Way too slow FJ40 build - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-10-2012, 07:12 AM   #51 (permalink)
Dave G.'s Avatar
Member # 211768
Originally Posted by Arya Ebrahimi View Post
I'm no suspension expert, but I was always told you should do a wishbone with the bolt running through the heim in a vertical orientation. The way you have it now is going to sideload the hell out of that heim and wear it out/blow it out much faster than if it were turned 90*.
If you look at the first page, post #10, you can see I originally had it that way. However, I needed the heim to come down some, and couldn't find a good way to tie it all into the axle bridge, so I changed it. Building these things is all about compromise, and when I look at my Ultra4 car that has had the same setup for 3 years, I decided that this thing will never be driven that hard so it shouldn't be an issue. This is a rockcrawler/street rig.
You'd be surprised the amount of desert racers that still run the bolt horizontally, so I don't think it's as huge a deal as people make it out to be. That all being said, you won't catch any racers that I build now with the bolt this way.
Dave Gutwillig
BRAVE Motorsports - For all your offroad and fabrication needs in Houston, Tx
713-896-8559
Dave G. is offline   Reply With Quote Quick reply to this message
Old 06-10-2012, 09:13 AM   #52 (permalink)
Wilson's Avatar
Member # 7233
Thanks, I've been envisioning trailing arms on mine for the same reason. I've only seen one other 40 that way and it was the yellow samco one. I've seen quite a few wishbone/ trailing arm setups, wasn't sure if there was another reason for it or not.
Wilson is online now   Reply With Quote Quick reply to this message
Old 06-10-2012, 09:53 AM   #53 (permalink)
Member # 7876
Send a message via AIM to Arya Ebrahimi
Got it. Not that you should/would go back and change it now, but what about welding a nut to the inside of the truss so that the heim could sit all the way down on top of the truss? You could accomplish the same thing now(with the truss welded on) by welding the nut to a piece of plate and the cutting out a hole in the top of the truss for the nut to recess into and then weld the plate to the truss.
Anyway, I'll stop critiqueing something I have no actual experience with.
'15 F250 Powerstroke
'73 FJ40 Tons, 40s, etc.
'88 FJ62, 100% stock
'94 FZJ80 LS swap in progress
Arya Ebrahimi is offline   Reply With Quote Quick reply to this message
Old 06-10-2012, 10:39 AM   #54 (permalink)
Member # 12567
Send a message via AIM to ChevotaSS
i was going to do trailing arms. but to clear the rear frame with the shocks i would have had to move the frame mount so far out i didnt like it. would be a boulder hanger.
everyone else is crying over what michigan has been dealing with for 6 years.
ChevotaSS is offline   Reply With Quote Quick reply to this message
Old 06-10-2012, 04:09 PM   #55 (permalink)
Dave G.'s Avatar
Member # 211768
Yep, this was a huge issue to me. I always like to build a bridge between my link mounts that hang down, this one was a little tougher since it's outside the frame. I'll get a side view picture of what I did, but you can sort of see it in the pic of the belly skeleton.
Dave Gutwillig
713-896-8559
Old 06-10-2012, 04:11 PM   #56 (permalink)
Dave G.'s Avatar
Member # 211768
I definitely could have done that, especially since the heim is a little forward of the truss now than in the original pictures. If there is ever a problem, I may do that, but at this point I have to get this thing done.
Dave Gutwillig
713-896-8559
Old 07-12-2012, 12:04 PM   #57 (permalink)
Dave G.'s Avatar
Member # 211768
She fired up for the first time last week!
Pics of the fuel tank all finished up. Not sure how many gallons it holds yet.
Also, I got the new rockers done today. They also serve as the main body mount, as well as having the A and B pillars of the cage tied to them. I'll get better pics of how it all ties to the frame once I can get a hold of the wife's camera.
Dave Gutwillig
713-896-8559
Old 07-14-2012, 10:13 PM   #58 (permalink)
swilson's Avatar
Member # 143
Nice fab work!
Scott Wilson - Member #143 - TLCA #5261
1966 FJ40 - SOLD -
1988 4Runner v2.0 -
swilson is offline   Reply With Quote Quick reply to this message
Old 07-15-2012, 12:06 AM   #59 (permalink)
NORCALFJ40's Avatar
Member # 51625
Looks awesome!
NORCALFJ40 is offline   Reply With Quote Quick reply to this message
Old 08-21-2012, 01:30 PM   #60 (permalink)
Dave G.'s Avatar
Member # 211768
Working on some upper steering arms today
Dave Gutwillig
713-896-8559
Old 08-21-2012, 03:07 PM   #61 (permalink)
Member # 160119
after looking at your quality of work i think im going to give up fabbing and wheeling and try something else. perhaps needle point or maybe i could just join a book club. you have set the bar very high sir-keep up the good work! or ease up a little so my rig doesnt look so bad
77WarPig is offline   Reply With Quote Quick reply to this message
Old 08-21-2012, 08:07 PM   #62 (permalink)
Member # 29
This is exactly what I am thinning of for mine. Can you get me some better pics of how you set this up?
Thanks
DIma
FJ40 crawler, 2006 F250 for tow duties
Flatty is offline   Reply With Quote Quick reply to this message
Old 08-22-2012, 08:13 AM   #63 (permalink)
Dave G.'s Avatar
Member # 211768
Thank you!
Thanks
DIma
Sure, here's how the rocker looks now, with the new step:
View from the bottom:
Dave Gutwillig
713-896-8559
Old 08-25-2012, 08:49 PM   #64 (permalink)
Member # 2619
Send a message via ICQ to DCruiser138 Send a message via AIM to DCruiser138
my thoughts EXACTLY!!! that shit is CLEAN. i love the stock stylings kept throughout
Dustin Crawford ---
OPEN DIFF DEUSH'
DCruiser138 is offline   Reply With Quote Quick reply to this message
Old 08-25-2012, 08:55 PM   #65 (permalink)
Moderator
RustyNailJustin's Avatar
Member # 8568
Great work man looks awesome!
KOH 2009 Team 435
KOH 2010, 2011,2012,2013,2014, 2015 Team 4431
EMC 4619 2014,2015,2016
TLCA# 5305
RustyNailJustin is offline   Reply With Quote Quick reply to this message
Old 08-25-2012, 09:08 PM   #66 (permalink)
Member # 20907
Love those steps!
2012 FJ Cruiser, 1984 BJ42 "Middy" Landcruiser, 1977 HJ45 Landcruiser, 1966 FJ45V Landcruiser
twisty_toy94 is offline   Reply With Quote Quick reply to this message
Old 08-27-2012, 10:40 AM   #67 (permalink)
Dave G.'s Avatar
Member # 211768
Got the cage back from powdercoat, time to put it all back together.
Dave Gutwillig
713-896-8559
Old 08-28-2012, 08:10 AM   #68 (permalink)
Dave G.'s Avatar
Member # 211768
Fuel tank is in. Holds about 27 gallons.
Put her on the scales to get some new springs coming. She was about 800#s less than I thought @ 4235 empty, with 50.1% side to side ratio, and 50.3% front to rear.
Dave Gutwillig
713-896-8559
Old 08-28-2012, 08:26 AM   #69 (permalink)
Member # 3886
did you do all the machine work here?
i really like your arms, looks smokin. how much for those bearing caps?
hold this...
gnob is offline   Reply With Quote Quick reply to this message
Old 08-28-2012, 09:28 AM   #70 (permalink)
Member # 160119
i would have thought less weight also, youve taken alot of heavy crap off of there. i weighed in at 3880 fully loaded ready to wheel with a full tank of gas...and i just shaved a bunch more weight off so ill be reweighing soon
Old 08-28-2012, 09:57 AM   #71 (permalink)
Dave G.'s Avatar
Member # 211768
[QUOTE=gnob;14732331]did you do all the machine work here?
No the owner of the Cruiser owns a machine shop, so he built those. Trying to get him to get me a price on them though.
Dave Gutwillig
713-896-8559
Old 08-28-2012, 09:59 AM   #72 (permalink)
Dave G.'s Avatar
Member # 211768
I guess I have no idea what FJ40s weigh. I'm used to 1-ton Jeeps that usually weigh in around 4500, I figured this thing would be way heavier than that.
Dave Gutwillig
713-896-8559
Old 08-28-2012, 04:24 PM   #73 (permalink)
Member # 85813
Does that tank hang below the frame at all? I really like that idea for the gas tank. Any reinforcement inside to handle the seat?
E WHEELER is offline   Reply With Quote Quick reply to this message
Old 08-31-2012, 05:54 AM   #74 (permalink)
Dave G.'s Avatar
Member # 211768
Yes it hangs down 5" at its lowest point, but slopes from the rear bumper height. No reinforcement plates inside, the tabs are close enough to the seams where I didn't feel the need, plus most of the tank is built from 3/16" plate.
Also included a pic where you see the fuel pre-filter and pump. It tucks nicely next to the back of the diff, we'll have to change it though if he ever goes to a centered diff.
Dave Gutwillig
713-896-8559
Old 09-01-2012, 06:10 PM   #75 (permalink)
Member # 12567
what fuel pump and filter are you using?
