Aussie FJ40 Build-up - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-12-2010, 07:48 PM   #1 (permalink)
Member # 20907
Few pics of a cage build we started on my FJ40 on the weekend. Still some tube and bracing to be added, but we got the main shape all done up in one weekend.
2012 FJ Cruiser
1984 BJ42 MWB Landcruiser
twisty_toy94 is offline   Reply With Quote
Old 09-12-2010, 07:48 PM   #2 (permalink)
Member # 20907
2012 FJ Cruiser
Old 09-12-2010, 07:49 PM   #3 (permalink)
Member # 20907
2012 FJ Cruiser
Old 09-12-2010, 11:27 PM   #4 (permalink)
Member # 63280
Send a message via MSN to brooksy1
Having a break from the shed tonight as I am buggered from the brews
Doing an order for the rest of the stuff for your 40 tonight, hope the exchange rate is good
brooksy
C44F-Custom 4x4 Fabrications Australia
project - "STRETCH" LS1 FJ40 105"wb
brooksy1 is offline   Reply With Quote
Old 09-12-2010, 11:30 PM   #5 (permalink)
Member # 64205
looks good, are you going to tie it into the frame?
current build, tj,boatside dovetail, ls1 auto, 4 speed atlas, d60 10.25, 42 irok's...
iancj7 is offline   Reply With Quote
Old 09-12-2010, 11:37 PM   #6 (permalink)
Member # 63280
Definately, doing an order for tie in bushes & some bracing gussets so the chassis mounts can be done.
brooksy
Old 09-12-2010, 11:44 PM   #7 (permalink)
Member # 64205
brooksy
cool
only way to go
Old 09-26-2010, 02:38 PM   #8 (permalink)
Member # 20907
Headed down to Brooksys on the weekend and we made some more progress on the cage. Still got lots of bits and peices to sort.
First thing was remove the 140l fuel tank and seats and the 75 series steering column. Then swapped in a standard 40 series steering column (which has been modded to suit p/steer) to help with getting the new seating position right. Really happy at the height of the seats now.
New seat rails.
Bit blurry, but shows the A to B pillar tube.
Old seating position
And the now lower one.
Diesel prefered it with no seats.
2012 FJ Cruiser
Old 09-26-2010, 02:39 PM   #9 (permalink)
Member # 20907
New Fuel cell is a RCI2162A 15 Gallon (57 litres) tank, measuring 30"x12"x9" (762x305x230). Got it from http://www.rocketindustries.com.au for $405 delivered. It will be mounted under the body behind the rear diff.
Some of the bracing tubes.
2012 FJ Cruiser
Old 09-26-2010, 02:39 PM   #10 (permalink)
Member # 20907
2012 FJ Cruiser
Old 09-26-2010, 06:19 PM   #11 (permalink)
jedrattle's Avatar
Member # 21750
Nice!!
Team RattleKann
**ROCKBRAWLERS**
jedrattle is online now   Reply With Quote
Old 09-28-2010, 01:23 AM   #12 (permalink)
Member # 20907
Few more bits and pieces brooksy got done today.
2012 FJ Cruiser
Old 09-28-2010, 01:24 AM   #13 (permalink)
Member # 20907
2012 FJ Cruiser
Old 10-04-2010, 04:04 AM   #14 (permalink)
Member # 63280
Bit lazy & tired to do a write-up but here are some pics, basically all done except tailgate/wheel carrier as I am still waiting for parts from USA. I have a little more work on tank bashplate too.
Twisty has some more detailed shots but here are the cage pics.
brooksy
Old 10-04-2010, 04:05 AM   #15 (permalink)
Member # 63280
Cage back in the 40
brooksy
Old 10-04-2010, 04:07 AM   #16 (permalink)
Member # 63280
Rear mounted 57L/ 15Gallon fuel cell with bashplate & fully removable cell mount
I have done a very trick dimple effect (thanks Don-fc187) on the bashplate but haven't taken pics, Dave has some.
I still have to do the same effect on the rear vertical section but time was getting away from us so I will do it during the week.
brooksy
Old 10-04-2010, 04:08 AM   #17 (permalink)
Member # 63280
A lot of other stuff was done things like finish all welding, die grind out cage footings in floor, the fuel cell/bashplate assembly, battery box intergrated into seat mounting bracket, fuel filler in rear floor, run new fuel lines & refit wiring.
I still have to put in seat belt mounts in B-pillar & do cross brace. May while I am there do harness mounts for added safety when driving the more risking tracks.
brooksy
Old 10-04-2010, 08:05 PM   #18 (permalink)
Member # 20907
Some pics of the bomb proof fuel cell mount.
2012 FJ Cruiser
Old 10-04-2010, 08:06 PM   #19 (permalink)
Member # 20907
Mounted in the chassis. (2mm bashplate with go fast dimples not fitted in these pics). Brooksy will have to post up some better pics with the bashplate fitted)
Sits nicely on the springs to allow the removal and fitting of the fuel lines.
Dimple died the floor for access to the filler.
2012 FJ Cruiser
Old 10-04-2010, 11:40 PM   #20 (permalink)
Member # 63280
Here are a couple pics of the bashplate covering fuel cell.
The dimples are located where the X bracing isn't so the dimpling strengthens those points.
I still need to do the vertical return to the bumper section, I will do it this week.
brooksy
Old 10-05-2010, 05:33 AM   #21 (permalink)
Member # 102244
Can you show pics how the rear tube flares are mounted? Cage looks awesome!!
deliverance72 is offline   Reply With Quote
Old 10-07-2010, 01:33 PM   #22 (permalink)
Member # 14670
Bitchin tube work, really like your design....
Ride it like you stole it.
Radd Cruisers is offline   Reply With Quote
Old 10-08-2010, 01:25 AM   #23 (permalink)
Member # 63280
Thanks,
Still got a bit to finish off but it is basically there !
I know Dave is happy which is the main thing. Going to give it a test in a couple weeks at a social wheelin' weekend that we have going now.
brooksy
Old 10-11-2010, 08:46 AM   #24 (permalink)
Member # 139747
Awesome thread! Thanks for sharing!
Intersted to know whats the wheelbase on your rig and how did you stretch it? Also are those 35s?
Thanks Again! Keep it coming!
Suhaib Kiani is offline   Reply With Quote
Old 10-11-2010, 05:35 PM   #25 (permalink)
Member # 20907
Thanks. Site I host my pics on is down at the moment, but I will post some build pics of the rear tube flares and tube front fenders once its back up.
No worries.
Yeah, tyres are 35x13.5 Krawlers.
Wheelbase is around 96" using custom springs. Suspension setup is.
1260mm (49.6") long front leafs 4" lift (bout 4.5" longer then std.) Fixed hanger was moved back approx 3"
1340mm (52.8") long rear leafs 4" lift (bout 7.8" longer then std.). Shackle hanger was moved to rear crossmember.
2" extended shackles
12" travel bilstein 5125s all round
High Clearance U-Bolt Plates
Rear diff back 5" from standard, front forward 1"
2012 FJ Cruiser
