runing 33's - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-04-2007, 10:49 PM   #1 (permalink)
Member # 77789
runing 33's
I was looking on getting a little 4cly probally stick 01-04. With 33's will I need to regear, what lift do you recommend?
xxxjeep jake is offline   Reply With Quote
Old 03-05-2007, 05:39 AM   #2 (permalink)
jtaco1's Avatar
Member # 34250
Send a message via AIM to jtaco1
Use the setup I have in my Sig and if you have 4.10 gears you will be ok. Get a TRD with the rear locker and you will be good to go.
88 4 Runner, dual cases w/ 4.7's, Tacoma E-locker rear, 37" PB Rockers and no lift, caged
jtaco1 is offline   Reply With Quote
Old 03-05-2007, 08:15 AM   #3 (permalink)
Banned
Member # 72658
Thats too open ended of a question to get a decent answer. How much do you want to spend to lift your truck? How well do you expect it to ride? How much hauling towing will it see? How much and what type of wheeling (if any) will it see?
Fitting 33's could be done with a 3" body lift and a sawzall, but not if you want it done right. And for a 4cyl on 33's your going to hate stock gearing, even 4:10's. Most people are running 4:88's with the 4cyl.
highplainsdrifter is offline   Reply With Quote
Old 03-05-2007, 09:20 AM   #4 (permalink)
jtaco1's Avatar
Member # 34250
4.10's really aren't that bad, I can cruiser down the highway at 80 and only turn 3k RPM. But if you get in an area with a lot of hills or steep grades, 5th gear is not usable. 4.88's are better suited for 35's in my opinion cause I have seen 33's and 4.88s on a 4cyl and the cruising RPMs are like 2900 to 3k.
I'll be running 35's next and will run the 4.10's for a little, but will be regearing to 4.88 sometime thereafter.
You will get tons of opinions whoever you ask. Look over at the members rigs section at TTORA and you can see what you want to run.
Old 03-08-2007, 07:35 PM   #5 (permalink)
archer1965's Avatar
Member # 74910
READ THE FAQ
then check TTORA or Yotatech for answers to those questions. this is a tech/rockcrawling forum. you'll have better luck at those sites
archer1965 is offline   Reply With Quote
Old 03-13-2007, 12:29 PM   #6 (permalink)
Black01taco's Avatar
Member # 57051
Yo bro just get the biggest lift possible!!! you’ll be the coolest kid on the block......And also get at lest 5.29 for 33's mannn!!!!!
Black01taco is offline   Reply With Quote
Old 03-13-2007, 06:23 PM   #7 (permalink)
DuCaTi MoNsTeR
Booger Weldz's Avatar
Member # 2931
fawk that performance accesories body lift!!! what a total piece of garbage, go to 4crawler.com if you plan to do the bodylift and value the integrity of your vehicle. DEAD serious
Amongst the best of the toyota vendors:
Www.4wheelunderground.com
Www.addictedoffroad.com
Www.hellfire-fabworks.com
Booger Weldz is offline   Reply With Quote
Old 03-14-2007, 07:34 AM   #8 (permalink)
jtaco1's Avatar
Member # 34250
Yep, it is a piece of crap when I got it on the truck, had several problems with it, but reinforced the mount areas and did a few other things and it hasn't been a problem in the past 3 years. Also got it before I heard about 4crawler.com
Old 03-21-2007, 10:32 PM   #9 (permalink)
dieselpower's Avatar
Member # 27944
dont get a body lift at all thats for fags, if your cheep just run the ome with a 3/4" spacer for the front and a 1" block in the rear, think about it the truck comes with 31s stock 33s are only an 1" bigger all the way around. also run them on ur stock wheels the backspacing is just right and you will also have to hammer the pinch weld back on the inner fender but thats no big deal. as little lift as possible is the best way to go, I have the same set up on my taco. it works great!
Take it easy
"Flyin"
dieselpower is offline   Reply With Quote
Old 03-22-2007, 08:49 AM   #10 (permalink)
Member # 73854
if you regear it go with 4.56, it will be like running stock gears and tiers and the speedo is not to far off.
[FONT="Comic Sans MS"][SIZE="4"][COLOR="Red"]4THEWKN[/COLOR][/SIZE][/FONT]
TacoStewie is offline   Reply With Quote
