Member # 127650
As far as case strength, I got my tacoma hung up on a 8" diameter stump that was in the middle of some soupy ruts. With some harsh 2' back and forth each way I used the transfer case to rip the stump out of the ground. The little sheetmetal plate on the bottom of it is perfectly contoured to the aluminum underneath now.
Member # 187391
on the first gen tundra and sequoia and the v8 4runner, it uses a similar chain drive with over 340lb of torque stock. if i recall right, when trd made supercharger for the tundra/sequoia the transfer case was not the problem, the weak link was the rear diff.
#12 (permalink) |
I can take a picture of a stock 23 spline taco input compared to a stock 21 spline gear case input when get home. You can see just how much shorter it is.
Old truck [url]http://www.pirate4x4.com/forum/showthread.php?t=566730[/url] [QUOTE=Sillyneck;7839776] If it's not playboy and BTF it's not good enough :D[/QUOTE] |
#14 (permalink) |
Nevermind, can't get the coupler off the stock taco case. The other case I had slid right off but not this one.
#16 (permalink) |
I'm not sure how close the t-case input and the tranny output are to each other.
#18 (permalink) |
Mating surface of the Tacoma case to the rear flange is 12 1/2 inches. Gear case is roughly 12 3/4 inches, hard to measure Callens cases accurately with his crossmember onthe way.
#21 (permalink) |
Member # 210693
No standard Tacoma case but this is from a 2000 limited 4Runner with a 3.4L.
Mounting surface to rear output flange is 15 5/8" The input is 4 1/16" from mounting surface to front of input. If I remember correctly the 4cil input is around 2 5/8" from mounting surface to front of input. Last edited by GreaseMonkeyGarage; 05-01-2012 at 09:13 PM. |
#24 (permalink) |
Member # 201841
heres a little vid. http://youtu.be/pg-MmIcd0-g. it started as a 59 fiat now has a new life as a wheeler. i should do a build up soon.
#25 (permalink) |
Member # 156460
Been workinq
I have a stock 3.4 auto duels stock gear case stock chain driven case my truck weighs 5800lbs tubed from front to back 60 70 42"s h1 wheels and a fifth spare I have had good luck with it I don't beat my truck but I do have fun thou.....
