Aussie FJ40 Build-up - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-17-2010, 07:38 PM   #26 (permalink)
Member # 20907
Copying some updates from Brooksy across from another forum.
Originally Posted by brooksy
Couple more from this arvo as the wife wanted to have a look
brooksy
2012 FJ Cruiser
1984 BJ42 MWB Landcruiser
twisty_toy94 is offline   Reply With Quote
Old 10-17-2010, 07:39 PM   #27 (permalink)
Member # 20907
x2
Dave asked me to post up some more progress pics as 4wdlinks is still down
Here is a quick couple pics of the battery mount that is fixed on seat rail tube. I have a dimpled bracket that is going over the top to mount Daves Waeco fridge console on top which I will have done by this arvo
Here is a couple of the 57L fuel cell mounting, very strong & pretty easy to remove as one complete unit with hose lengths allowing to sit on ground.
brooksy
2012 FJ Cruiser
Old 10-17-2010, 07:41 PM   #28 (permalink)
Member # 20907
x3
Here is the doors. Dave is having 2 sets of doors. These are the daily set which will be used for the Scenic Rim trip at the end of this month.
I am making a tube set but they are going to take some time as they will be pretty detailed with removable sections. They will be done at the same time when I do the tailgate carrier & roof rack.
Marked out doors to a height that is same as rear tube ontop of the tub. Dave will be painting the cage the same as the body so this works great. If He was painting the cage a different colour the doors would need to be cut lower to match the body line as it wouldn't look right.
brooksy
2012 FJ Cruiser
Old 10-17-2010, 07:41 PM   #29 (permalink)
Member # 20907
x4
The cage fouled on the doors (which I knew would happen) so I did a bit of panel work to follow the tube cage lines.
And the result, pretty good I thought.
Top skins
brooksy
2012 FJ Cruiser
Old 10-17-2010, 07:43 PM   #30 (permalink)
Member # 20907
x5
Started mounting checking for fit & clearances.
Tac'd into position
Height is awesome & you feel comfortable
brooksy
2012 FJ Cruiser
Old 10-17-2010, 07:43 PM   #31 (permalink)
Member # 20907
x6
took both doors off & fully welded interior skin but only did spot tac's roughly every 1" on outside to minimise warping although on each end & at the point where the door angles up I run a weld to eliminate cracking.
brooksy
2012 FJ Cruiser
Old 10-17-2010, 07:44 PM   #32 (permalink)
Member # 20907
x7
Finished & the doors outer skin is pretty damn flat with next to no warping at all
Some pics outside
brooksy
2012 FJ Cruiser
Old 10-17-2010, 07:44 PM   #33 (permalink)
Member # 20907
x8
Onto seat belt mounts.
Had the belt cartridge mount on 8mm plate welded to just above B-pillar mount
Next was the shoulder mount which needed to be drilled through the cage & welded both sides to pass regs
brooksy
2012 FJ Cruiser
Old 10-17-2010, 07:45 PM   #34 (permalink)
Member # 20907
x9
Finished, but I didn't have a 7/16 UNF tap so will need to buy one so I can use factory HT Bolts that allow seatbelt mount to rotate.
brooksy
2012 FJ Cruiser
Old 10-17-2010, 11:36 PM   #35 (permalink)
Member # 63280
Send a message via MSN to brooksy1
Well here I will update some myself to help you out mate instead of me being slack
OK, finished for the day so progress for today was bashplate/fuel cell guard is complete & battery/Waeco centre console done.
Console first:
Front
Rear
45mm clearance to battery terminals so should be fine.
With seats back in place
brooksy
C44F-Custom 4x4 Fabrications Australia
project - "STRETCH" LS1 FJ40 105"wb
brooksy1 is offline   Reply With Quote
Old 10-17-2010, 11:37 PM   #36 (permalink)
Member # 63280
Rear Fuel cell guard.
Looks good combined with rear barwork. Lot of dimpling but just enough without being over the top.
brooksy
Old 10-17-2010, 11:37 PM   #37 (permalink)
Member # 63280
Couple outside pics
brooksy
Old 10-21-2010, 08:33 PM   #38 (permalink)
Member # 20907
Some more updates by Brooksy (copied from another forum)
Well basic outline of Tyre gate is done although I am going to be lowering the stinger height so I can bring it in closer to the back as currently it needs to be out that far to get tyre off.
I was going to just cut the stinger off halfway up the lower radius & angle cap the ends of the tube to give it the KOH look but as Dave mentioned don't think the Police or DOT would approve :crazy:
I am using factory points to simplify the mounting & maybe make it easier for other 40's to be done.
I folded some 6mm plate to fit on the radius corner.
I will be doing some dimple infills on the bush brackets
You can see in this pic how I have used a larger tube slipped over & cut to use as a stop on both sides for the tailgate
brooksy
2012 FJ Cruiser
Old 10-21-2010, 08:34 PM   #39 (permalink)
Member # 20907
No.2
With wheel mount & latch.
I am however having some issues with the latch holding correctly but hopefully will have that sorted over the weekend along with all the bracing tubes & gussets
brooksy
2012 FJ Cruiser
Old 10-21-2010, 08:34 PM   #40 (permalink)
Member # 20907
No.3
Pics of Slider/Stinger
I have changed my mind since these pics & I am going to be lowering the stinger about 2-3" so I can bring it in closer to the tyre. I currently have it like this so you can get the Krawler out, it is huge for a 35" tyre.
I will be running a support under the stinger from the rolled tube to the rear bar to help with loads.
Here are a couple pics with it outside as I had to get a couple for 4wdA as they wanted to do a mini build feature on it for the Custom mag.
brooksy
2012 FJ Cruiser
Old 10-21-2010, 08:35 PM   #41 (permalink)
Member # 20907
Last....
Couple cage pics
brooksy
2012 FJ Cruiser
Old 10-22-2010, 02:14 PM   #42 (permalink)
plasma dust huffer
carslut's Avatar
Member # 25823
Send a message via ICQ to carslut
nice work
Duramax and LS based motor tuning
Offering in House Custom CNC Plasma cutting services, we can take your idea from design to your doorstep.
have a sketch you want to become parts for your project? pm me, i can help. parts are shipping out daily
"it makes the mach5 look like a vagina" - ARCHER
carslut is offline   Reply With Quote
Old 10-26-2010, 12:29 AM   #43 (permalink)
Member # 63280
Thought I would share the changed wheel carrier.
It ended up about 1" higher at bottom, 1.5" closer & the hoop is around 3" lower.
Not as big as the Krawler in width.
Justin dropped some goodies off to Dave so he brought them down with him.
Thought I had better add a bit of B.R.U.
brooksy
Old 10-26-2010, 12:30 AM   #44 (permalink)
Member # 63280
brooksy
Old 10-26-2010, 12:37 AM   #45 (permalink)
Member # 63280
brooksy
Old 11-08-2010, 06:06 PM   #46 (permalink)
Member # 64205
nice work guys
i realy like your swigaway carrier. sweet fab work
current build, tj,boatside dovetail, ls1 auto, 4 speed atlas, d60 10.25, 42 irok's...
iancj7 is offline   Reply With Quote
Old 11-11-2010, 03:17 AM   #47 (permalink)
Member # 20907
Originally Posted by iancj7 View Post
nice work guys
Thanks mate!
Just some pics from the Spring Hardcore Wheel at Scenic Rim the other weekend. Thanks to Bundy for taking them!
On the way there.
Camp
2012 FJ Cruiser
Old 11-11-2010, 03:18 AM   #48 (permalink)
Member # 20907
Brooksy was checking the rear shocks....thought we had enough clearance to the fuel cell mount, but they rub..... :bad-words:
2012 FJ Cruiser
Old 11-11-2010, 03:18 AM   #49 (permalink)
Member # 20907
2012 FJ Cruiser
Old 11-11-2010, 03:19 AM   #50 (permalink)
Member # 20907
2012 FJ Cruiser
