Member # 10478
getting head machined, how much resurfacing?
How much should I get shaved on the head? 50,000, 80,000? The head has warped and it needs a initial resurface, but while at it, I may as well get more taken off to increase the compression ratio. Any input would be great.
Shaun
1997 TJ, 4" stage 2 procomp, 33's, xd9000i. |
Member # 1282
The machinest will determine how much to shave off to get the head surface true. As a standard practice check your block deck also. Won't do any good bolting down a resurfaced head onto a warped block....
Member # 10478
The machine shop has determined that 6-7000 must be removed to true the head. I've been told that the stock head can have 75,000 removed to increase compression. I don't want to remove that much material unless I know it will be ok, and not open up the water jacket holes to much.
Shaun
Member # 1858
I had mine shaved 40k-50k to up the compression a little bit. I can't say I've ever heard of anyone going much higher than that but I'm sure its been done...
Kurt Williams Cruiser Outfitters - YOUR CRUISER PARTS SOURCE! - ARB - OME - Engel - Helton - AdvAdapt ExpeditionUtah.com U4WDA - Member TLCA #10662 Wasatch Cruisers #028 Mountain Yoats Red Rock 4 Wheelers #789 Mojave Underground kurt@cruiseroutfitters.com |
