LC Engineering 3rz Oil Pan - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-27-2006, 07:35 AM   #1 (permalink)
OliveToy's Avatar
Member # 39522
Is anyone running this pan or even had a look? It's really expensive but I think it would help the oil starvation problems when the truck is at angles.
http://www.toyotacatalog.net/M1WebGe...1-EC9A07DE1DD1
Oil Pan - 2RZ/3RZ Solid Axle Swap Oil Pan
This is the oil pan you must have if you are putting that solid front axle in your Tacoma or early model Toyota truck. The pan features anti rust coating, custom pickup tube, windage tray and trap doors to keep the oil by the pick up. This pan even comes with the drain plug and washer. For all 3RZ motors.
$350.00
Si Vis Pacem Para Bellum
OliveToy is offline   Reply With Quote
Old 12-27-2006, 08:24 AM   #2 (permalink)
OliveToy's Avatar
Member # 39522
The stock oil pans are single wall right?
Old 12-27-2006, 08:44 AM   #3 (permalink)
Member # 37212
Considering you can get the stock pan, pickup and dipstick for under $150, that pan had better offer some huge advantages over stock for that price!
Chass
ct
Tuna!
Chass is offline   Reply With Quote
Old 12-27-2006, 08:53 AM   #4 (permalink)
OliveToy's Avatar
Member # 39522
Chass
ct
Thats why I was hoping someone had one, they might not show a profile view because it is a modified stock pan. Does that pickup look similar to the T100 2wd pickup? or is it a custom piece.
Old 12-27-2006, 01:45 PM   #5 (permalink)
JeepRecoveryTeam's Avatar
Member # 10203
Send a message via ICQ to JeepRecoveryTeam Send a message via AIM to JeepRecoveryTeam Send a message via Yahoo to JeepRecoveryTeam
Funny you should bring this up. I just bought a custom version of that pan for the buggy. Thing holds 7 quarts
Mine has 4 trap doors and 4 baffles as well as a full length windage tray.
It came with a custom pickup.
I'll post pics later. Unfortuantely I wasn't specific enough with the measurements and it was interefering with the drivelines at full stuff (it's low profile with wings off of both sides) I had Dan Bell fix it up and it's ready to install.
For me it was WELL worth the 350 I paid. Excellent workmanship.
Hopefully I won't be going through motors again this season.
d
Ultra4 and King of the Hammers
JeepRecoveryTeam is offline   Reply With Quote
Old 12-27-2006, 02:15 PM   #6 (permalink)
OliveToy's Avatar
Member # 39522
d
So yours was built by LCE? I just got off the phone with them, they are looking around for more pics, if they find them I will post them up.
Old 12-27-2006, 02:26 PM   #7 (permalink)
Member # 10203
Yep, just got delivery on Friday.
Completley custom but they kept all the designs, so it's repeatable.
The trap doors are
Old 12-27-2006, 02:29 PM   #8 (permalink)
OliveToy's Avatar
Member # 39522
I want one now! What is your setup? Why was it so close to your d-shaft.
Old 12-27-2006, 02:35 PM   #9 (permalink)
Member # 10203
It was only close to my driveshaft because at full compression, the pinion flange is above the pan
The pan is only ~4" deep, but it has wings that stick out on both sides ~3". The pan is with the buggy over at a buddies shop, when I get a chance I'll post pics.
Old 12-27-2006, 02:51 PM   #10 (permalink)
OliveToy's Avatar
Member # 39522
What dipstick did you use and is it accurate?
Old 12-27-2006, 03:14 PM   #11 (permalink)
Member # 10203
I'm switching to the T100 application this week. Still haven't put fluids in. I'll let you know.
Old 12-27-2006, 03:20 PM   #12 (permalink)
OliveToy's Avatar
Member # 39522
Thanks for all your help guys, I think I will probably order one this week.
Old 12-28-2006, 02:19 PM   #13 (permalink)
OliveToy's Avatar
Member # 39522
Some pics I just received from LCE.
Old 02-28-2007, 09:17 AM   #14 (permalink)
Member # 80969
Send a message via AIM to krickett Send a message via MSN to krickett
So does that one hold 7 quarts?
[I]-Ryan[/I]
[URL="http://4wdtoyota.com"]4WD Toyota[/URL]
krickett is offline   Reply With Quote
Old 03-09-2007, 10:01 PM   #15 (permalink)
Member # 2115
i've driven my taco sideways and i haven't had any problems with oil! the t100 does just fine. IMO.
1 ton '48 Willys in progress
alienjeep is offline   Reply With Quote
Old 03-10-2007, 08:55 AM   #16 (permalink)
blacksheep312's Avatar
Member # 31174
Send a message via AIM to blacksheep312
my t-100 oild oan works like a charm and holds more oil
98 Taco w Crawler. SAC.Front:Dana 60 HP Kingpin 69",Cromos, 300m Superjoints,Bilstein 9100 17in Shaft Coilovers. 3 Link,Rear:Full Floater Corp. 14 bolt,40in. Goodyear MTR's and more.....
blacksheep312 is offline   Reply With Quote
Old 03-12-2007, 10:38 AM   #17 (permalink)
OliveToy's Avatar
Member # 39522
I didn't like how LC's looked, little hack if you ask me so I also just put the T-100 pan on. Did any of you plug the original dipstick hole on the front for the tacoma pan.
Old 04-04-2007, 12:21 PM   #18 (permalink)
Member # 74022
I just left the stock dipstick in it and don't worry about it. I got a 3rz so I didn't have to worry about shit like it running through 5.7qts (T-100 capacity) between oil changes. When its full it reads around a 1/4" above the low level on the stock dipstick.
Needs to be checked after its been sitting for a while though since it slides down the side of the pan a little and would pick up enough oil to look 1/2 qt low just off the sides of the pan if it had been sloshing around.
banthis is offline   Reply With Quote
Old 04-04-2007, 02:22 PM   #19 (permalink)
OliveToy's Avatar
Member # 39522
I am going to plug the tacoma dipstick hole and run the T100 dipstick only.
Old 04-04-2007, 05:37 PM   #20 (permalink)
Moderating Midget
wngrog's Avatar
Member # 1154
Send a message via AIM to wngrog
IU have a 3RZ in my rock buggy and I la yit over often, drive it around on its side, have flopped in quite a few times and I have never had the motor starve for oil.
I did drop off a big ass ledge on Britney Spears in Moab and bashed it up into the pickup that in-turn pushed up into the engine.
I pulled it off and hammered it back and it is good to go.
Can't see the starvation thing being an issue.
Nolen Grogan
1997 FZJ-80 Land Cruiser, 37's
2010 RZR-4
www.cottonlandcruisers.com
www.rockmidgetphotography.com
USAF Veteran 1988-1998 GOD Bless America
wngrog is offline   Reply With Quote
Old 04-05-2007, 05:56 AM   #21 (permalink)
OliveToy's Avatar
Member # 39522
Nice! Sounds like smooth sailing
Old 11-07-2012, 06:55 AM   #22 (permalink)
Member # 159557
Resurrecting this one for modern day opinions.
JETHROBODEAN is offline   Reply With Quote
Old 11-07-2012, 08:04 AM   #23 (permalink)
OliveToy's Avatar
Member # 39522
I'm still running the same T100 pan. My draglink and tie rod made some custom indents through self clearancing but other than that it's done everything you could expect a oil pan to do.
