Midcoma's 4WU 3link w/ Diamonds - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-13-2017, 11:23 AM   #76 (permalink)
Member # 155299
While I had easy access, I decided to replace the fuel filter. Hopefully all this cleaning and filter change will result in a better running engine.
Some pictures of the throttle body after cleaning, powdercoating and re-assembly.
I also cleaned up the IAC valve before reinstalling.
I finally got all the right shims to get my valve clearances in spec, so I was able to get the valve cover reinstalled. Anything that was removed was reinstalled with new OEM seals and gaskets. I think my order from Camelback Toyota was 48 items. Took forever to get everything, but once it was here it was just a matter of printing out torque specs and getting to work. Here's a few progress shots of getting everything back on the engine.
That's where it sits for now. Still needs more parts, time and money before it's complete. Radiator should be here tomorrow, so that will be a big step. Still need to finish up the transfer case crossmember. Now it's pretty much down to all the little annoying things that keep adding up and nickel & diming my wallet.
midcoma is offline   Reply With Quote Quick reply to this message
Old 04-29-2017, 07:38 PM   #77 (permalink)
Member # 155299
There may be some interest in this post, so I'll go ahead and add details.
I was sick of breaking plastic radiators so I decided to get an aluminum one. Well, aluminum radiators for the Tacoma are pretty difficult to come by. I found two sources, "myautopartswholesale" on ebay and Radiator Express.
Myautopartswholesale had the radiator listed for around $190. Radiator Express had it listed for $290. After making a few calls, I was pretty sure they were the same part, so I ordered one from ebay and it came out to $196.76 total including shipping. Well a few hours later I got an email saying they had to cancel my order because the radiators were out of stock. So I called Radiator Express and sucked it up and spent $100 more. About two hours after placing that order I got a call saying they were also out of stock. So that helped confirm my suspicion that the radiators were the same part. I don't know if the two companies are the same, but I'm fairly confident they pull from the same stock. The web page has been updated, but Radiator express had the MSRP at $190, with a sale price of $290. I asked the sales associate why the radiator costs more than the MSRP and the response I got was "these radiators are so rare that they sell for more than MSRP". So I cancelled the order, but ended up calling a couple weeks later and placing a backorder for the radiator. Radiator Express was good about letting me know when a new shipment was coming in and their dates ended up being accurate. I received the radiator about 6 weeks after placing the original order. Price was $305 after shipping. It turns out that it is the same brand myautopartswholesale was selling for $100 less. So if you can find it on ebay I'd go that route. If you know you want one and you're willing to pay more and wait, Radiator Express had good customer service and you can place it on backorder to ensure you get one.
Here's a link to the radiator: Aluminum Tacoma Radiator
It's a 18.5" core with a transmission cooler.
Here's a few pictures.
It comes with aluminum mounting brackets welded on.
A few close ups. Welds are ok. Some are better than others.
Old 04-29-2017, 07:51 PM   #78 (permalink)
Member # 155299
The overall fit of the radiator was surprisingly good. It did have a slight twist to it, but bolting to the core support pulled it flat. I had to oblong one of the core support holes about 1/8" to get a bolt to line up, but that may be from my truck hitting rocks. The nuts welded to the brackets are the correct thread for factory hardware.
I had to make a few modifications for it to fit my application. I ordered a new shroud for the smaller radiator from Rock Auto. The shroud had to be notched slightly for the lower hose mount.
And I had to cut off the lower driver side shroud nut to get the radiator to clear my steering box.
I drilled 2 holes in the shroud and bracket so I could use zip ties to secure this corner.
Overall shroud fit.
Installed pictures. I still need to get the shorter lower hose.
Fan fits perfectly.
Just clears the front steering box bolt.
Old 04-29-2017, 07:52 PM   #79 (permalink)
Member # 155299
And it sits above the frame rails.
Old 04-29-2017, 08:05 PM   #80 (permalink)
Member # 155299
I finished my crossmember. Decided to add a couple vertical gussets on the sides. And the bracket on the driver side is to support the factory gask tank skid. I wish some of the welds would have turned out nicer, but they'll hold.
Installed.
I need to lower it one more time to adjust my shifters, but I'm pretty happy with how it turned out.
Old 04-29-2017, 08:35 PM   #81 (permalink)
Member # 155299
A few other little updates.
I got the front brake lines installed. I decided to order custom lines from Spiegler Performance. They mostly do motorcycle brake lines, but they'll make them for anything they have fitting for. They have quite a list of fittings to choose from. They also have a nice selection of line colors. I got rear lines from them too, but they aren't installed yet. All the fittings are stainless steel, including the banjo bolt. I went with a 20⁰ offset banjo fitting to keep the line out of the tire and a standard female m10x1.00 inverted flare at the frame end. I had them add a tab to the line because I intend to run a spring or bungee cord from the line to the frame to keep the line under control at ride height.
I also finally got my reservoirs mounted. I made a rookie mistake when trying to mount them and let one of the fittings on the hose come loose. Didn't notice until a bunch of shock fluid had already leaked out. So I had to pull the coilovers again and take them to my shock guy so he could adjust the fluid level and recharge with nitrogen. But they're all good now.
I used 316 stainless steel worm clamps. The clamp was cut for minimal excess and I also wrapped most of it with heat shrink to protect the reservoir. I also put two wraps of electrical tape under the clamps for protection.
Passenger side.
Driver side is a bit tighter.
I've been waiting for a few parts to finish rebuilding my starter, but they finally arrived. I had it powdercoated along with the other batch of parts. I like how it turned out. Removed the coating from under the necessary bolts to ensure a ground connection. Had it bench tested at the parts store prior to install to make sure everything was good.
And then just an overall shot of how the engine is coming together.
Old 05-01-2017, 12:12 PM   #82 (permalink)
Member # 103621
Very nice attention to detail.
1982 Toyota - Dirt Squirrel - LQ4/Atlas 4.3, D60/14b w/ Reids & RCVs, 3-link/4-link, 43" stickies
the_white_shadow is offline   Reply With Quote Quick reply to this message
Old 05-17-2017, 09:46 PM   #83 (permalink)
Member # 155299
Got some wiring done. I previously ran a Dakota Digital SGI-5C to correct my speedometer error. I didn't know so much about wiring when I installed it, so it wasn't as clean as it could have been. I decided to go with a different unit this time and wire it better. I chose the SpeedoHealer V4 from HealTech Electronics this time. I went with the SH-V4-AB model because it includes a switch to easily change between 2 settings. I use a smaller tire on the street than I do when off road and I like to have the speedometer calibrated for each tire. With this unit, I can set two separate settings and easily change between them by flipping the switch. I used the SH-U01 wiring harness and purchased it all from Blue Monkey Motorsports. It can be found under the Yamaha tab.
These are the gauge cluster plugs on my truck.
All the connections were soldered and covered with heat shrink.
I soldered the wires to the bottom of the factory pins. These are the positive and ground wires.
Plugged back into the connector.
Finished wiring.
I ran the cable to the left of the gauge cluster and behind the left air vent, then down to the fuse panel. This is the cable management in that area.
I put the switch for the different settings on the dash near the dimmer knob. This is the location from the back of the dash.
And the front.
And this is how it will be accessed for adjustments. The cable gets coiled and stored behind the fuse panel access when not needed.
Old 05-17-2017, 10:04 PM   #84 (permalink)
Member # 155299
The rear shocks and brakes are installed.
Here's the frame to axle line.
Used a high pressure (3,200psi) 1/8" NPT elbow at the proportioning valve.
And the lower fitting has a 20⁰ bend to get the line more vertical.
Overall junction.
In this picture you can see the left fitting is straight and the right fitting has a 45⁰ bend.
I can't speak enough to how awesome these lines are. When I was ordering I asked it they had any chafe guards and they said they could add Norprene tubing and heat shrink, I just had to tell them where to put it. I didn't know where it had to go, so I told them how long I needed it to be and asked if they could leave the heat shrink un-heated so I could move it. The lines arrived exactly how I asked. I was able to set the chafe guard where I wanted it, then shrink the tube.
The caliper lines have 90⁰ banjo fittings. Again, all the metal fittings, including the banjo bolt, are stainless steel.
And the FROR Drotor brake kit just barely clears my 15" wheels.
Overall view.
Old 05-17-2017, 10:12 PM   #85 (permalink)
Member # 155299
I run a triple stick from RADesigns and made a custom bracket for the shifters a couple years ago. I wanted all the shifters to be in the forward position when in the high/2WD range. The truck is a daily driver so I wanted everything out of the way as much as possible while on the road. Combining this with the URD short shifter for the W59 and it's a pretty compact shifting setup.
This is the assembled shifter bracket.
Overall view.
And with the boots installed.
Old 05-18-2017, 08:43 PM   #86 (permalink)
Member # 18433
Badass! I wish i had your level of attention to detail! Im curious to see how that crossmember works out, i want to ditch my fail gear crossmember and your design is peaking my intrest.
2002 Tacoma, duals, flipped fj60 front axle, fj80 rear axle, 37s, not cool enough for links.
Gslander is offline   Reply With Quote Quick reply to this message
Old 05-21-2017, 05:17 PM   #87 (permalink)
Member # 284930
Thanks for the detail Midcoma. I have been following the build on TTORA and Pirate. It's been a help, especially on the 4 wheelunderground shock tower install. I am in process of a 1990, 4 wheelunderground 3 link with diamond axle.
A lot of the information transfers over from the Tacoma to the older models.
Will be watching for updates...
YotaXTP is offline   Reply With Quote Quick reply to this message
