69 Pig venting - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-11-2008, 09:27 PM   #1 (permalink)
aka dtrain
WebWhlR's Avatar
Member # 74680
69 Pig venting
Searched around a bit for pics, diagrams, etc. Didnt find what I was after
I have a 350 conversion done by 2 POs ago with the stock tank in my '69 piggy.
Was giving the pig some air. Running really well and this guy pulls up to me saying I have gas dumping out the right side. I have obviosly vented the wrong tube. Previously, the tube was capped and I guess it was a return of some sort? Best I can figure... when I would let off the pedal, gas would come rushing out of this tube (walked my street from when I came home and the gas trail was consistent with my assumption)
Which of the tubes are for venting? The passenger side of the tank has two tubes: one delivers the gas to the motor and the other appears it was for a return line of some sort (this is the one I had vented)? The driver side has 3 "nipples": the center one is capped and the two on either side of the center one are connected/lopped together. Is the center one on the passenger side supposed to be the vent? Getting a roll-over valve from summit when I track down the right f'n tube
Thanks!!!
Damon
'96 FZJ80 - DD, wheeler
Watch out for the coffee h0s
WebWhlR is offline   Reply With Quote
Old 10-12-2008, 07:58 PM   #2 (permalink)
aka dtrain
WebWhlR's Avatar
Member # 74680
I know one of you out there knows the answer
bump
Damon
Old 10-13-2008, 07:37 AM   #3 (permalink)
one 55 guy's Avatar
Member # 78189
let me look
aww I played this game also , took me a year to get it right <, I" ll get back to ya
BANNED FOREVER ! DIESEL TRUCK RESOURCE PENITENTIARY
Crawler,Sand dune, (85) 4 runner, v8,465,203,205,tons,H1s,40"PBR"s,63s.B52s,locked up, WB113",propane :smokin:
(SOLD ):crybaby2: 1970 fj55,350,465,203,205,529s,40ltb"s,17, locked d60s-gas/propane --(SOLD) :crybaby2: 1966 45lv ,
one 55 guy is offline   Reply With Quote
Old 10-13-2008, 10:19 AM   #4 (permalink)
aka dtrain
WebWhlR's Avatar
Member # 74680
Thanks Mike
Here was my new plan: Going to vent this to the intake. There will be a few "swirls" in the hose before it gets there and my it should take care of any gas smell/fumes. Any advice?
I've heard of other people doing this so I dont think its dangerouse. Am I wrong? Just want to be safe and do it right.
Damon
Old 10-13-2008, 05:56 PM   #5 (permalink)
one 55 guy's Avatar
Member # 78189
OOPPS ! I looked at mine < all my nipples are pluged ! I used the one that is used for overflow (the 1 inch nipple ) when you fill up at the pump , I gave up on all the others , I had the same problem you had ,when the gas tank got hot the gas would expand , i.e. gas would come out the hose !
you gotta find someone with a empty tank , to research this for ya ? ....... my 2 cents
Old 10-13-2008, 07:31 PM   #6 (permalink)
Pooze's Avatar
Member # 104239
Size:  9.5 KB does this help at all
1978 FJ40,383 stroker, 350,205,corp 14,dana 60 detroits 5.13's 42" Irocs, and a little tubing.
1974 FJ40-metal tech tubing, 4.88, Detroit rear, Arb front, 60 outers
1967 FJ45-Mater
http://www.rubiconfriends.com/
http://www.laketahoehilos.com/
http://www.badrap.org
Pooze is offline   Reply With Quote
Old 10-13-2008, 08:45 PM   #7 (permalink)
aka dtrain
WebWhlR's Avatar
Member # 74680
Thanks for looking Mike. My guess is that is why they are all plugged. Maybe I can "splice" in a breather to hose you are describing.
I was also playing around with the idea of a ball valve welded into the center of the gas cap (leveled out of course). Not really sure what that will take and may not even be possible.
Originally Posted by Pooze View Post
Attachment 396599
Attachment 396600 does this help at all
Pooze - Thanks for the diagram. I saw that but the issue I am having is that it doesnt really "explain" what each port does (if that makes sense).
Edit: Almost forgot... it was good meet'n you a swap meet. I had the two little girls and was chatt'n with you about the seatbelts
Damon
Old 10-14-2008, 05:36 AM   #8 (permalink)
Member # 25339
The four hoses from the tank to part #45 vent the four corners of the tank, #15 is supply and return, the hose from the front to #45 comes from the charcoal canister (I think) and then you're left with the fill and overflow.
'82 Toyota LandCruiser BJ60 3B AXT turbo, factory A/C, factory PTO winch, rear Aussie locker. From Vancouver, B.C., Canada!
'67 Toyota LandCruiser FJ45LV being restored by my shop class c/w 3B and turbo, H41 low range 4 speed, as well as minitruck disc upgrade!
cruiser guy is offline   Reply With Quote
Old 10-15-2008, 06:14 PM   #9 (permalink)
one 55 guy's Avatar
Member # 78189
roll over
Damon , your 55 looks great nice rock crawler , I would like to give you a heads up , you should make a way to plug that line ,one that you can get to fast !! the first time you roll that pig your going to leak GAS !!!.........I have a cap that I put on a 1/4 pipe to plug mine ,also it vents behind my front seat, I can get to it quickly !!! 55 guy out !
Old 10-15-2008, 08:46 PM   #10 (permalink)
aka dtrain
WebWhlR's Avatar
Member # 74680
Thanks Mike
Thanks for the advice. I was thinking to go with a ball valve on the end of the breather to cure that problem. Although an actual inline cut-off valve may be idea as well.
Damon
