FJ40 braking issues - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-20-2002, 03:50 PM   #1 (permalink)
Member # 3760
FJ40 braking issues
I have a soa fj on Bj60 axles. My problem is that the rear locks right up and the front keeps rolling. I have a 100% new brake system (components, lines etc.) What can I do to fix this. Its pretty scary when I hit the brakes and the truck starts sliding
thanks Dan
83 BJ60 DD,74 FJ40 crawler
Be Canadian, Eat beaver!!
crawlin cruiser is offline   Reply With Quote
Old 11-20-2002, 04:00 PM   #2 (permalink)
Old Rock Doc
Medusa's Avatar
Member # 915
Add a proportioning valve to the rear brake line. Get an adjustable Wilwood model. This allows you to adjust the rear brakes so they do not lock up before the fronts.
Got Rice?
Medusa is offline   Reply With Quote
Old 11-20-2002, 05:29 PM   #3 (permalink)
cruiseroutfit's Avatar
Member # 1858
Or use a late 75' or early 76' master cylinder. I run 60 F&R on my 40 with a late 75' master and it works great. We have use this master cylinder on many conversions in the shop.
Kurt Williams
Cruiser Outfitters - YOUR CRUISER PARTS SOURCE! - ARB - OME - Engel - Helton - AdvAdapt
ExpeditionUtah.com
U4WDA - Member
TLCA #10662
Wasatch Cruisers #028
Mountain Yoats
Red Rock 4 Wheelers #789
Mojave Underground
kurt@cruiseroutfitters.com
cruiseroutfit is offline   Reply With Quote
Old 11-20-2002, 07:08 PM   #4 (permalink)
Big DW's Avatar
Member # 9950
Angry Wilwood Valve-----WIL-260-2220
What Medusa said...go to Summitracing.com and put in this part number.....WIL-260-2220.....$39.99, it worked great for me...
[SIZE="4"][COLOR="Blue"]Operator, Quick...give me the number for 911!!![/COLOR][/SIZE]
Big DW is offline   Reply With Quote
Old 11-21-2002, 12:48 AM   #5 (permalink)
Member # 3760
does an aftermarket propotioning valve make any difference to pedel hight?
BTw I have a master from a 79
Old 11-21-2002, 09:57 AM   #6 (permalink)
Member # 12758
You should be fine with the '79, in that case if you have the adjustable is won't matter except how you tune it.
dieselcruiserhead is offline   Reply With Quote
Old 11-21-2002, 10:52 AM   #7 (permalink)
Member # 1858
Nope, but your pedal height is still adjustable under the dash or by using the slave cylinder, but you must be careful either way not to overextend....otherwise it blows the slave apart.
Kurt Williams
ExpeditionUtah.com
U4WDA - Member
TLCA #10662
Mountain Yoats
Mojave Underground
