Differential Strength Scale - Toyota, 9", 60, 14 bolt, etc. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-11-2009, 04:00 PM   #1 (permalink)
Member # 100847
Not punching in the right terms to get a good search. Have been hearing about 609 front hybrids - but am more interested in a rear axle right now?
Where does a Ford 9" diff - something along the lines of a custom large bearing Currie unit factor in as compared to other diffs. Advantages - disadvantages? Am following all of the axle build threads and questions - and was wondering if a custom axle with a Ford 9", 35 spline or larger and FF ends would be worth it?
Either looking to go cheap with a 14 bolt with some clearance mods (am already running 39" tires, with 40" MTR's for street duty) - or forego those diamond earrings for the girlfriend and go all out...
I wheel stupid - if that answers how the axle would be used question.
sputnik40 is offline   Reply With Quote
Old 11-11-2009, 04:07 PM   #2 (permalink)
Member # 24859
IMO go 14. Unless you got bank and are building a custom build. The 14 is cheap, and parts will be available readily.
Mellonhead
peesalot is offline   Reply With Quote
Old 11-11-2009, 05:37 PM   #3 (permalink)
Moderator
RustyNailJustin's Avatar
Member # 8568
My friend James wheels "Dumb"
[IMG][/IMG]
2012 KOH Team CrossedUp, ADS, Artec, Mike Klensin and Justin Reece. 9TH Place.
2011 LCQ to KOH Team CrossedUp Mike Klensin and Justin Reece. We finished 40th
2010 KOH Team CrossedUp Mike Klensin and Justin Reece.
2009 KOH Team 435 Finished 35th.First Full Frame/Full Body To Finish KOH.
TLCA# 5305
RustyNailJustin is offline   Reply With Quote
Old 11-12-2009, 07:10 AM   #4 (permalink)
Member # 24876
Wow. Were those gears cryo'd or whats the deal? I know the 9" has the bearing support at the end of the pinion but i still thought you'd shit gears long before killing the 3rd member
[COLOR="Lime"]'85 Toyota ext cab. 4 cyl. 5.29s. Chromoly birfs. dual cases. hi-steer. OBA. front ARB. rear welded. cage.[/COLOR]
FullsizeYota is offline   Reply With Quote
Old 11-12-2009, 08:30 AM   #5 (permalink)
rockthedog's Avatar
Member # 19510
i'm not sure but they looked cryo'd to me.... jk
that is crazy, i've never seen a 3rd explode like that....... i'd go 14 bolt cuz i'm pretty broke most of the time and that would free up money for other stuff. different width options by changing hubs 63"wms w/dually hubs or 67" w/srw hubs.... jmo
77fj40, 1 TON
www.wfoconcepts.com 530-268-9494
tlca# 12281
semi_budget 1ton build
/forum/toyota-land-cruiser/530636-semi-budget-1-ton-buildup-thread.html
linking the rear
http://www.pirate4x4.com/forum/toyot...king-rear.html
rockthedog is offline   Reply With Quote
Old 11-12-2009, 09:30 AM   #6 (permalink)
Member # 1926
Was that a nodular 3rd memeber?
'69 FJ40 with very few stock parts.
2000 Cummins with some goodies to make it smoke.....
Trail Gear's Bad Ethics=Bad Business.
fj40charles is offline   Reply With Quote
Old 11-12-2009, 09:53 AM   #7 (permalink)
Member # 78331
I'm willing to bet it isn't.
dirtchicken is offline   Reply With Quote
Old 11-12-2009, 11:17 AM   #8 (permalink)
Member # 24876
it looks like a stock 3rd..
Old 11-12-2009, 11:41 AM   #9 (permalink)
KyleQ's Avatar
Member # 83837
I have a 3rd in a bucket that looks like that. The gears and Detroit held up fine - I wouldn't say a 9" isn't worth looking at, they can be made VERY tough and have lots of after market support.
74' Bronco - Mustang Injected 5.8 - 105:1- Locked D60/70HD - NP435 -Atlas2 3.8 - PSC Full Hydro - 5.5" lift - Cage Arms - 37" Cut & Grooved Boggers
Bronco Build Thread
KyleQ is offline   Reply With Quote
Old 11-12-2009, 05:29 PM   #10 (permalink)
Member # 24876
but at what cost? IMO by the time you replace everything, you should have just started fresh. Kinda like building a dana 300 vs an atlas
Old 11-12-2009, 05:33 PM   #11 (permalink)
Member # 80208
Your sure stuck on the atlas. ha ha
76 fj-40, 400sb, 465, 35's.
89 blazer, tbi 350, nv 4500, 241, 60, eaton, 5.13's, 38.5 SX's.
J-Ohlin is offline   Reply With Quote
Old 11-13-2009, 11:39 AM   #12 (permalink)
Member # 1926
There is a very good reason for it. Atlas is a great transfer case.
Old 11-13-2009, 04:59 PM   #13 (permalink)
Moderator
Member # 8568
Just a stock 9" with a spool, richmond gears, and moser shafts.
TLCA# 5305
Old 11-14-2009, 04:36 PM   #14 (permalink)
Member # 100847
Yeah - cost is a huge factor, I tend to get sucked in by all the bling axles being developed these days...
That is a wicked sick grenaded rear diff.
Old 11-14-2009, 10:01 PM   #15 (permalink)
Member # 80208
I know the atlas is a great case, I was just givin him shit.
Old 11-15-2009, 04:01 AM   #16 (permalink)
Member # 89922
Do you guys think you could run the cruiser 9.5 diffs upside down for a rear engine application? I know they will bolt in the housing and run high pinion, but will they oil properly? Was just kinda thinking about a buggy idea with 9.5 diffs & housings and fj80 knuckles.
Smokehouse is offline   Reply With Quote
Old 11-16-2009, 09:37 PM   #17 (permalink)
cruiseroutfit's Avatar
Member # 1858
Oil is the least of your worries, the direction is the bigger issue
Kurt Williams
Cruiser Outfitters - YOUR CRUISER PARTS SOURCE! - ARB - OME - Engel - Helton - AdvAdapt
ExpeditionUtah.com
U4WDA - Member
TLCA #10662
Wasatch Cruisers #028
Mountain Yoats
Red Rock 4 Wheelers #789
Mojave Underground
kurt@cruiseroutfitters.com
cruiseroutfit is offline   Reply With Quote
Old 11-17-2009, 12:27 AM   #18 (permalink)
Member # 89922
What do you mean by direction? I know you have to run the diff's upside down to be able to go forward in forward gears in rear engine application, the question is how does the oiling system in toyota 9.5" chunks work?
Old 11-17-2009, 05:29 AM   #19 (permalink)
Wilson's Avatar
Member # 7233
You will be running on the coast side of the gears, people do it all the time, whether they know it or not.... as almost all front axles were not designed to be front axles and run on the coast side of the gear. I don't see a 9.5" LC diff being stronger than a 9". Personally, I would rank a nodular 9" center higher in strength than a D60, simply due to the extra pinion bearing.
[COLOR=Red][SIZE=4]ECV 7-11[/SIZE][/COLOR] Serving up a Tsunami of Swagger
Wilson is offline   Reply With Quote
Old 11-17-2009, 05:43 AM   #20 (permalink)
LC Hamma's Avatar
Member # 137
I've seen pics of how JR modded his 9" diffs to run upside down w/ custom oil slingers. I'd run the Six Shooters instead of the stock FJ80 knuckles if you're stuck on keeping it all LC related . If you're not a purist, I'd do the smart thing & go w/ the D60 outers. That way, if you want to go 35 spline & rebroach the LC 3rd member, you can
'72 FJ55
http://forum.ih8mud.com/showthread.php?t=76835
'73 FJ40
http://s132.photobucket.com/albums/q...&addtype=local
'78 FJ40
'91 Ram W250 5 spd. CTD
'93 Ram W350 5 spd. CTD
'99 Ram 3500 4X4 5 spd. CTD
Welding is like sex, it's all about the penetration!
LC Hamma is offline   Reply With Quote
