97 Taco Coil SAS - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-27-2006, 09:19 AM   #1 (permalink)
Shenanigengineer
RockTacoAU's Avatar
Member # 33543
97 Taco Coil SAS
I am most of the way done with my SAS on my 97 tacoma. here are the specs: ford hp 44 with chevy 6 lug outers 4.88s and lockright. partmike superarms, high steer 1.5" .25 wall TR and DL with 1 ton ends. yota ifs steering box (custom shaft made of tacoma shaft plus TM 6inch extension and yota rag joint) T100 oil pan.
Here are some pics:
removing IFS crap
Jamin torching off the Ifs brckets(much better than the sawzall and cutoff)
axle sittin under it looking good
just a few inches wider than the rear
steering box plates made and installed, frame sleeved, box installed, My 5.5 EB coils mocked up
bolt in link xmember will hold up the links, will go right under the front output of tcase 2x3x.188 rectangular tubing, i took teh tranny xmember out in favor of a FROR mount.
modified PS reservoir with 3in exhaust tubing for more capacity and DL
Extreme Offroad DVDs and Apparel -
Follow us on Facebook -
RockTacoAU is offline   Reply With Quote Quick reply to this message
Old 06-27-2006, 09:21 AM   #2 (permalink)
Shenanigengineer
RockTacoAU's Avatar
Member # 33543
a little carnage from 5ft cheater bar, i hate weld in bungs I cant get my DLE to thread in far enough (anyone know any tricks for this????)
I should get it close to driveable this weekend. I have researched 3links and i believe my 2 lower links will be mounted below axle centerline and taper in to the xmember, my 3rd link mounted on the passenger side will be perpendicular to as close the center of the axle as possible sloping slightly down to the axle. any other tips???
should look similair to this with forged JJs at the frame end and polyjoints at the axle end.
I want to run 36 to 37in iroks while keeping the truck low as possible (frame to ground about 26inches)
Yall let me know what ya think.
So after getting my FROR xmember in place I figured out that my link xmember hung way to low so i modified it a lil
link xmember take two:
now it hangs down just level with the tcase skid plate (perfect)
Then i figured out the easiest way to make my steering shaft work, I did the usual double u joint into single u joint then i just used the Tacoma IFS TM shaft extension slipped it onto the tacoma shaft and it bolted right to the ragjoint on the box. It works great.
and here is what my lower link tabs for the xmember look like
I made the lower link mounts for the axle today, and worked on the link xmember somemmore.
It is all coming along slowly but surely, maybe i will have it rolling by the end of this month.
So i have been gettin a few things done, my lower coil buckets are done, got my lower joints and tabs al mocked up in place and am ready to cut links (28" long not including the joints) I got the axle all level and the truck level. I figure ill get the lower links done then make the top and all the brackets then mount the coils and lastly make the panhard and tabs.
Old 06-27-2006, 09:21 AM   #3 (permalink)
Shenanigengineer
RockTacoAU's Avatar
Member # 33543
What do yall think about my link placement. they taper out just a little from the frame to the axle. loks like i have plenty of TR/DL clearence. caster at 6* to 8*.
Must finish never ending SAS ;D
P.S. these are all my posts with pics pasted from CAOS
Matt
Old 06-27-2006, 09:26 AM   #4 (permalink)
FrankenToy's Avatar
Member # 36822
This is exactly what I was hoping someone would post up. Been thinking SAS but not wanting leaf springs. Keep the pics rollin'...
Dr Floyd: Don't suppose you have any idea what the damn thing is, huh?
FrankenToy is offline   Reply With Quote Quick reply to this message
Old 06-27-2006, 03:50 PM   #5 (permalink)
Member # 37734
Send a message via AIM to 92toy21 Send a message via Yahoo to 92toy21
Nice work man.... keep it up and lets see it done some time soon..
92toy21 is offline   Reply With Quote Quick reply to this message
Old 06-27-2006, 06:24 PM   #6 (permalink)
Member # 66914
bad ass man !!! you gonna run spacers in the rear or wheels with less back spacing ?
1984 Toyota 4x4
GA86yota is offline   Reply With Quote Quick reply to this message
Old 06-27-2006, 08:21 PM   #7 (permalink)
Shenanigengineer
RockTacoAU's Avatar
Member # 33543
i will probably run some 1.5 spacers in the rear to even everything out, I made the trac bar brackets today so everything is ready to go, I am just waiting on welding(I dont trust myself to weld suspension stuff.)
thanks for the comments I hope to have it done soon.
Matt
Old 06-27-2006, 09:58 PM   #8 (permalink)
Member # 64917
very nice there! I will be taking notes although I plan to use an FJ80 axle in my taco.Are you going to use a tower on top of the diff for the 3rd link?
swank501 is offline   Reply With Quote Quick reply to this message
Old 06-27-2006, 09:59 PM   #9 (permalink)
Member # 64917
nevermind, Ijust looked at the pics again
Old 06-28-2006, 09:15 AM   #10 (permalink)
Shenanigengineer
RockTacoAU's Avatar
Member # 33543
I made a mount that is about 8inches tall it is as close to the center of the axle as possible. I think it is better to put it there on a driver side drop axle becuase of the rotation or something?
Old 06-28-2006, 10:15 AM   #11 (permalink)
Member # 64917
Would you be able to upgrade to dual cases with that rear x-member?I can't really tell from the pics although it looks like it will have crazy flex!
Old 06-28-2006, 11:25 AM   #12 (permalink)
Shenanigengineer
RockTacoAU's Avatar
Member # 33543
I made the link xmember bolt in and it is right under the front output so i could easily move it back some If i decide to go with dual cases. I would just have to make longer links (right now they are all about 3ft long).
Matt
Old 06-28-2006, 11:45 AM   #13 (permalink)
Not a Wenzelite
MT4Runner's Avatar
Member # 44480
Nice!
There's some great tech right here with the 3" exhaust tubing to extend the PS reservoir:
MT4Runner is offline   Reply With Quote Quick reply to this message
Old 06-29-2006, 09:10 AM   #14 (permalink)
Shenanigengineer
RockTacoAU's Avatar
Member # 33543
thanks i got that idea from tacominator on TTORA it should help with cooling alot since it just about tripled the capacity and the best part is that it is easy to pour fluid in it now becuase it sits right at the top of the motor, I also plan on running a PS cooler as well.
Matt
Old 06-30-2006, 07:53 AM   #15 (permalink)
Not a Wenzelite
MT4Runner's Avatar
Member # 44480
Here's another dumb idea--now that it's got a lot of surface area, how about some cooling fins to cool even more?
Old 06-30-2006, 05:21 PM   #16 (permalink)
Shenanigengineer
RockTacoAU's Avatar
Member # 33543
I actually thought about puting some fins on it, that would be
but i will prolly just put on a cooler and be done now that i have a lifetime warranty pump from autozone anyway (they had no idea what they where gettin into )
Matt
Old 07-02-2006, 08:17 PM   #17 (permalink)
Shenanigengineer
RockTacoAU's Avatar
Member # 33543
well i am tired of the seeing the truck sittin there waiting on welding so i got a friend of mine to give me some welding tips and i started practicing on some stuff and i can already run a pretty good bead. Fawk it i guess i will just weld everything up myself, if it breaks atleast i will be the one to blame.
wish me luck
Matt
Old 07-05-2006, 06:58 PM   #18 (permalink)
Shenanigengineer
RockTacoAU's Avatar
Member # 33543
well i got the coil buckets welded up today and ran out of wire, CAs are finsihed. My welds are gettin better so i guess ill be tacking everything into place tomarow and i will post up some pics.
Matt
Old 08-20-2006, 10:27 PM   #19 (permalink)
Shenanigengineer
RockTacoAU's Avatar
Member # 33543
It drives and wheels, I finsihed it all up and everything works great, My stock driveshaft worked perfect with the HAD adapter. I ended up goin wiht some 6.5 EB coils becuase i needed more lift they are super soft. I have 13.5 RS5000s on the front with some custom shock hoops. AP front SS lines and rear 1.5" wheels spacers. I need to put my lokcrite in the front and make a hybrid leaf pack and some shcles to get rid of the block in the rear and i hsould be good to go for a while
What do yall think?
Matt
Old 08-21-2006, 12:57 AM   #20 (permalink)
millerjouni's Avatar
Member # 33725
Dope....starting to become a more reasonable route as first and second get trucks get older and older and tacoma prices get lower.... can't wait to do a double cab one day.
Instagram: jjoe_miller
millerjouni is offline   Reply With Quote Quick reply to this message
Old 08-21-2006, 09:47 AM   #21 (permalink)
FrankenToy's Avatar
Member # 36822
Did you still use 28" links (top and bottom) after everything was completed?
When you swapped oil pans were there any other parts needed (were you able to just to change the pick-up or did you have to swap out the entire oil pump, etc...)?
Can you post up a few close-ups of where you cut the cross member and added the tube right beneath the engine?
You did a great job . Is there anything you woulda done differently after having driven it? How does it drive (low speed, high speed) compared to the stock Taco IFS?
(I know, I know, a thousand questions...)
TIA...
Old 08-21-2006, 03:28 PM   #22 (permalink)
Shenanigengineer
RockTacoAU's Avatar
Member # 33543
1)all my links are the smae link they are about 36inches long,
2)I just swapped the pickup tube and oil pan(some swap out the dip stick but it is a PITA so i just trimmed mine a lil and it works fine)
3) I just torched off all my crossmembers and added one to the front, one for the links and the Tcase one from FROR. No tubing right under ther engine.
I dont think i would change a thing after everything, I dont remember how a stock taco drives but this is soooo much better than my TM lift kit's ride. nice smooth ride at 40 and 80 no problems whatsoever. My steering can be difficult when parking. (I will add hydro assist before long to fix this)
Thanks for the compliments let me know if ya got anymore questions
Matt
Old 08-21-2006, 05:05 PM   #23 (permalink)
FrankenToy's Avatar
Member # 36822
Tubing under the engine is prolly the exhaust. My bad....
Old 04-06-2007, 09:58 PM   #24 (permalink)
Member # 89215
questions
eb coils whos that and how much lift are those springs?what size tires and lift in the rear?
dawezel1 is offline   Reply With Quote Quick reply to this message
Old 04-07-2007, 07:37 AM   #25 (permalink)
Member # 69547
EB coils are Early Bronco coils.
95 Taco 4x4 2.7 - 4 linked front - 3rz-R151-4.7s - FJ80 axles F+R
thepinktaco is offline   Reply With Quote Quick reply to this message
