Brake Booster solution? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-22-2002, 01:27 PM   #1 (permalink)
Member # 14417
I recently bought a 72 fj40 and the brake booster went out promptly after I got it home.... so insted of buying the $350 rebuild kit, I found a 71 fj40 with one in it at local wreaking yard, for $125 with master cylinder. My questions is will the 71 work with my 72? What are my other options. Any help is greatly appreciated. Thanks
Crashnburn
crashnburn is offline   Reply With Quote
Old 10-22-2002, 01:30 PM   #2 (permalink)
Member # 9216
Send a message via AIM to Mr McGee Send a message via Yahoo to Mr McGee
from what i know, it should work...both years have drums all the way around.
Nick Hietpas...1985-2003
Rest In Peace
Mr McGee is offline   Reply With Quote
Old 10-22-2002, 01:56 PM   #3 (permalink)
Member # 14417
Thanks.... Is this a common problem for older yotas and would I have this problem with the one from the wreaking yard seeings how it's fromt he same vintage?? Or should I just sack up and rebuild the one I have? (Damn that's alotta cash!!)
Crashnburn
Old 10-22-2002, 02:12 PM   #4 (permalink)
Member # 1849
Booster Dewey does those LC years for $125, and zinc plating is just a bit more.
sorry, no good contact info, in Oregon or Washington State.
rick d is offline   Reply With Quote
Old 10-22-2002, 02:16 PM   #5 (permalink)
Junkyard's Avatar
Member # 522
test it out
The one from the wrecking yard should be the exact same as the one that you're replacing, but it might also have the same problem as your current one. The only way to really know will be to bolt it up & test it out. $125 seems kind of high to me.
You should be able to use other types of master cylinders and/or boosters in your year cruiser. For example, I've got a booster/master in mine from an '83 1-ton Toyota pickup and it bolted right up with no problems. I only paid $25 for both the booster & master cyl.
Do a search - lots of discussion threads about boosters/masters.
- Dave
You haven't lived a full life until you've delivered a baby in your bathroom at midnight...
Junkyard is offline   Reply With Quote
Old 10-22-2002, 02:55 PM   #6 (permalink)
Member # 14417
Is there anything to be aware of when swaping in another model's booster as far as throw or PSI in sucking power?? Or is it a plug and play part? I'm sure I could find something else that I could "rig - up" but I don't want it looking like chit!
I realy appreaciate all the help guys!!
Jason
Old 10-22-2002, 08:38 PM   #7 (permalink)
181
LCOwner's Avatar
Member # 181
When I did my dick break conversion I used a master cylinder out of a mini truck. It bolted right up to my 71 booster and has never given me a a single problem. I consider this to be a better option because mini-truck parts are much more available than LC in the parts stores.
Team Member: G-Man Racing #213
LCOwner is offline   Reply With Quote
Old 10-22-2002, 08:51 PM   #8 (permalink)
texican's Avatar
Member # 12349
[QUOTE]Originally posted by LCOwner
[B]When I did my dick break conversion
AAAAAAAAAARRRRRRRRRRRRGGGGGGGGGHHHHHHHHHH!!!!!!!!! !
Don't want one of these!!!!!!
Butch
Conflict is inevitable.....
Combat is optional....
Tires are like boobs, they always look big until you have played with them for a while, then you just want a bigger set.
[URL=http://www.lslc.org/]Lone Star Land Cruisers[/URL]
[URL=http://www.khyi.com/]Support Texas Music[/URL]
texican is offline   Reply With Quote
Old 10-22-2002, 09:42 PM   #9 (permalink)
Member # 14417
If you used the mini truck master cylinder, did you use the brake booster out of the MT?
Crash
Old 10-23-2002, 06:13 AM   #10 (permalink)
Member # 9216
owwwwweeeeee!!! lol im at school and even my teacher is laughing!!!1
Rest In Peace
Old 10-23-2002, 08:25 AM   #11 (permalink)
Member # 9851
I used a booster and master out of a 97 Tacoma, and it works great! I had one out of a 88 mini truck and it did not work anywhere near as well( same master in bolth cases) so get a matched set!
-Scott
"CRUZILA" 75 FJ40.....with some stuff done to it.
Cruzilla is offline   Reply With Quote
Old 10-25-2002, 07:26 AM   #12 (permalink)
Member # 1797
Send a message via ICQ to Cruiser Ken
-Scott
I thought you were using an FJ80 master cylinder? Do you have a proportioning valve?
Cruiser Ken is offline   Reply With Quote
Old 10-25-2002, 07:35 AM   #13 (permalink)
Member # 450
Send a message via ICQ to Macgyver Send a message via Yahoo to Macgyver
Crash
Crash, did you do a search as recommended above? your questions will be answered with a little research as they have all been asked before. check out the link at the top "before asking any tech questions"
NRA/DAV Life Member
'69 FJ40, 86 Runner
Macgyver is offline   Reply With Quote
Old 10-25-2002, 07:45 AM   #14 (permalink)
Member # 9851
The MC from a Taco and a FJ80 are the same thing(as far as I can tell) 1" bore, aluminum housing, single resivour. and yes I run a prop valve, and have a 2# residual valve for the rear on the way!
-Scott
Old 10-25-2002, 02:39 PM   #15 (permalink)
Member # 7631
Send a message via ICQ to Zipp Send a message via AIM to Zipp
I had a single reservoir, no booster setup in my 1970 (mfg date: 11/69). I installed a booster and master out of an '85 toy minitruck 1ton (15/16" bore) when I went with discs in front. All I can say is: Damn! I can stop now!!! Why am I posting here? Oh yeah- I got the booster/master for $20 and a couple axle shafts- traded with Seabass44 for it.
Moral of the story: cheap stuff can get you where you need to be. Cheap doesn't always mean crappy and unsafe... (Just most of the time. )
Brandon Zipp
- 1970 FJ-55 - 350 - sm420 - SOA - 37" MTR's - PS(fj60) - Discs - And other stuff in the works...
Zipp is offline   Reply With Quote
