Member # 6142
Steering Issues
My steering is real lose after completing the SOA and shackle reversal. Before it was fine, if you hit bumps or anything it would just go over them. Now it has 37's and when it hits bumps it jumps one way or another, and uneven spots in the road are the worst. It will hit a spot and fly over into the grooves. Like I said, before it was perfectly fine. Any suggestions? Im tired of scaring the hell out of myself and the people passing me.
Sean
77 FJ-40 with stuff A college student slowely building his 40 "Keep your body like you'll live forever, and keep your soul like you'll die tomorrow" |
Member # 10067
hows your castor? I drove 50 miles once with negative castor, way back when I was sprung under and thought longer shackles were cool....it was SCARY.
But, it taught me all about steering geometry, and now I have +5 degrees positive castor and I love it. drives straight as an arrow. if you werent spring over, I'd be wondering about your draglink angle and bumpsteer, but you probably have a double steering arm, (right?) so that kinda cancels out the bumpsteer. anyways, that's my guess. cheers, ryan
79 BJ40/42, 87 BJ70, 71 fj40 Parts mound. Last edited by seapotato; 08-15-2002 at 05:19 PM. |
Member # 8975
Check out the tread Titled something like my "Cruiser won't follow" its just a couple pages back, it gose over caster angles and I would be willing to bet money thats your problem try installing shims under the spring pad to see if that helps.
72 TLC w/ Pontiac 455, SM420, Orion T-case, OBA, ARB's, SOA, PS, P disc B's, 36x14.5 TSL's, Painless wiring, GM column, Autometer gauges, Power and heated bucket seats, CD Stereo 4 speakerw/ sub woofer, Union Pacific Train Horn |
#5 (permalink) | |
Moderating Midget
Nolen Grogan 1997 FZJ-80 Land Cruiser, 37's 2010 RZR-4 www.cottonlandcruisers.com www.rockmidgetphotography.com USAF Veteran 1988-1998 GOD Bless America |
Member # 6142
Im caster angle is +3 or +5 one of those. I cant remember its been about 2 monthss since its been done and I havent driven it very much. All the bolts are tight and I do have a double steering arm. So whatever that makes the angle of the draglink then thats it cause I dont know. Thanks for all the info fellas.
Sean
