cnagpilot's crop duster - Page 12 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-14-2011, 02:26 PM   #276 (permalink)
Best Bronco Parts!
WildHorses's Avatar
Member # 19421
Beautiful rig man!!!
WILD HORSES 4X4 & Off-Road Parts
640 N. Eldorado
Stockton CA 95202
209-943-0991
http://www.wildhorses4x4.com
HEADBANGER Roll Bar Pads
Monthly Specials
Ebay
WildHorses is offline   Reply With Quote
Old 03-14-2011, 07:35 PM   #277 (permalink)
fc187's Avatar
Member # 1525
Originally Posted by WebWhlR View Post
Love the updates Don!
If it was my choice... no paint... I would just clear coat the whole thing!
Originally Posted by rugburn View Post
WORD FOOL !
Originally Posted by brooksy1 View Post
It is something I am throwing around too with my build. Crapload of clear after some steel wooling & pickle paste.
brooksy
would be cool! clearing steel can be weird. if the steel is too smooth, it looks like Grey paint?
Hydro assist diff tube bracket is tits !!
brooksy
Thanks B!
Originally Posted by Flatty View Post
Whose sway bar is that? I think I am in love with this thing.
Dima
thanks Dima! its a rock equipment bar..
Originally Posted by SixPax View Post
What size are the rims and tires on this? Just trying to get some prospective. Again, great work!
42s on 17" walkers....
NCRD
fc187 is offline   Reply With Quote
Old 03-14-2011, 07:43 PM   #278 (permalink)
fc187's Avatar
Member # 1525
Thank you very much
Been meaning to stop by and check out James's rig. prolly just end up seeing you guys at Chips on the 2nd for the swapmeet? mostly toyota stuff, but the food will rock!
NCRD
Old 03-16-2011, 02:59 PM   #279 (permalink)
SlamBone's Avatar
Member # 136717
You rock don!! That rig is hands down my favorite build you've done thus far! But fuck that thing and get yours done so we can go wheeling!!
" look up and live "
85 cj 7 60's 39.5 irocks 6.0 t-18 dana 300 (look up and live)
SlamBone is offline   Reply With Quote
Old 03-16-2011, 04:40 PM   #280 (permalink)
Member # 124127
Spring Reversal VS Non Spring Reversal
Originally Posted by fc187 View Post
shackle outboard..
Don-Most if not all of your builds place the front leafs back to the stock application. Fixed mount in back, shackle in front. Without getting into the whole spring reversal debate do you follow or have a typical set up for this? If your using 40 leafs how far back do you put the front hanger and where do you put the back fixed point? if your using 55/60 leafs? (Post #7 &8) Etc....
rhenry is offline   Reply With Quote
Old 03-16-2011, 07:54 PM   #281 (permalink)
fc187's Avatar
Member # 1525
thanks Bro! when it roll out, I will get back on mine.....
no typical formula, location of the fixed mount, for the most part is based on tire size and where I want that tire to sit inside the wheel well. I stuck a 60 axle in the front of the hippies 40 using 55 rears with the axle offset two inches from center. If you like I can get you a pic/measurement?
NCRD
Old 03-16-2011, 07:57 PM   #282 (permalink)
fc187's Avatar
Member # 1525
a little alu-minni-um (1/8" on floor and top of fenders, .080 every where else)
and 78 body tabs later.......
NCRD
Old 03-16-2011, 08:08 PM   #283 (permalink)
In the Dark
cnagpilot's Avatar
Member # 128178
Thumbs up
Saweet!
cnagpilot is offline   Reply With Quote
Old 03-16-2011, 08:27 PM   #284 (permalink)
Member # 124127
no typical formula, location of the fixed mount, for the most part is based on tire size and where I want that tire to sit inside the wheel well. I stuck a 60 axle in the front of the hippies 40 using 55 rears with the axle offset two inches from center. If you like I can get you a pic/measurement?[/QUOTE]
That would be great if you could. Thanks.
Old 03-16-2011, 09:39 PM   #285 (permalink)
Member # 121345
Very nice work on the aluminum. Did you use a form block for clearance on the coil over and compound bends?
77 FJ40
97 4runner
FlyingLow is offline   Reply With Quote
Old 03-18-2011, 07:24 AM   #286 (permalink)
Member # 105834
OK! here ya go!.....
Thanks Don, Looks Great!
war pony is offline   Reply With Quote
Old 03-18-2011, 07:09 PM   #287 (permalink)
fc187's Avatar
Member # 1525
made a make shift die for the press
thanks!
NCRD
Old 03-18-2011, 07:10 PM   #288 (permalink)
fc187's Avatar
Member # 1525
1/2" UHMW on today.......
NCRD
Old 03-18-2011, 09:19 PM   #289 (permalink)
ROCK HUGGER's Avatar
Member # 4329
Don your work is amazing as always!! Is it going to be at the swap meet? I'd like see it in person.
ROCK HUGGER is offline   Reply With Quote
Old 03-21-2011, 07:20 PM   #290 (permalink)
fc187's Avatar
Member # 1525
Thanks!
prolly wont have it at the sweap meet.
NCRD
Old 03-27-2011, 04:54 PM   #291 (permalink)
Member # 183133
Uhmw
Just looked up UHMW, that is an awesome idea. How well does it hold up to heavy trail abuse? Also, would 60 springs up front have given you more flexability?
SixPax is offline   Reply With Quote
Old 03-27-2011, 07:03 PM   #292 (permalink)
fc187's Avatar
Member # 1525
it will smash at the edges and gouge eveywhere else. BUT! it will glide over rocks
fj60 sprigs would provide more flex, but would not have as good of an approach angle. with the OME 40 springs, you still have a decent size bushing and with the spring flipped and the axle pushed forward another inch,... we have a bitchen approach with 42's AND plenty of flex
NCRD
Old 03-28-2011, 09:04 AM   #293 (permalink)
Member # 124127
Would you use 40 springs or 60 springs in the front with 37's? Are you using 40 springs because of the larger tire (42's)? I allways thought you were better off using a 60 spring in front IF you could?
Old 03-31-2011, 06:21 PM   #294 (permalink)
rockthedog's Avatar
Member # 19510
i might have missed it don so sorry if i did..... you have OME 40 springs are they stock? or lift? they looked pretyy flat the way i like them .... the stock 40 spring bushings are so small i burn out a set of them after one trip of wheelin the OME ones look the size of 60 series bushings
lookin nice as always btw
77fj40, 1 TON
www.wfoconcepts.com 530-268-9494
tlca# 12281
semi_budget 1ton build
/forum/toyota-land-cruiser/530636-semi-budget-1-ton-buildup-thread.html
linking the rear
http://www.pirate4x4.com/forum/toyot...king-rear.html
rockthedog is offline   Reply With Quote
Old 03-31-2011, 06:24 PM   #295 (permalink)
Member # 1926
Very nice work Donald. I hope you can work on my junk one of these years.
Charles
'69 FJ40 with very few stock parts.
2000 Cummins with some goodies to make it smoke.....
Trail Gear's Bad Ethics=Bad Business.
fj40charles is offline   Reply With Quote
Old 03-31-2011, 09:39 PM   #296 (permalink)
fc187's Avatar
Member # 1525
IMHO....
the advantages of 60 springs, long n flexy with big bushings....
the disadvantage of 60 springs, Longer than 40's...
the advantages of 40 springs, the short side makes for bitchen aproach angle when flipped.
the disadvantage of 40 springs,.... tiny bushings self destruct after a GOOD run.
late 40 springs or aftermarket springs/lift springs will usually have a larger bushing and still give you the better approach when you flip them.
when forced to side between flex and approach,.... I will pick approach every day! quality over quanity!
good eye! they are older OME's. they have a slight positive arch, but they do sit nice AND have a good size bushing.
and Thank you!
Charles
send that thing out here chuck!
NCRD
Old 04-02-2011, 02:34 PM   #297 (permalink)
Member # 14670
This rig is the shiznits
Rad build Don.....
Ride it like you stole it.
Radd Cruisers is offline   Reply With Quote
Old 04-03-2011, 07:37 AM   #298 (permalink)
Member # 105834
Thanks for the tour yesterday Don. That buggy looks even better in person.
war pony build
http://www.pirate4x4.com/forum/showthread.php?t=651553
Old 04-03-2011, 08:10 PM   #299 (permalink)
Member # 147864
it looks really good FC looks like it could be my big brother
nocal40 is offline   Reply With Quote
Old 04-03-2011, 11:04 PM   #300 (permalink)
Member # 121345
Do you have something in mind for the lower link cross member? Is it going to tie into a full belly skid plate?
77 FJ40
97 4runner
