Whoops - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-24-2002, 03:47 PM   #1 (permalink)
Member # 3259
Send a message via AIM to FIXXXXAH
Whoops
WELL, IT WAS ONE OF THOSE NO COFFEE-UP BEFORE YOUR USED TO MORNINGS, AND WELL YEH I LEFT A BIT LESS REINFORCEMENT ON MY SHACKLES THEN PLANNED....
ITS 3/8 PLATE SO IM NOT THAT WORRIED, AND THE SHACKLES ONLY TAKE STRESS ON THE WEAK PART DURING DROOP, BUT WHAT DO YOU THINK? THIS WAS THE LAST PEICE OF STOCK SO I THINK I'LL RUN THEM FOR NOW...
[SIZE=1] "ANYONE WILLING TO TRADE FREEDOM FOR SECURITY DESERVES NEITHER."
TUBING AND BUGGIES ARE OVERRATED
METRIC ROCKS. [/SIZE]
FIXXXXAH is offline   Reply With Quote
Old 09-24-2002, 03:50 PM   #2 (permalink)
Member # 5286
Send a message via Yahoo to Jason M
Run them but bring a spare..
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote
Old 09-24-2002, 03:58 PM   #3 (permalink)
Member # 6943
I think you will be all right.
Lets say you have 3/8" edge distance and you said 3/8" plate.
Thats 0.14 sq inches cross section
Assuming 36 ksi steel and appropriate factor of safety
You are looking at about 2500 lbs shear strength for static loading.
Crawl on............
are you kidding me?
KMAN is offline   Reply With Quote
Old 09-24-2002, 04:04 PM   #4 (permalink)
GloNDark's Avatar
Member # 2482
whoa, you smart......me not....... damn that beats the hell out of my "Run it till it breaks commment"
GET IT Dave!!
save me a spot bro......i'll miss you...
GloNDark is online now   Reply With Quote
Old 09-24-2002, 05:54 PM   #5 (permalink)
Member # 6588
[COLOR=yellow]Bj on Roids 1970FJ45, Quad Cam V8, Auto, Broken T-case, H-TEC (traction control and cutting brakes) 42 TSLs.[/COLOR]
[COLOR=green][URL=http://www.outerlimits4x4.com]Aussie Wheelers Bulletin Board[/URL] [/COLOR]
BJ On Roids is offline   Reply With Quote
Old 09-24-2002, 09:30 PM   #6 (permalink)
coyote's Avatar
Member # 170
Now figure your going up hill and have a 5000lb rig with most of the weight shifted to the back and your asking for a failure sooner versus later.....redo it correct or shall it fail at 3 am....in the dark......
Red Racer I
Toyota FJ62
coyote is offline   Reply With Quote
Old 09-25-2002, 06:01 AM   #7 (permalink)
Eskimo's Avatar
Member # 10429
In that case, the thin area (at the top) won't be taking the stress.. Besides, 2500lbs x 4 is a 2x safety margin...
Rich Q.
FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/ORI's/42's
Eskimo is offline   Reply With Quote
Old 09-25-2002, 07:40 AM   #8 (permalink)
Member # 3259
MAN, THATS WHY I LOVE THIS BOARD, YOU GET THE GUYS WHO CAN DO PHYSICS
ACCTUALLY, IM NOT TOO WORRIED ABOUT THE SHEER WEIGHT FACTOR, BUT MORE ABOUT THE FATIGUE APPLIED TO THAT AREA BY THE BOLT WHEN THE AXLE IS DROOPING AND WANTS TO TURN THE BOLT DUE TO THE ARC THE AXLE WANTS TO TAKE. IM GOING TO RUN THME AND CHECK PERIODICALLY FOR DEFORMATION THEN PROBOLY MAKE SOME NEW ONES WHEN EVERUTHING ELS IS BUTTONED DOWN.
Old 09-25-2002, 07:41 AM   #9 (permalink)
coyote's Avatar
Member # 170
That only applies on level ground....and unless your wheeling at the mall most hill climbs are off camber for me thus shifting the weight to the back and forcing the spring to turn and applying stress to that part....its close but I would rework it in the garage versus the trail....much easier.....
Red Racer I
Toyota FJ62
Old 09-25-2002, 08:18 AM   #10 (permalink)
Member # 764
kman made a good post but I believe the shear number would be higher but its irrelevant if you read eskimos post which puts your margin of safety pretty high. do what you said run em and see what happens for that matter don't even worry about them. YOu also need to think of how much down force you axle can provide (real life numbers) Im guessing it is no where near 2500 pounds.
arndog
1966 FJ40
cruiser page
arndog is offline   Reply With Quote
Old 09-25-2002, 11:48 AM   #11 (permalink)
Member # 2619
Send a message via ICQ to DCruiser138 Send a message via AIM to DCruiser138
too much fukin math....just fukin slap somne paint on it....and haul ass!!!! it looks ok...just bring a spare if you want. but i think its fine
Dustin Crawford ---
OPEN DIFF DEUSH'
DCruiser138 is offline   Reply With Quote
Old 09-25-2002, 12:32 PM   #12 (permalink)
Metal-tech'in
helocat's Avatar
Member # 10420
I have always gone by never going less than the radius of the hole. I.E. One inch hole; leave at least half inch of material for spacing to another edge. (End of material, another hole etc.) Not too scientific but a place to start.
In your case, I side with Coyote reworking metal is much easier in the driveway.
Metal Tech Made in the USA! ALL Active duty US Military get 10% off Metal-tech brand – thank you for your service!
helocat is offline   Reply With Quote
Old 09-25-2002, 03:17 PM   #13 (permalink)
Member # 1357
a couple of years ago,Nolen ripped the bottom of his frame horn off instead of damaging the shackle or hanger. But then again, we are talking about Nolen. He has some pics of it if you are interested.
77 FJ40, 5.7L vortec, soa, shaved 14 bolt rear, stock front housing loaded with some good stuff, and a lot of f***ing dents and rust.
rustyb is offline   Reply With Quote
Old 09-25-2002, 04:50 PM   #14 (permalink)
Member # 6943
I second that, I would be more worried about the frame horn/stock mounting than a marginal shackle. I just re-worked my rear shackles and was flabergasted out how thin the metal was the hanger mounted to.
are you kidding me?
