Somebody has made RWS conversion here? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-14-2010, 10:10 PM   #1 (permalink)
Member # 90125
I'm selling Dana 60s and was thinking about taking two of them to make a 4 wheel steering buggy. To keep axles in the stock length configuration, I could just inverse the 2 tubes of the front Ford dana 60. Both diffs will then be offset on the passenger side (clearance advantage). The only t-cases options for that are samurais, t-18s or land cruisers cases. Cruiser cases seems the good one because of the Orion upgrade and strength.
Someone has already done this?
John 3:16
ob0ne is offline   Reply With Quote
Old 01-14-2010, 11:18 PM   #2 (permalink)
Pooze's Avatar
Member # 104239
I think trevor does something like that http://www.wfoconcepts.com/Default.aspx
1978 FJ40,383 stroker, 350,205,corp 14,dana 60 detroits 5.13's 42" Irocs, and a little tubing.
1974 FJ40-metal tech tubing, 4.88, Detroit rear, Arb front, 60 outers
1967 FJ45-Mater
http://www.rubiconfriends.com/
http://www.laketahoehilos.com/
http://www.badrap.org
Pooze is offline   Reply With Quote
Old 01-15-2010, 06:26 PM   #3 (permalink)
Member # 90125
link doesn't work.
John 3:16
Old 01-16-2010, 08:38 AM   #4 (permalink)
Member # 12663
Send a message via AIM to Leafsprung
NP200 and LT230 gear driven t-cases also have RH outputs
I am what I am - Popeye
Leafsprung is offline   Reply With Quote
Old 01-16-2010, 12:20 PM   #5 (permalink)
Member # 90125
Maybe the lt230se could be à good one for this kind of application. For that, I would retain the stock engine+manual tranny.
The Orion could be mated to the granny sm435 or np465. That is also a + on the Orion choice.
John 3:16
Old 01-16-2010, 11:54 PM   #6 (permalink)
Pooze's Avatar
Member # 104239
1967 FJ45-Mater
Old 01-17-2010, 06:07 PM   #7 (permalink)
Member # 90125
Thanks but no project like that on the web site...
... but I can't wait to see their trail ovens. Probably some burrito box to put on the headders.
John 3:16
Old 01-17-2010, 08:19 PM   #8 (permalink)
88 mangler's Avatar
Member # 31780
they can build you axles anyway you want them if you are looking for someone to build them.if you are just trying to get an idea of what is needed to run a setup like your talking about you might get a quicker response posting over in general 4x4 since thats more of a common set up for buggies.
88YJ, d60 with some goodies&14bolt,atlas,111"wb,40"creepies,some other stuff and 6 angry hampsters under the hood!:D
tow rig: 07.5 6.7l dodge 2500
Dixon 4Wheelers
Build it, Break it,Fix it, Repeat!
88 mangler is offline   Reply With Quote
