3rzfe misfire CE code
Ok, I've been having a minor problem with my 99 Tacoma (with 2.7L 4cyl). It seems to be running fine, but has been showing a check engine code for all 4 cylinders misfiring.
Can anyone shed some insight on this...the biggest thing that causes me confusion is that it seems to be running fine. Is there a sensor that would be causing this problem? David |
Maybe shitty gas, low octane, water in fuel??? Knock sensor acting up telling it to change the timing at the wrong time causing a misfire. What kind of gas mileage are you getting? Is it getting worse since this code popped?
Here is right out of my toyota factory service manual, areas to check for misfire codes. Ignition system, injector, fuel line pressure, EGR, Compression pressure, valve clearance not to spec, valve timing, Mass air flow meter, Engine coolant temp sensor. Are you running a K&N air filter? My maf was fawking filthy from the oil getting in from the K&N filter, I am changing to a paper element with a sock over it to cure the problem. Good luck man.
89 yota/3.4 swap/auto/33 stt's 87 runner/3.4 swap/33 toyos 78 chev k30/400/th400/44 swampers 77 chev k20/400/th350/36's, no lift, lincoln locked front and rear 79 blazer-getting piratized as we speak 84 runner/9 inches taller,3.4/auto/crawler etc soon [url]http://www.myspace.com/slater442w30[/url] |
#4 (permalink) | |
Yes, I do have a K&N and at one point prior I swapped out the MAF, and it fixed the problem at that point. Recently I had the same code, replaced the MAF with a junkyard one and the problem continued. Then I replaced the front O2 sensor as well. The only other thing that seems kindof odd is that after shutting of the engine it smells like un-burned gas...yet I'm getting a lean code for the Check Engine code along with these mis-fires. David |
Member # 80948
problems
There are so many things that could be wrong, but most likely if you have a code for a lean condition then it would probably be the MAF sensor. If you look down the MAF there should be no debris on the sensor itself, you can use brake clean to clean it along with a light blow of compressed air, but do not use Carburetor Cleaner. Make sure it is completely dry before installation. If I am guessing right, you would have a P0171, P0300, P0301,P0302,P0303, and P0304. the first would be the lean code and the subsequent others would be from the missfire. Let me know if there is anything I can do to help.
#7 (permalink) | |
David |
