3RZ refresh - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-28-2007, 12:48 AM   #1 (permalink)
Member # 30087
Send a message via MSN to Izeloz
3RZ refresh
I just bought a '97 taco rolling chassis with the intent of at least using the 3RZ out of it for my '85. I am quite bad at leaving things be and abiding by the, "if it ain't broke, don't fix it" rule. I usually follow the more dubious path of, "if it ain't broke, fix it till it is." I was told that the engine has around 100,000 miles on it. It has no apparent leaks and appears to be in good condition (from what I could tell pulling the valve cover and looking at the oil in it). Is there anything I should do for preventative maintenance before I drop it in some project, or should I just leave it alone until something goes bad? Thanks for any input.
Izeloz is offline   Reply With Quote
Old 02-28-2007, 05:40 AM   #2 (permalink)
Propane's Avatar
Member # 30839
If it aint broke, don't fix it I see those motors with over 200k with no problems at all. Excellent motors!
We are now having our pre-summer sale!!
4 Barell kits $925 complete!
Suzuki Samurai $625 complete!
22R,Holley 2 barrell,Jeep 258, $800 complete!
All other kits on sale!
Bulletproof, complete propane kits for carbureted offroad and street vehicles.
Please visit our website for details.
www.gotpropane.com
Propane is offline   Reply With Quote
Old 02-28-2007, 10:27 AM   #3 (permalink)
Member # 24516
Send a message via Yahoo to Greg_Canada
oil change and plugs....
Greg_Canada is offline   Reply With Quote
Old 02-28-2007, 05:41 PM   #4 (permalink)
Member # 24817
I talked to another mechanic who has a customer with over 900000km on his 3rz. These are not shitty domestic motors that are worn out at 160kms, these are awsome Japanese motors that are way overbuilt. Toss it in and run it.
Toyota Fan.
FXR UPR is offline   Reply With Quote
Old 03-28-2007, 01:46 PM   #5 (permalink)
98taco4x's Avatar
Member # 68676
Yeah like said before, I would change the oil and the plugs and wires. After that I would just do some cleaning, maybe have the injectors sent off to have them cleaned. Clean the throttle body and plentium up.
Yeah the 2.7 is a great engine and should last a long time, and they are real easy to work on if you ever have to.
98taco4x is offline   Reply With Quote
Old 03-30-2007, 09:32 AM   #6 (permalink)
Member # 68122
Has the head gasket ever been replaced? There was a factory recall for those due to a poor head gasket. If you plan on running it hard (approaching redline, say in a mud hole, you may want to consider replacing it now while it is out of the truck. If you do I would spend the extra dough and get a multi layer metal head gasket for it. I replaced mine after blowing, replaced with a graphite one, just to blow it again. Just a suggestion. You might get away without blowing it though.
3rides is offline   Reply With Quote
Old 04-04-2007, 12:58 AM   #7 (permalink)
Member # 72050
That would be the first i've heard of that, and I'm on my second truck with a 3rz in it. I bet you are confusing it with the early 3.4s which did have a head gasket recall.
The 3rz is rock solid, 100k is just getting broken in.
slus is offline   Reply With Quote
Old 10-06-2007, 07:31 PM   #8 (permalink)
Member # 14489
Send a message via Yahoo to Daveyclimber
I have 165k on mine, abused regularly and revved to the fuel cut ALOT. Leave it alone. You stand a better chance of screwing it up rather than leaving it be.
NorCal Tree Expert Co. (530)527-2844
Need tree trimming/removal , need defensible space ?
Call us ,insured and licensed . Serving Tehama, Glenn, Shasta and Butte County
Daveyclimber is offline   Reply With Quote
Old 10-06-2007, 08:42 PM   #9 (permalink)
toyin's Avatar
Member # 56751
I have a 95 with 193k on it and it runs like a champ. If i had the engine out i would do a head gasket, clean injectors, plenum and then run it. I think i would be foolish not to replace the head gasket.
‎4x4 is like a condom... its better to have it and not use it than need it and be FUCKED LOL
2007 5.9 cummins, CC, SB = Tow Bitch
1984 Toyota Pick up 4.3/4l60/build yota axles and 37" and a pretty paint job
1987 Buick Grand National 6.0/TC76 turbo/4L80E
1996 Toyota T100, 40's, 60/14B
toyin is offline   Reply With Quote
Old 10-07-2007, 08:13 PM   #10 (permalink)
Member # 19373
Are you sure your talking about the 3rz and not the 3.0 3vz?
[CENTER]When the power of love overcomes the love of power, the world will know peace.
-Jimi Hendrix[/CENTER]
[QUOTE=steveh;7244017]Keep it on track guys.
DRM and I will be watching. We need our TG paychecks ...... [/QUOTE]
mtnkid85 is offline   Reply With Quote
Old 10-11-2007, 09:05 AM   #11 (permalink)
Member # 69410
Send a message via AIM to 1stgenxxx
My 2.7 has 253k and the only thing I have changed is the belts and oil....It still runs like a top and has plenty of power. You will wear the drivers seat out before you have to do any motor work....
89 x-cab 40"s sbc/th350/205 RIP
01 Rattle box, 98 Cherocar
1stgenxxx is offline   Reply With Quote
