1996 + taco/runners SAS pictures needed please. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-19-2006, 10:54 AM   #1 (permalink)
Member # 20195
I have the axle, I have the thirds coming, but I would like ot get some ideas of different SAS's performed on these newer IFS frames. Specifically, parts and materials used. This may become a spring time project so I'd like to research methods and pictures for how guys installed everything...
83 toy, 5.29's 36" IRoks, Detroit rear, Auburn limited slip front...now with dual tcases & TDD spacers front and rear
[QUOTE=Dr.Van Falk]Seriously, once you start dying your hair you're only a boob job away from being able to do porn in Brazil.[/QUOTE]
copeland is offline   Reply With Quote
Old 12-19-2006, 11:22 AM   #2 (permalink)
AddictedOffroad's Avatar
Member # 79221
Link it!
http://www.allprooffroad.com/index.p...ask=view&id=80
AddictedOffroad is offline   Reply With Quote
Old 12-19-2006, 02:56 PM   #3 (permalink)
Member # 20195
I wonder how that kit would handle for DD duties though? anyone have a review of the kit?
Old 12-19-2006, 04:18 PM   #4 (permalink)
Member # 7932
Check here http://ttora.com/forum/
There is a wealth of info about the late model tacoma SASs there.
1985 EFI longbed 4x4
2003 Tacoma 4x4
halfxspaid is offline   Reply With Quote
Old 12-19-2006, 04:32 PM   #5 (permalink)
RockwelledToyota's Avatar
Member # 25217
Send a message via AIM to RockwelledToyota
www.offroadsolutions.com is working on a kit
MUDDEVILS 4x4
North Carolina
RockwelledToyota is offline   Reply With Quote
Old 12-19-2006, 05:33 PM   #6 (permalink)
KStacoma's Avatar
Member # 51493
Here is my 98, didn't use a toy. axle, used a waggy d44 because the width suited me better.
This shows the plating/sleeving you need to do to accomidate an older IFS steering box. Also you need to put a rear sump oil pan/pickup on it from a t100.
Other then that as far as frame mods, you just add a piece of 2x4 in between the frame rails in the front and then add your hangers below. Also of course you need to torch all the old crap off.
KStacoma is offline   Reply With Quote
Old 02-27-2007, 02:28 PM   #7 (permalink)
Member # 86672
what shocks are those kstacoma? also are you having problems hitting ur pitman arm under flex with the box positioned in that way?
tacoma87 is offline   Reply With Quote
Old 02-27-2007, 03:07 PM   #8 (permalink)
KStacoma's Avatar
Member # 51493
Funny you mention that, I actually was, I cured it by getting a billet pitman arm w/ 3/4" less drop, no issue since. The shocks are the longest rancho 9k's I could get but I am still max them out both ways
85 SR5 4runner- Duals, 4.7, longs, 40" iroks, caged, 5vz-fe
2012 tacoma -street queen
Old 02-27-2007, 03:56 PM   #9 (permalink)
CronusTRD's Avatar
Member # 11141
Don't expect the All Pro Kit to work out of the box.
what axle?
Mike
RcRocs 4.3 Toyota Jeep
www.marylandcreepers.com
www.rightcoast4x4.com
CronusTRD is online now   Reply With Quote
Old 02-27-2007, 10:30 PM   #10 (permalink)
Member # 86672
are they 12" travel? im trying to solve my shock dilema and i know i should go bilstein but i would rather not fork over the money for them and get some cheapo ranchos or something. i have been studying ur truck cause its hard to find SAC reg cab tacos and i am collecting parts for mine right now so i need all the influenece i can get get.
Old 02-28-2007, 10:31 PM   #11 (permalink)
synovus's Avatar
Member # 37467
Here's a well done reg cab SAS. http://www.ttora.com/forum/showthread.php?t=38134
synovus is offline   Reply With Quote
Old 03-01-2007, 05:54 AM   #12 (permalink)
Member # 86672
yea i have read up on josh's truck to but i hate that he sold it so quickly cause i wanted to learn from his "mistakes" a couple months after doing it and what needed to be changed and so on
Old 03-01-2007, 07:22 AM   #13 (permalink)
Member # 7753
I too am looking for info, trying to decide whats easiest,
a) buy a prerunner, swap in a 5 spd tranny/case with pass drop and use the toy axle I have
b) buy a 4x4, buy a diamond housing or similar and buy some custom inners and long's for drivers side drop
c) buy a 4x4 and drop a d44 in there. I'm more of a 3rd member kinda guy but I'm flexible
TTORA link, the truck is way high for what I'm thinking. Too much lift.
Slowzuki is offline   Reply With Quote
Old 03-01-2007, 08:13 AM   #14 (permalink)
Bloody Stump Wheeler
TacomaJoe95's Avatar
Member # 64808
Click on my build link below. There are some good pics there.
BSW Racing,CalRocs,Super Mod #8
Need tabs, brackets, or diff covers?http://www.ajs4x4.com/
Click for my taco build.
Check out my buggy build
/forum/general-4x4-discussion/669882-family-truckster-tacomajoes-new-ride.html
Bloody Stump Wheelers
TacomaJoe95 is offline   Reply With Quote
Old 03-01-2007, 10:16 AM   #15 (permalink)
El Presidente
Infernal Jeep's Avatar
Member # 38540
Bad ass,I wheeled with you in Arkansas before you did the SAS.Looks good man!
TTC 2013 ! ! ! - THANKS FOR THE SUPPORT EVERYONE ! ! !
WWW.GLOBALOFFROADSUPPLY.COM
*ROCK BRAWLERS* So-Cal
www.RockBrawlers.com
Fifth annual SoCal Off-Road Truck Show . Coming 2013 .
www.OffRoadTruckShow.com
Infernal Jeep is offline   Reply With Quote
Old 03-01-2007, 12:42 PM   #16 (permalink)
Member # 86672
for the record josh's truck on ttora is one of the lower solid axle tacos around that i have found. u cant go much lower without limiting travel...i think it is like 25"s to the frame maybe a little lower
Old 03-01-2007, 01:01 PM   #17 (permalink)
Member # 7753
Well, obviously the rear isn't the issue, it was lifted to match the front but the front is using shackle below the frame instead of sleeved for one. Looks like a little flatter spring could be used. Could save 3-4 inches there, looks like you could squeak an inch out of the front hangers.
Is there an oil pan issue with the T-100 pan or something? My zuk was setup with maybe 3-4" uptravel and all droop. Wheeled ok.
Maybe I'm just used to the regular truck conversions.
Old 03-01-2007, 02:10 PM   #18 (permalink)
Member # 86672
all tacos have the front shackles mounted below the frame instead of thru it...and yes there is an oil pan issue because the taco oil sump is right where the draglink will hit under flex so it is swapped for a t100 oil pan that puts the sump at the back. also with the tacos at 25-27"s to the frame seems like most trucks are wider than they are tall so it works out. might have been an issue with a sami being that tall cause of it being narrow.
Old 03-01-2007, 02:33 PM   #19 (permalink)
Edisonsteve's Avatar
Member # 46928
Send a message via Yahoo to Edisonsteve
Taco
Allpro offroads Taco supreme also uses a T100 oil pan.
1994 Toyota Extra cab, Exo, SAS, 2.28x4.7, 4.88, e-locker/Detroit, 37 Red crawlers, Supercharged 3.4 swap, front and rear Rock Assaults, Air Bumps, marlin 5.15 trans.
2011 KOH Buggy
2012 Jeep Sahara Unlimmited 4" lift on 35s
2005 Dodge 2500HD Cummins 4x4
Edisonsteve is offline   Reply With Quote
Old 03-02-2007, 04:48 AM   #20 (permalink)
Member # 7753
I know about the T100 pan, was just wondering if it is lower than the old 2.4's pan on the solid axle models or something that reduces clearance.
The zuks its hard to build them low too, you have to chop sheet metal, but a zuk on toys with a low stance can squeeze 37's in with some fender cutting. Surely a taco can stay a bit lower.
Here's scwafish's old rig. There a few others around, some even lower.
Old 03-02-2007, 09:59 AM   #21 (permalink)
Member # 34813
Mine comes in at 25" to the frame on 39's with 5" of uptravel..........3 link with 17" coilovers.
FAUX X 4 is offline   Reply With Quote
Old 03-02-2007, 10:31 AM   #22 (permalink)
Member # 6892
My taco on ttora is sitting at 23.5" to the frame on 37" tires, 5" of uptravel.
Yarr!
I've been to the Hammers... There in the tool section at Home Depot.
Rally for The Hammers post #141
Rally for Tellico post #100
Blue-Beard is offline   Reply With Quote
Old 03-02-2007, 11:24 AM   #23 (permalink)
Member # 7753
Those numbers are getting closer to what I'm talking about. On 33's or 34 with 4" of uptravel I'd be closer to what I'm looking for in a dd. The police here target lifted vehicles, there is a problem with the law and if you get pulled over, your registration basically changed to scrapped vehicle until it is put back stock.
Old 03-02-2007, 03:15 PM   #24 (permalink)
KStacoma's Avatar
Member # 51493
Damn, mines at 26" to bottom of frame underneath my door and i'm on 35's but it doesn't seem too tall or tippy to me imo.
Old 03-05-2007, 01:06 PM   #25 (permalink)
Member # 46928
24.5 to the frame, 4.25 up traval, 37"s
2011 KOH Buggy
