97 tacoma build up - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-26-2006, 06:12 PM   #1 (permalink)
Member # 72362
97 tacoma build up
Just wanted to say thanks to the pirate for all the ideas and inspiration on this build. The truck is a 97 tacoma, started as a 2wd 2.4l. Project is under way and theres no turning back now. Specs:
toyota front axle with long 30 spline axles and inner hubs,new hi pinion e locker front diff, arp knuckle studs and hub studs and billet hi steer arms from Fror. knuckle rebuild kits also from Fror. Front brakes are ifs.
2nd gen rear axle, v6 diff, gonna send ring pinion out for cryo treatment 5.29 gears, rear disk brakes.
W-56 trans bolted to W-59 bellhousing, marlin crawl box with bobby long 4340 output shaft for rear t-case. staying with stock 2.28 gears in both for now, will see about gears from marlin for rear t-case if needed.
Just finished rebuilding the motor,had to get a new head as the old one was cracked.New injectors, alternator and starter, new everything on the motor, new larger 2 core radiator with dual electric fans.
4- link rear and 3 link front with 2 5/8 rebuildable flex joints from Ballistic Fab for one end and Poly Performance bushings one the other end.
ifs gear box and fj-80 tie rod ends.
14" saw coil-overs 2.5" dia.
37" Iroks
warn 8000 winch
co2 tank
3/8 t-case mount plate from Inch-Wormgear
many more goodies as well.
Right now its a frame and stripped cab, just waiting on second t-case so i can set motor/trans in and figure out links.Truck is green, will paint it silver as soon as i get body work finished. Soo much to do and not enough time in the day. If it wasn't for the PBB i dont think it would be as easy as it has been. Thanks to all the people here who have posted their pics and info. And thanks to troy at Cal Mini-Truck for all the help sourcing parts. Troy is great to deal with and killer deals.(and his 1st gen truck is sick!) Also would like to thank all the vendors on the pirate as I have purchased everything from them. I know a build up is no good without pics, i have tons of them and will get them tonight and post them. I just wanted to say the PBB is awesome for sooo much info and inspiration I got my redstar to help support this great place.(and the search function is kinda nice too!) pics coming by tomorrow. will update this as much as possible. thank you everyone here!!!!
sweet jesus, we kidnapped a turd!!
munsen is offline   Reply With Quote
Old 06-26-2006, 07:37 PM   #2 (permalink)
Grandmas Rock!
harley_sr's Avatar
Member # 12945
Well get some pics....
Originally Posted by crash View Post
I like oranges--but apples are better
Originally Posted by ROCDOC
Where are these fawking newbs coming from? Does Lance have a banner running on MySpace or something?
harley_sr is offline   Reply With Quote
Old 06-26-2006, 10:23 PM   #3 (permalink)
Member # 72362
Old 06-26-2006, 10:25 PM   #4 (permalink)
Member # 72362
:d
Old 06-26-2006, 10:26 PM   #5 (permalink)
Flexy Flatty's Avatar
Member # 17143
Really looking forward to this. Did your truck start life as a manual or auto?
Will
Flexy Flatty is offline   Reply With Quote
Old 06-26-2006, 10:28 PM   #6 (permalink)
Member # 72362
it was a 2.4l 2 wd manual w59 trans. I reused the bellhousing on a w56 trans.
Old 06-26-2006, 10:31 PM   #7 (permalink)
Member # 72362
Old 06-26-2006, 10:36 PM   #8 (permalink)
Member # 72362
hidden toolbox
Old 06-26-2006, 10:38 PM   #9 (permalink)
Member # 41848
Is the toolbox going to have a drawer on sliders? That would be
GTA3wheeler is offline   Reply With Quote
Old 06-26-2006, 10:41 PM   #10 (permalink)
Member # 72362
more pics
Old 06-26-2006, 10:43 PM   #11 (permalink)
Member # 72362
The bed will be cut out above the box and will be hinged and have a locking latch.
Old 06-26-2006, 10:51 PM   #12 (permalink)
Member # 72362
more pics
Old 06-26-2006, 11:26 PM   #13 (permalink)
Member # 72355
Since it is my truck, I might as well post some pics myself...
Munsen is the my brain behind the whole operation (also my good friend). The entire truck has developed from mostly his research here on PBB. You guys are too awesome, and the information on this site is priceless.
I'll shut up now and post some shit for you guys.
[url=http://www.pirate4x4.com/forum/showthread.php?t=485795]97 Taco SAS in progress[/url]
Caps is offline   Reply With Quote
Old 06-26-2006, 11:35 PM   #14 (permalink)
Member # 72355
Munsen hard at work.
Old 06-26-2006, 11:37 PM   #15 (permalink)
Member # 72355
Lots more pics on the way.
Old 06-27-2006, 12:03 AM   #16 (permalink)
Member # 20195
kool
83 toy, 5.29's 36" IRoks, Detroit rear, Auburn limited slip front...now with dual tcases & TDD spacers front and rear
[QUOTE=Dr.Van Falk]Seriously, once you start dying your hair you're only a boob job away from being able to do porn in Brazil.[/QUOTE]
copeland is offline   Reply With Quote
Old 06-27-2006, 02:22 AM   #17 (permalink)
Member # 72355
Under coating on fenders, engine enamel on frame.
Old 06-27-2006, 08:05 AM   #18 (permalink)
4xguy's Avatar
Member # 26533
we started at the same spot with the 2wd but you are going way deeper going to be sweet
88 4runner Clean Low Miles 300k+ SOLD
97 RUNNER IN THE WORKS [url]http://www.pirate4x4.com/forum/showthread.php?t=459214[/url]
4xguy is offline   Reply With Quote
Old 06-27-2006, 01:55 PM   #19 (permalink)
Renaud33's Avatar
Member # 23389
Send a message via AIM to Renaud33
Glad to see you recognize the wealth of information here and ponied up for the red star.
85' 4Runner - AP extreme lift, 37" PB Rockers, duals
TLCA Member# 16265
Renaud33 is offline   Reply With Quote
Old 06-27-2006, 11:02 PM   #20 (permalink)
Banned
DrVic723's Avatar
Member # 46226
Very nice clean job, should be a very interesting build. Looks like my taco (well not so much anymore... )
DrVic723 is offline   Reply With Quote
Old 06-30-2006, 03:24 AM   #21 (permalink)
Member # 72355
With the wealth of information here, I would gladly pay it again. You could never find a book for $20 that has even 1/2 the info. I'll support this site any way I can.
Plus the search function helps alot too.
Here's some more eye candy:
Thanks for the input so far. More updates coming soon.
Old 06-30-2006, 06:52 PM   #22 (permalink)
Member # 72355
Marlin Crawler t-case adapter and 2nd case showed up today. Woo Hoo!
E-locker high pinion from Inchworm also showed up today.
T-cases and tranny installed
Engine went back in today.
Thanks to Dr. Vic @ Ballistic Fab. This shit is pimp!
Dual core Radiator:
A little visual inventory.
Stereo equip. CB, KC lights, joints from Ballistic and Poly Performance.
Ballistic's rebuildable flex joints
Old 06-30-2006, 07:27 PM   #23 (permalink)
Fabster
Randy's Avatar
Member # 3069
what was done to the engine while it was apart? are you planing to put the rear sump pan on it? looking good
Thanks for the support
Currie Enterprises
PSC Steering
BFG Tires
Reid Racing
King Shocks
BTR wheels
LAT Racing Oils
Baja Designes
K&N
CBM Engines
Bulldog Winch
2013 KING
Bomber Fabrication http://www.facebook.com/pages/Bomber...4102610?v=wall
Randy is offline   Reply With Quote
Old 06-30-2006, 09:17 PM   #24 (permalink)
big ron's Avatar
Member # 71495
Five lug mini into a straight axle. That is so sweet Can't wait to see this finished. Good luck....
[URL="http://yotamasters.com/"]http://yotamasters.com/[/URL] :flipoff2:The only jeep in my family is pink and my 4 year old drives it:flipoff2:
big ron is online now   Reply With Quote
Old 06-30-2006, 10:10 PM   #25 (permalink)
Member # 72362
The motor had a warped block and a cracked head.Tha truck had too many miles on it as it was on its second motor already.We draied the radiator and it looked like gear oil.I know the owner of the local engine shop, got everything machined for next to nothing and a new head. it was a 2wd 2rz motor, I'm not sure if they ever had a rear sump pan or not. if i have to iI can either make a new oil pan and pick up or i was thinking if cutting the rail off and fliping the pan around. It looks like it would work. Guess i'll find out when the front axle goes in and clearances are checked out.Anyone know if the 3rz oilpan and pickup bolt on??
