2002 - 2010 Tacomas - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-22-2017, 08:12 AM   #1 (permalink)
Member # 33801
2002 - 2010 Tacomas
Looking at buying a used one. I have never owned one so have no clue.
Are there any years or models to avoid?
What are the known weak spots to be checking on these?
TIA
Hippie666 is online now   Reply With Quote Quick reply to this message
Old 05-22-2017, 01:18 PM   #2 (permalink)
Member # 103621
First would be to figure out what body style you want. If youre wanting a double cab, they first ones start at 01-04, then got a redesign in 2005-15. Engines in the 01-01 are the 3.4l v6 and 3rz. 3rz (4cyl) carried over in the 05+, but the v6 went to a 4.0l.
I like the look of the 01-04 stuff, but thats personal opinion. Frames are prone to rusting out (there was a recall on them) and are pretty weak up front, so be prepared to plate them if solid axle swapping. Some cut it out completely at the body mount and rebuild it with rectangular tube.
Prices are still holding strong for them in my area. $5k minimum for a high mileage DC, and close to $10k for a nicer one.
1982 Toyota - Dirt Squirrel - LQ4/Atlas 4.3, D60/14b w/ Reids & RCVs, 3-link/4-link, 43" stickies
the_white_shadow is offline   Reply With Quote Quick reply to this message
Old 05-22-2017, 01:24 PM   #3 (permalink)
Member # 33801
Body style does not matter. Thanks for the info on the frame, since I am in a very rust prone area I will look closely at that.
Are the 4 cylinders under powered? Any problems with auto tranny?
I will not be swapping axles or anything under it, it will just be a daily driver.
Old 05-22-2017, 02:01 PM   #4 (permalink)
Member # 103621
a 4cyl with a manual trans would be what would look for if i was going with a 4banger. As for the 3.4l with an auto, I had one and it was pretty good as a DD. Had 170k on it before i traded it in on a new Tundra. Wish I would have kept it. I wouldnt hesitate buying one. If getting a 3.4l check and make sure they are up to date on the timing belt maintenance. Should be done every 80-90k. Water pump at the same time since its in the way when doing the work.
Old 05-22-2017, 07:50 PM   #5 (permalink)
Member # 33801
Good to know on the 4 banger.
Old 05-23-2017, 06:16 AM   #6 (permalink)
Member # 33801
I am seeing info that indicates the 05-06 have head gasket issues. Anyone have any knowledge on that?
Old 05-23-2017, 07:50 AM   #7 (permalink)
Member # 103621
Which engine? My pops has the 2.7l in his '05 with 238k miles on it and hasnt even changed the brake pads/clutch/etc. Only oil changes every 3k and tires and it runs like a top.
Old 05-23-2017, 11:28 AM   #8 (permalink)
Member # 33801
4.0
Old 05-23-2017, 11:54 AM   #9 (permalink)
Member # 143737
I had a 04 single cab short bed 2.7 5 speed 4x4 SR5 that a regret trading in. I put 60k on it in 2 years, oil changes and tires were the only maintenance, got 25 mpg and would chirp 2nd with 31s. Was an excellent truck 2.7 had plenty of power, though it had 4.30 gears or something.
POS Ranger on narrow 3/4 tons with a 357w noise maker
posford is offline   Reply With Quote Quick reply to this message
Old 05-23-2017, 12:10 PM   #10 (permalink)
YotaAtieToo's Avatar
Member # 25632
Those prices are cheap compared to out here!
YotaAtieToo is online now   Reply With Quote Quick reply to this message
Old 05-23-2017, 06:22 PM   #11 (permalink)
Member # 33801
I have seen an 02 for $9.3k and I have seen 2010s for low 10k's. Here the price is mainly driven by the condition of the vehicle, the year and mileage don't have much effect.
Old 05-24-2017, 08:35 AM   #12 (permalink)
drr
Member # 712202
If you're in the rust belt, you will want to be very thorough with inspecting the frame of a 1st gen (95 - 04). They especially tend to rust through around the leaf spring hanger and crossmembers, take a hammer and rap on those areas to see if they're rusting from the inside out.
There was a frame recall, if the previous owner had the undercoating done by toyota during the recall period, it might still be eligible for a new frame. Run the VIN past a dealership to see if there is any record of it.
drr is offline   Reply With Quote Quick reply to this message
Old 05-24-2017, 01:51 PM   #13 (permalink)
Member # 156657
And frames on the 05' and up especially if they were under coated by a toyota dealer . Some of them wI'll undercoat right over dirt,sand ,and salt . It makes them rust faster .
cryptic toy is offline   Reply With Quote Quick reply to this message
Old 05-31-2017, 12:28 PM   #14 (permalink)
Member # 703953
I don't sweat buying a used one that didnt' have records of the timing belt being replaced. I've owned 5 3.4L trucks and 4runners, all with over 200K (2 w/ 300K) miles. They usually need spark plugs and the valve cover gasket bolts tightened up. And radiators. Had to put radiators in 3 of them (swapped to short 4cyl radiators then also)
eat.sleep.wheel is offline   Reply With Quote Quick reply to this message
Old 05-31-2017, 12:33 PM   #15 (permalink)
Member # 103621
The 3.4l i used to drive skipped a tooth on the timing belt once. Thats why i make sure i know when they have been changed. Its about the only maintenance item i care about.
Old 05-31-2017, 12:42 PM   #16 (permalink)
Member # 703953
hmm
wonder what made that happen? maybe the tensioner failed?
either way, the 3.4 is a decent engine that is not problem prone
YMMV
Old 05-31-2017, 12:49 PM   #17 (permalink)
Member # 103621
hmm
YMMV
No clue. It was my DD in college. 2wd prerunner that only saw the highway. I agree that its a nice engine. Just want to make sure its done because its a pain in the ass job to do.
Old 06-19-2017, 11:05 AM   #18 (permalink)
75cruisin's Avatar
Member # 39366
No info other than I have an 01 4 door 4wd that I have had for 8+ years. Put 80k on it and has over 214xxx. Still gets 20 mpg on the freeway. Just replaced rad about a month ago. Everything in good working order. I wouldn't get rid of this truck for anything.
[QUOTE=Dieselmh;27768049]I don't know either, but dammit, this is the internet. And as an internet user, it's my job to jump to conclusions and get angry about things that don't personally affect me in any way, shape of form, so fuck you! :flipoff2:[/QUOTE]
75cruisin is offline   Reply With Quote Quick reply to this message
Old 06-19-2017, 05:29 PM   #19 (permalink)
Member # 166413
I have 445k on my 3.4 auto (96 4runner). Regular maintenance... I haven't done anything besides the usual; spark plugs/wires, alternator, battery, starter (four times...just get a decent one non-vatozone), valve cover gaskets, o2's, timing belt, radiator, fan clutch idler, water pump, etc. regular dumb shit. Put a 44/9 under it 5 years ago, currently putting a 60/14 with 42's under it now, and a supercharger... We'll see how much longer it will last before i swap in another 3.4.
Friend has an 06 taco 4.0 with over 250k no issues, regular maintenance.
Just find one with a good carfax and give it a tune up.
A340F's are hit or miss....usually fine...like i said, mine has 445k on it, but the gf bought an 01 dc taco 3.4 auto last summer that was immaculate with 190k miles and the torque converter went out two weeks later and friction welded itself to the housing, cost me $4k for a reman with oil pump, installed, 3yr warranty. Otherwise if you have problems find a craigslist A340F preferably scrapped from a new build for $300.
Sent from my Pixel XL using Tapatalk
downpour11 is offline   Reply With Quote Quick reply to this message
Old Yesterday, 09:35 AM   #20 (permalink)
Member # 2682
Wow you could make a living driving them to the DC Metro area and flipping them. If people are actually getting anywhere close to there asking price I have no idea but on craigslist a 2nd gen double cab v6 4x4 is typically 15k minimum and if your lucky the clock is at 100k but its usually more like 200k and the same specs but 1st gen are not much less
Ztec is offline   Reply With Quote Quick reply to this message
