4x4 not working, front end LOUD?
need some help with dads taco. sorry, if this is a stupid question, just dont know much at all about tacoma's
98 4x4 3.4, 5speed, TRD, 140K the 4wd will not work, the transfer case is going into 4wd and 4low just fine, the front drive shaft turns, but something isnt locking up in the front. Something in the front is loud as hell in 2wd just dd around town, it sounds like he is running boggers but he has bfg a/t's. the sound is something that is rotating bc it gets louder with speed. also, he just took it in for an alignment and the shop says the rack and pinion is fawked, is this normal for a DD that sees little off-road? what should i look into replacing? d44 and call it done ?
90 4runner, v6, 5spd, toyota SAS, rear leaf swap, 5.29's, 38.5 boggers...95 Chevy 1500 350 4x4 |
Member # 73854
check the CV axles. you could have gotten a hole in the boots which could cause them to go out.
[FONT="Comic Sans MS"][SIZE="4"][COLOR="Red"]4THEWKN[/COLOR][/SIZE][/FONT] |
#3 (permalink) | |
Member # 57051
PS:It may be the Auto Locking Hubs...They may be stuck in the lock position or broken, there for not allowing the tires to receive power from the T-Case... |
4XSURFER
Member # 6021
I would be willing to bet that the noise is wheel bearings. My 01 DC was loud as crap on the road and it has plain ol' steet tires. Finally got around to getting it checked out for real and the pass bearing was shot, needed a new tie rod and the steering boot. Expensice as crap to get done but I spend enough time wrenching on my 85 runner.
I don't care about the Jeep thing as long as my mail is on time!!! 92 4runner 22re, DD, under (slow) construction. ![]() 2010 Honda Insight: Yakima surf racks, Wet Okole seat covers, HF air horn, 45+MPG!
