corner protection - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-24-2009, 11:14 AM   #1 (permalink)
Member # 57425
corner protection
im trying to find some corner protection similiar to what poison spyder has for teeejays. it seems as thought the budbuilt replaces the fender im looking for something that goes over it any body have pics of this? either custom or production
78 fj40 with some junk and mud tires
00 runner with less junk and mall terrain tires
jimbo92 is online now   Reply With Quote
Old 01-20-2010, 06:02 PM   #2 (permalink)
Member # 57425
well i decided to but the bullet and go with it. Im doing a new cage sliders and some paint so i figured now would be the time to do it. Im doing full crushers with pieces on the rockers as well. Both pieces are being done out of 1/8th inch steel. Also they are being done on a roller instead of step bending to avoid the creases.
also probably going to go with some kind of led lighting in the stock location being as i constantly break the stock lenses and get water in them
also the cut on the crusher is going to follow the door line not stay straight as it is in the picture
Old 01-21-2010, 01:27 PM   #3 (permalink)
Member # 23069
Looks great. The step bending is what has always kept me away from the ones that are available, that and the diamond plate.
Fourwheeling is like sex, when it's good it's really good, and when it's bad it's still pretty good!
65' FJ40 Uninstalled parts piling up blah,blah,blah......
Evergreen12 is offline   Reply With Quote
Old 01-21-2010, 01:32 PM   #4 (permalink)
PJohnson's Avatar
Member # 263
Nice.
Warrior Products does an FJ40 corner that is not diamond plate. It's not as thick as yours, but ok.
Phil
1966 FJ45 LPB-1973 FJ40- KR6AWL
MTA 4x4 - San Jose, CA
PJohnson is offline   Reply With Quote
Old 01-21-2010, 02:31 PM   #5 (permalink)
FJ 40 Dave's Avatar
Member # 17594
Here is what info that I received from www.warriorproducts.com
The part number S914 steel corners cost $158.37 per pair plus freight
FJ 40 Dave is offline   Reply With Quote
Old 01-21-2010, 02:54 PM   #6 (permalink)
Member # 23069
That seems like a deal. I wonder if one could talk them into selling them blank without wheel cutout. I'm going to have to look into these further.
Old 03-08-2010, 10:37 PM   #7 (permalink)
Member # 57425
figured id throw in a little update the project took a bigger turn than expected
Old 03-10-2010, 10:04 PM   #8 (permalink)
Desert Rat
65SWB45's Avatar
Member # 27432
I did my corners in 1/8" steel. Welded the leading edge in place on the rig and just heated the metal and bent it around the corners, tacking top and bottom as I went. Actually, I let someone else do the heating while I did the sledgehammer bending part!
Radius wasn't perfect, but definitely not step-bent looking either.
MarksOffRoad.net
Originally Posted by lc tpi
...if I have to buy them from Trail Gear I guess I dont need them.
65SWB45, 64LWB45, 68FJ40, 72VJ40, 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer
tlca #1086
member: Trail Crew-L.A. TLCA, Elwood Chapter, TLCA
65SWB45 is offline   Reply With Quote
Old 03-11-2010, 08:02 AM   #9 (permalink)
Moderator
RustyNailJustin's Avatar
Member # 8568
Hey, Good to see you here
2012 KOH Team CrossedUp, ADS, Artec, Mike Klensin and Justin Reece. 9TH Place.
2011 LCQ to KOH Team CrossedUp Mike Klensin and Justin Reece. We finished 40th
2010 KOH Team CrossedUp Mike Klensin and Justin Reece.
2009 KOH Team 435 Finished 35th.First Full Frame/Full Body To Finish KOH.
TLCA# 5305
RustyNailJustin is offline   Reply With Quote
