Land Cruiser sincros? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-30-2002, 08:39 PM   #1 (permalink)
Member # 5436
Can anyone tell me how to adjust the sincros on a '79 BJ40 4 speed? My dad's cruiser is grinding when he goes into reverse and sometimes in 1st. He changed the clutch slave and checked the clutch and it it seems fine but its still grinding. Any ideas?
YOU are paranoid.
monzter is offline   Reply With Quote
Old 11-30-2002, 08:50 PM   #2 (permalink)
Member # 3942
If they're worn, then there's no adjustment, they'll need replacing. Bring some $$$, they're not cheap!
60seriesguy is offline   Reply With Quote
Old 11-30-2002, 09:56 PM   #3 (permalink)
Member # 4783
Reverse is non-synchro. If it grinds going to gear when the truck is stopped, the clutch is dragging and needs adjustment. Lengthen the adjustment rod until it stops dragging. It may need bleeding if you replaced the slave cylinder.
Pin Head is offline   Reply With Quote
