Flipped out rear housing - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-06-2002, 10:16 AM   #1 (permalink)
Reddog's Avatar
Member # 25
Has anyone had any experience with a Cruiser rear axle housing that has been modified to be closer to center for running a centered output transfer case?
The modification I'm talking about is done like this.....
Pull the third, flip the axle housing end for end so the dif is now on the oppisite side,
Cut new nothes for the ring gear clearance,
Re-install the third,
do whatever to the spring perches and bolt it back up.
Apparently this puts the third member into a "closer to center" position that works with a transfer case with a centered output.
[url]http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=151481375[/url]
[SIZE="4"][COLOR="Red"]N C R D[/COLOR][/SIZE]
Chevy Pickup, lifted, modified V8, dual transfer case, lockers, big tires and BIG BALLS !
Reddog is offline   Reply With Quote
Old 09-06-2002, 10:19 AM   #2 (permalink)
Member # 5286
Send a message via Yahoo to Jason M
Why bother,
Get a stronger centered rear axle and go to town..
If you want Toyota get a mini axle..
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote
Old 09-06-2002, 10:21 AM   #3 (permalink)
Member # 1100
looks like it would work,
does anyone know if the bolt holes line up for sure.
and you use the bottom diff cover bolt instead of the drain hole
Ive got an extra rear housing, if you need one.
70Cruzer is offline   Reply With Quote
Old 09-06-2002, 10:28 AM   #4 (permalink)
Eskimo's Avatar
Member # 10429
CV Unlimited sells 'em, Moorefield makes em. No c-clip axles, disc brakes with Monte Calipers...
Flipping the axle would just put the diff on the other side, not centered. There's some cuttin & weldin goin on to make a centered housing.
I will take a picture of it today.
Rich Q.
FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/ORI's/42's
Eskimo is offline   Reply With Quote
Old 09-06-2002, 10:30 AM   #5 (permalink)
Member # 1100
Originally posted by Jason M
Why bother,
might have something to do with the fact that you have the parts, plus lockers, disc brakes, any upgrades....
Old 09-06-2002, 10:34 AM   #6 (permalink)
Member # 1100
we have looked at this and the pinion is offset to the outside so by flipping the rear housing the pinion will now be closer to center. not centered but close. will it work without vibrations? who knows
Old 09-06-2002, 10:44 AM   #7 (permalink)
Member # 5286
Weld it up.
The disk conversions are almost identical between the mini and the LC the caliper mounting bracket is the only difference.
On the positive side, If you flipped the housing upside down you would then instantly have the SO pads
By the time you sell your axle and get a mini one the price is a wash. And you have a lot less hedaches on your hands.
Plus a stronger pinion and cheaper gearsets, no c clip....
DEAR MADAM:
Old 09-06-2002, 10:50 AM   #8 (permalink)
Eskimo's Avatar
Member # 10429
True...didn't think about that. I know *mine* is centered and it took work. But I've heard of guys running centered output t-cases with stock cruiser diffs, but never seen it in person.
Rich Q.
Old 09-06-2002, 10:50 AM   #9 (permalink)
Member # 1100
Weld it up.
good points, but we are cruiserheads, who said we always do things the easy/smart way
Im curious, cause Ive heard of this mod for a while, but never heard of anyone who has done it. sounds like a cool thing to try, and not to much work. one of those fun little projects.
Old 09-06-2002, 11:23 AM   #10 (permalink)
Reddog's Avatar
Member # 25
You're talking about the using a Cruiser third centered between two mini truck axles....I'd really like to see some pics.
I've got all the parts and pieces to do what you are talking about , but I've never actually seen the finished product.
As far as flipping the housing end for end, like 69Cruiser said the pinion is offset to the passenger side so it does actually come back a little closer to center. No cutting of the tubes, spring perches end up over the axle, use the same axle shafts, not to mention all the other parts , like money already spent on lockers, gears and stuff like that. Sounds like a quick and cheap way to bring it a few inches closer to center.
A few inches can be a whole lot depending on what you are getting into
Old 09-06-2002, 11:30 AM   #11 (permalink)
Member # 1100
who brought chuckles into this
Old 09-06-2002, 11:54 AM   #12 (permalink)
Reddog's Avatar
Member # 25
Poor Chuckles, LOL ! It's probably better to keep one's cloothes on if one wants to run wild in the woods
Old 09-06-2002, 12:04 PM   #13 (permalink)
Moderating Midget
wngrog's Avatar
Member # 1154
Send a message via AIM to wngrog
Reddog, I had one of these housings that used Cruiser Diff/Mini Axles...I sold it to Georg...do you live near him?
Worked fine...the only PITA was pressing off the old bearings on the Toy axles and pressing new ones on.
Nolen Grogan
1997 FZJ-80 Land Cruiser, 37's
2010 RZR-4
www.cottonlandcruisers.com
www.rockmidgetphotography.com
USAF Veteran 1988-1998 GOD Bless America
wngrog is offline   Reply With Quote
Old 09-06-2002, 12:06 PM   #14 (permalink)
Moderating Midget
wngrog's Avatar
Member # 1154
Of course the only reason to do this was to run rear disc brakes..if you stick with the drums you won't have to do this part.
Basically, cut the pumpkin out of the Cruiser axle and then weld the Mini tubes to the pumpkin.
Nolen Grogan
2010 RZR-4
Old 09-06-2002, 12:29 PM   #15 (permalink)
Reddog's Avatar
Member # 25
You mean Orangefj45 Georg ? he's close to me, he lives in Stockton. I'll have to ask him about that.
I actually started that Cruiser/mini rear axle project a while back.
Cut the center section out of a Cruiser housing, then I cut the tubes off a mini truck housing, started to size things up and that's about as far as I got. Seems real simple, mini truck axles, no c-clips, Cruiser third......
I started getting all worried about alignment and clearances and stuff like that.
Then I thought about bolting it all together, axles third member, complete then tack weld it all together. My big fear is having somthing pull out of alignment when I start welding on it.
I'd hate to go thru all that work and end up with some kind of howl caused by bad alignment.
Old 09-06-2002, 01:08 PM   #16 (permalink)
Member # 4783
Why bother at all? As long as the overall angle between the pinions and drive shaft are equal or less than they were with the passenger side TC output and the pinion flanges are parallel it shouldn't make any difference if the 3rd member is offset. The U joints won't care if the maximum angle is not in the verticle plane.
It could be an advantage as your drive shaft will be longer and therefore have a lower overall angle. It is also useful sometimes to know that your front and rear pumpkins are in the same line.
The only down side is that your friends will think it looks stupid.
Pin Head is offline   Reply With Quote
Old 09-06-2002, 01:34 PM   #17 (permalink)
Moderating Midget
wngrog's Avatar
Member # 1154
You mean like this?
I made my rear axle with a slight driver's side offeset when I had the 2F since it is 4" offset to driver. Now with the 350 I am centerd and the diff is off.
No problem as the compound angles are way under the 1410 joint max operating angle.
Like Pinhead says, my friends think it looks stupid
Nolen Grogan
2010 RZR-4
Old 09-06-2002, 01:50 PM   #18 (permalink)
Reddog's Avatar
Member # 25
I'm kinda liken Pin Head's opinion here. "why bother"
I think before I get too involved in a centered dif I'll install the new transfer case and run the drive line at an angle. It may work just fine.
I seem to remember Dogwalker saying that on one of his early conversions he ran a Dana 300 with an angled driveline back to the stock LC dif location. Said he didn't have any problems.
Old 09-06-2002, 02:05 PM   #19 (permalink)
Member # 4783
Since you have two FJ25, you could always use one these centered axles.
Old 09-06-2002, 02:16 PM   #20 (permalink)
Eskimo's Avatar
Member # 10429
Here's a pic of mine, if you care...
Rich Q.
Old 09-06-2002, 02:17 PM   #21 (permalink)
Eskimo's Avatar
Member # 10429
one more..
Rich Q.
Old 09-06-2002, 02:18 PM   #22 (permalink)
Member # 1100
A good time to reverse your rear springs to help the angle a little too.
I saw georg axle over there a while back but never paid much attention, Ill have to check it out a little closer next time.
Old 09-06-2002, 02:42 PM   #23 (permalink)
Member # 3427
flipped rear
We actually just did this mod to one we are building for a friend of mine except that we did not "flip" the axle but just "spin" the axle. Same result except the brake likes and vents are still on top. We had to relocate the spring pads anyway to rotate the pinion. It only took about an hour to do once the axle was out from under the truck. It does get closer to center but looks like it will be 5" offset to the drivers side now. The plan is to use a cv type driveshaft and point the rear pinion straigh at the np205 t-case output (north-south / not east-west). It will be a while till we get it running since we are flipping springs, SR, soa conversion, front disc conversion, 350-sm465-np205, fabbing up a rear underbed pto winch, etc, etc, etc
Keep the shiny side up!
wanabecruisen is offline   Reply With Quote
Old 09-06-2002, 03:08 PM   #24 (permalink)
Reddog's Avatar
Member # 25
I keep lookin at those.....hmmm, maybe I'll take a serious look at them and figure out a way to modify one of those for mini truck axles into a Cruiser third.
Eskimo, where are the welds, I mean like where did they join the mini truck outters to the Cruiser inners, if you know what I mean. It's hard to see from the pics.
Hey Len, next time you see Georg ask him about that axle housing, maybe he wants to give it to me for my birthday, eh ?
Wannabe, It's quite often I tend to overlook the obvious, D"OOOOHHHHH !, Spin the housing, what a great idea!
Old 09-06-2002, 03:14 PM   #25 (permalink)
Eskimo's Avatar
Member # 10429
I do have mini-truck outers... There is a weld abour 3/4 over on the right of the tube, just inboard of the leaf spring....
Rich Q.
