stretching the 40 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-17-2010, 06:33 PM   #1 (permalink)
turnmeover's Avatar
Member # 105563
stretching the 40
well after the install of a sm465/toybox/splitcase i need more drive shaft. after much deliberation i decided to cut and stretch the frame and body by 8". here are some starting pics.
l plan to cut just forward of the tubular cross member . I will do a step cut by 4" which will give me a total of 22" of weld surface combined with the 16" of fish plate. should be strong enough to survive the abuse of the rock world.
i searched this before and i found nothing. so i hope i am the first to do this. I seriously doubt this.
http://nfcruiserheads.org/forum/inde...ch=10173;image
http://nfcruiserheads.org/forum/inde...ch=10175;image
turnmeover is offline   Reply With Quote
Old 04-17-2010, 07:22 PM   #2 (permalink)
Member # 85813
Trupster did this:
http://www.pirate4x4.com/forum/showt...957&highlight=
And it looks like Wilson is too, but there aren't any pictures of the stretched tub in his build thread.
E WHEELER is online now   Reply With Quote
Old 04-18-2010, 12:55 PM   #3 (permalink)
Wilson's Avatar
Member # 7233
Originally Posted by E WHEELER View Post
Trupster did this:
I would consider mine to be more of a buggy style build. The only tub left in mine is the cowl, skinned over tube door openings and the very top rail from the back of the tub.
[COLOR=Red][SIZE=4]ECV 7-11[/SIZE][/COLOR] Serving up a Tsunami of Swagger
Wilson is offline   Reply With Quote
Old 04-18-2010, 08:13 PM   #4 (permalink)
Member # 47170
Everything OK with toybox? I haven't heard otherwise
Jerry
jerz4wd is offline   Reply With Quote
Old 04-19-2010, 06:41 AM   #5 (permalink)
LC Hamma's Avatar
Member # 137
IMO, an inner sleeve would be the best option, extended 6" to 8" either side past the new frame section into the existing frame. I know that would be a little more trouble due to the inside frame rivets. Then, weld up your "V" cuts. Or, the fishplate idea would be a good option as I've done that in the past.
'72 FJ55
http://forum.ih8mud.com/showthread.php?t=76835
'73 FJ40
http://s132.photobucket.com/albums/q...&addtype=local
'78 FJ40
'91 Ram W250 5 spd. CTD
'93 Ram W350 5 spd. CTD
'99 Ram 3500 4X4 5 spd. CTD
Welding is like sex, it's all about the penetration!
LC Hamma is offline   Reply With Quote
Old 04-19-2010, 04:13 PM   #6 (permalink)
turnmeover's Avatar
Member # 105563
Jerry
yet to finish the install. Will defiantly let you know.
