How to get drive shaft bolt off... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-14-2009, 06:11 PM   #1 (permalink)
Member # 129664
Hi all, i'm replacing the stock parking brake drum on my FJ55 with a disc conversion i got from man a fre (http://www.man-a-fre.com/parts_acces...akeconvkit.htm). i got my drive shaft off, but there's a bolt in the center of the parking brake drum that is stuck pretty tight (see attached photo). Is there a trick to getting it off? i've tried an impact wrench, wacking a really long wrench with a rubber mallet, and even torching it to no avail.
any suggestions?
bryancostanich is offline   Reply With Quote
Old 02-14-2009, 07:36 PM   #2 (permalink)
woooody's Avatar
Member # 1200
Doesn't look like you "un-staked" the nut. There are two depressionsin the ring of the nut that matched up with the grown in the out put shaft. You needed to pry those back out prior to removing the nut
Ross Woody * Secretary - TLCA #7704 * President - Pacific Mountain Cruisers
72 FJ40 * 07 TRD FJC
woooody is offline   Reply With Quote
Old 02-14-2009, 10:21 PM   #3 (permalink)
Member # 1282
Impact wrench also works.
ranger is offline   Reply With Quote
Old 02-14-2009, 10:38 PM   #4 (permalink)
Bacon addict
smurfblue40's Avatar
Member # 32029
X2 what woooody said...
It should only take a couple good whacks of the mallet to breaker-bar to get it loose.
*just in case you haven't done this already (guess how I learned ) chock the front wheels, put trans in gear, t-case in 4 LO, lock hubs... have at it
Rick
'72 FJ40 -Lightly modified
'91 FJ80 -Work in progress
TLCA #14103
smurfblue40 is offline   Reply With Quote
Old 02-14-2009, 10:59 PM   #5 (permalink)
Member # 129664
i tried a 1/2 air driven impact wrench. it didn't touch it.
i didn't unstake it, it was already the way it was when i opened up the transfer case, the stakes where just mush. i pulled them off. sucker still wouldn't budge.
Old 02-15-2009, 05:32 AM   #6 (permalink)
Member # 1926
What brand/model of impact are you using? My IR has 650 ft/lbs in reverse and will remove it without any issues.
'69 FJ40 with very few stock parts.
2000 Cummins with some goodies to make it smoke.....
Trail Gear's Bad Ethics=Bad Business.
fj40charles is offline   Reply With Quote
Old 02-15-2009, 10:21 AM   #7 (permalink)
Discount!
dog walker's Avatar
Member # 156
Send a message via ICQ to dog walker
I just removed mine last week, took a very large 1/2" ratchet (2 footer) plus a 1' breaker bar to loosen it. You know there is a seal right behind it right? You probably ruined it with the heat. Better get a new one.
Jeff Fretwell
72 FJ40
67 FJ45
83 Toyota 4x4 LB
dog walker is offline   Reply With Quote
Old 02-15-2009, 04:18 PM   #8 (permalink)
Member # 129664
yeah, a 24" breaker bar did the trick.
i'm replacing the speedo housing unit with a double-seal one from this guy: http://www.mudrak.com/products.html
Old 02-16-2009, 07:14 AM   #9 (permalink)
Member # 12028
Quoted because I think calling Mudrak- "this guy" is funny.
Cruiserless :(
LukeZero is offline   Reply With Quote
Old 02-16-2009, 08:34 AM   #10 (permalink)
Moderating Midget
wngrog's Avatar
Member # 1154
Send a message via AIM to wngrog
Mudrak is the biggest lurker....
I will stick my biggest 1/2" drive on there, put the Cruiser in gear and back up. Front driveshaft does all the work
Nolen Grogan
1997 FZJ-80 Land Cruiser, 37's
2010 RZR-4
www.cottonlandcruisers.com
www.rockmidgetphotography.com
USAF Veteran 1988-1998 GOD Bless America
wngrog is offline   Reply With Quote
Old 02-16-2009, 12:20 PM   #11 (permalink)
Member # 24859
Never even thought of that Grog. good tip. I used a long 1/2 breaker bar with a 6 ft piece of pipe over it and then jumped on end of pipe.
Mellonhead
peesalot is offline   Reply With Quote
Old 02-16-2009, 10:04 PM   #12 (permalink)
Desert Rat
65SWB45's Avatar
Member # 27432
I think I met this guy today. dude.
MarksOffRoad.net
Originally Posted by lc tpi
...if I have to buy them from Trail Gear I guess I dont need them.
65SWB45, 64LWB45, 68FJ40, 72VJ40, 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer
tlca #1086
member: Trail Crew-L.A. TLCA, Elwood Chapter, TLCA
65SWB45 is offline   Reply With Quote
Old 02-16-2009, 10:17 PM   #13 (permalink)
Bacon addict
Member # 32029
That Mudrak guy? yeah... I've heard of him
Rick
TLCA #14103
Old 02-17-2009, 06:27 AM   #14 (permalink)
Member # 1926
Can you say fireworks?
Old 02-17-2009, 08:44 AM   #15 (permalink)
Member # 12028
Last time I saw him he was throwing an M80 on the ground, under the passenger seat of Dave Wests rig, where it exploded and I needed to change my pants.
Cruiserless :(
Old 02-17-2009, 09:09 AM   #16 (permalink)
Bacon addict
Member # 32029
Bear repellant
Rick
TLCA #14103
Old 02-17-2009, 11:33 AM   #17 (permalink)
Member # 24859
Watch it. All those shannanigans have been banned and certainly "This Guy" follows the rules. Nothin to see here, keep movin. No loud noises comin from his camp.
Mellonhead
