Member # 16522
Tacoma bed bob
I found that taking 13 1/4" is the difference between the length of a double cab bed and an extra cab/standard cab bed. I decided on 13" just in case I want to put a shell back on
I used cut off wheels to do the initial cuts. Had to do minimal grinding to get the 2 pieces to match up right. I ended up getting them so close together that I didn't need any backing. Tight seam First step: Mark the cut lines ![]() Second step: Cut ![]() ![]() Third step: Line up and tack
-Brian 01 4 door Taco- soon to be 3 link on tons with 40's |
Member # 16522
Fourth step: Fully tack weld together, no pics sorry
Fifth step: Grind smooth ![]() ![]() ![]() I chopped the end of the frame off and wanted to cap the ends with something, here's what I came up with ![]()
IDIot!
Member # 44480
Very nice bodywork--looks like you're welding a bit too hot, and melting base metal out and into your weld--see the dips in your weld toward the bottom. Not an issue for just capping the frame--just some friendly constructive criticism.
Did your shackle bushings smoke when you welded that close to 'em?! ![]() The upside is that you're getting good penetration. Pause just a little bit so your electrode will fill in the gaps in the base metal. Also looks like you have a little bit of pitting--pausing will also let the gases bubble to the surface so your completed weld will be solid.
Motive Gear Land Use Team http://www.tenfactory.com http://www.motivegear.com http://www.nationaldrivetrain.com http://www.davezoffroadperformance.com http://www.mastercraftsafety.com FToy 086 - UHaul Toterhome |
#5 (permalink) | |
Member # 16522
Definitely not my best work, I was just tired of tack welding for 3 hours I was using my Lincoln 3200hd (I think it's the 135 but the Home Depot version) on flux core, .035 wire. I may do the switch back to gas, we'll see
IDIot!
Member # 44480
Oh! Flux would explain some of the pits...just pause and let the wire fill--it's not like you're welding so hot you're burning through. Don't turn the heat down, necessarily (and risk bird shit!)--just fill more. If you turn down the heat, you risk losing the good penetration you're getting (which not everybody with a wire welder understands).
Member # 37026
sweet. that looks good. ya that second picture is on my cell phone.
![]() edit: guess its time for a new rear bumper design?! are you just going to chop the ends of your old one? Last edited by kiyul4130; 10-30-2006 at 11:27 AM. |
#10 (permalink) | |
Member # 16522
http://www.aervoe.com/productcart/pc...=3&idproduct=4 I used the color "Dark Green"
#11 (permalink) | |
Member # 16522
#13 (permalink) | |
Got .45?
Member # 9274
94 YJ w/ 5.3L, TH400, Atlas, and 42" Pitbull Rockers |
#14 (permalink) | |
Member # 75751
Nobody listens to turtle :( |
#15 (permalink) | |
Member # 16522
It used to tell you how many cans you get for 22 bucks. Give them a call
#18 (permalink) | |
Member # 16522
#19 (permalink) |
Member # 77294
Looks good. I plan to do a bob when i get an older pickup.
Mark
1985 toyota 4runner rebuilt 22re offroad cam internals from Engnblder 5.29s e-lockers f/r rebuilt axles |
