny?
Old 10-06-2008, 07:40 PM   #55 (permalink)
Member # 71152
my 42s showed up.
some pics...
gettin closer to getting the th400 done. I really could have been done but the front band showed some wear so I ordered a new one. Should be here in a day or two... then I can move onto getting the 203/205 done.
trim lines:
Bumper looks like it'll be for sale soon:
Front shot:
started taking the H1's apart:
Old 10-06-2008, 08:14 PM   #56 (permalink)
Member # 71152
one pitbull mounted...
Old 10-07-2008, 09:39 PM   #57 (permalink)
Member # 71152
major frustration tonight... I couldnt seem to get the wheels to "seal" up. Anyone got any tips?
Old 10-08-2008, 06:00 AM   #58 (permalink)
Trail Tampoon
rajincajingt's Avatar
Member # 27333
i use a little wheel bearing grease on the surface the seal rides. after that, i slap it all together and then tighten the bolts down in the star pattern.
mine normally seal up well and are pretty stupid-proof. sorry i can't be more help
83CJ7-350 on pane-465-205-chromo 60&70-h1s-42" SX2s-linked F&R - ORIs
90YJ - stock-ish
1970 Commando under the knife:
/forum/jeep-hardcore-tech/900628-urban-commando-project.html
rajincajingt is offline   Reply With Quote
Old 10-08-2008, 07:42 AM   #59 (permalink)
Member # 71152
damn... I cant even get stupid proof right.
Old 10-08-2008, 07:48 AM   #60 (permalink)
Trail Tampoon
Member # 27333
alot of people have had problems with the seals, mine just seem to work well...
90YJ - stock-ish
http://www.pirate4x4.com/forum/showthread.php?t=900628
Old 10-08-2008, 08:51 AM   #61 (permalink)
jesster's Avatar
Member # 49468
Thicker beaded tires can sometimes cause problems in H1s.
jesster is offline   Reply With Quote
Old 10-08-2008, 08:58 AM   #62 (permalink)
Trail Tampoon
Member # 27333
this too, i did not notice you were re-using the trimmed mag run flats.
im using the stazworks HDPE inserts
sorry
90YJ - stock-ish
Old 10-08-2008, 09:38 AM   #63 (permalink)
Member # 71152
I'll try again tonight... I'll be a little more patient and tighten them down a bit more...
next subject is the spring rates for coilovers:
I need to pull the trigger on the coilovers. Here's what I am figure. 1200 total weight on each of the two front corners (taken from "how much does your 60 weigh thread') minus the tire/wheel (175ish) minus half of the d60 (250ish) which leaves me with about 800 pounds of sprung weight on the corners... here's what I put into the FOA calculator:
Does 250/400 seem reasonable for my spring rates with medium valving?
Old 10-08-2008, 08:23 PM   #64 (permalink)
Member # 71152
now I'm no genius but this may have been the problem...
Looks like it got pinched. I stole one from one of the other wheels and it works great... Patience and lithium grease is the key!!!
Old 10-09-2008, 01:52 PM   #65 (permalink)
Trail Tampoon
Member # 27333
BAM, that will normally do it.
90YJ - stock-ish
Old 10-11-2008, 09:54 PM   #66 (permalink)
Member # 71152
Sat. progress:
Got the th-400 buttoned up... lining up the clutches to get the different clutch assemblies to seat properly was probably the most difficult thing of the whole process:
Got the shift kit installed. I went for the "street" shift which is supposed to be the most firm. I hope that it doesnt end up breaking my teeth when it shifts:
Primed:
Painted:
My little girl approves...
I got two more wheels/tires together too. Still waiting on the new o-ring for the 4th wheel.
I'm hoping to start digging into the 203/205 tomorrow.
Old 10-12-2008, 04:56 PM   #67 (permalink)
Member # 71152
Carnage:
Old 10-13-2008, 10:57 AM   #68 (permalink)
Member # 71152
little more progress with swapping some of the 205 stuff.
Case:
Tear down:
front output out:
old vs new 32 spline:
Old 10-13-2008, 10:57 AM   #69 (permalink)
Member # 71152
Rear tailshaft assembly
this needed to come out
off:
I remembered to account for the fatty needle bearings (15)
apart:
Removed the shift rail pins:
then frustration set in... I could not get the shift rail out. Before I knew it and had the BFH out and started pounding on it. Still nothing. I decided to take a break and quit pounding on it and see if there was a better solution to getting it out.
Old 10-13-2008, 08:09 PM   #70 (permalink)
Member # 71152
3.0 Ballistic joints are big... that's a pounder by the way:
Old 10-13-2008, 08:40 PM   #71 (permalink)
Member # 71152
since I got the new shift rails coming... I figured why do it the hard way and cut the rail out.
Old 10-14-2008, 05:48 AM   #72 (permalink)
Trail Tampoon
Member # 27333
they are HUGE and very well build, ive been beating mine for over 9 months now and they are holding up GREAT!
90YJ - stock-ish
Old 10-14-2008, 09:39 AM   #73 (permalink)
Member # 71152
FOA coilovers ordered:
Old 10-14-2008, 09:34 PM   #74 (permalink)
Member # 71152
I'm pretty set on a three link... anyone got of opinions on my 3link calculator? The numbers are pretty close to actual distances/possibilities...
Old 10-15-2008, 08:23 AM   #75 (permalink)
Member # 71152
I'd even appreciate public humiliation and ridicule!
