fill plug relocation - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-07-2002, 05:57 PM   #1 (permalink)
Member # 5967
I did a search on this already, so here goes. On all the SOA write ups I have not seen anyone mention relocating the fill plugs for the diff....shouldn't this be done??
Buford '78 FJ40,4.88s, loc-rites,39.50 TSLs, front & rear winches custom 6 point cage,V8 sm465, toy box, splitcase on the way.
"If at first you don't succeed......weld it up and try again"
[URL=www.tlcconcepts.com]www.tlcconcepts.com[/URL]
buford is offline   Reply With Quote
Old 08-07-2002, 06:26 PM   #2 (permalink)
Member # 270
Why would you want or need to relocate the fill plug? If the pumpkin/pinion is rotated up just park up or down hill to level it out while filling up.
or maybe there's more to it than that and I'm just
KeithF is offline   Reply With Quote
Old 08-07-2002, 07:03 PM   #3 (permalink)
Member # 6588
medusa
his webpage
green forty series
fill plug relocation is mentioned
[COLOR=yellow]Bj on Roids 1970FJ45, Quad Cam V8, Auto, Broken T-case, H-TEC (traction control and cutting brakes) 42 TSLs.[/COLOR]
[COLOR=green][URL=http://www.outerlimits4x4.com]Aussie Wheelers Bulletin Board[/URL] [/COLOR]
BJ On Roids is offline   Reply With Quote
Old 08-08-2002, 07:51 AM   #4 (permalink)
Member # 6863
Most SOA setups with rotated axle housings have them rotated quite a bit, mine will be about 30 degrees, and that is a LOT of difference in oil volume. It would take a pretty steep hill or a really tall hilift to fill it, and then filling in an emergency would be a short fill, not something I want with the pinion bearing that high up in relation to its original 'nearly at oil level' location.
All you need is a pair of hole saws and a piece of metal to plug the hole where the plug used to be...
I have enough projects for the next decade. Need two?
cruiserbrett is offline   Reply With Quote
Old 08-08-2002, 08:20 AM   #5 (permalink)
Member # 270
I live in SF so 30 degrees ain't nothing around here
Old 08-08-2002, 08:35 AM   #6 (permalink)
Old Rock Doc
Medusa's Avatar
Member # 915
The way I did my FJ40 axle fill plugs was to cut a rectangular section about 1.5" wide and 3" long out of the diff cover. The original fill plug was located at the bottom of this rectangle. When removed, simply rotate the piece 180* so that the fill plug is not at the top of the hole and weld it back in. Grind off the welds, sand and paint and you can't tell that the plug was even moved
Got Rice?
Medusa is offline   Reply With Quote
Old 08-08-2002, 03:24 PM   #7 (permalink)
Member # 1159
I had a bent housing I was swapping out when I did the pinion rotation so I cut out the fill hole and welded it into my new housing further up the face. I also cut out the entire bottom half of the face and welded that to my new front diff for some armor from rocks that kept on denting my old housing.
For my rearend (dana 60) I welded a nut to the inside of the cover and used a short bolt for a plug (with the correct kind of washer).
I have 4 fill plugs on my 2 diffs
Tankota is offline   Reply With Quote
Old 08-08-2002, 08:10 PM   #8 (permalink)
Moderating Midget
wngrog's Avatar
Member # 1154
Send a message via AIM to wngrog
My diff is at a pretty wicked angle and I just jack the rear up with floorjack under the rear and over fill it.
Not had a problem yet.
Nolen Grogan
1997 FZJ-80 Land Cruiser, 37's
2010 RZR-4
www.cottonlandcruisers.com
www.rockmidgetphotography.com
USAF Veteran 1988-1998 GOD Bless America
wngrog is offline   Reply With Quote
Old 08-12-2002, 12:39 PM   #9 (permalink)
Member # 1357
Hey Nolen, as often as you turn your rig on its side now, you could just take advantage of it and give the old diff a fill up before laying her back over.
77 FJ40, 5.7L vortec, soa, shaved 14 bolt rear, stock front housing loaded with some good stuff, and a lot of f***ing dents and rust.
rustyb is offline   Reply With Quote
Old 08-12-2002, 02:50 PM   #10 (permalink)
Moderating Midget
wngrog's Avatar
Member # 1154
Crawl back under your rock and don't come back out until you can wheel/weld again
Nolen Grogan
2010 RZR-4
Old 08-12-2002, 03:38 PM   #11 (permalink)
Member # 3774
The fill plugs are just 1/2" NPT (dana 60 ones, anyway). You can weld an extra layer of metal somwhere on the cover, then drill and tap it for the new plug.
GhettoRig is offline   Reply With Quote
