Member # 86615
3RZ Starter prob.
Hey guys, I've got a 96 taco with the 3RZ. When you hit the switch all i get is a click. And no it's not the beat on the starter click or the i beat my battery cables on click. At first it would do it 3 or 4 times then start, then it went to 20 or 30 times, n now it won't start at all. You can roll it off and it does fine. Someone mentioned a cam or crank position sensor. Not sure. Any help would be greatly appreciated. Thanks guys, Jon
Rebuild the starter. The clicking is from a worn out plunger and contact points. Check over on TTORA and search starter rebuild. Should come up with a post that has the part numbers and the rebuild. I did this a few months ago. The hardest part is getting the starter out of the truck, the actual rebuild takes like ten minutes.
88 4 Runner, dual cases w/ 4.7's, Tacoma E-locker rear, 37" PB Rockers and no lift, caged |
#3 (permalink) | |
Member # 75683
jtaco1
x2 |
Member # 86615
Thanks guys, I'll try that next week. It sucks that i've got my straight axle on the way n my truck won't even start. Here's the truck as it sits now. Just to put a truck with the prob.
#9 (permalink) | |
Member # 86615
Really??? Huh. I thought i could just tighten them down like that. No, allpro has the slowest freakin shipping in the world. I've got the correct shackles coming.
#14 (permalink) |
Member # 88957
Friggin Sweet
Yeah so i was just heading out side to go yank my starter out and see what the hell was up with it. Its doing exactly what yours was. I figured it was a bad ground. Or should I say I was HOPING it was a bad ground. But yeah so would it be cheaper to fix this one or buy a rebuilt one for about 70 bux? Eehh whatever im just gonna pull it out and get another one. I just wanted to say how perfect the timing was on this post.
How do blind people know when they're done wiping? |
#15 (permalink) |
Member # 86615
I took mine to the local starter shop and the guy rebuilt it in about 4 hours. Put new points in it, cleaned tohe mud out, and sand blaster and painted the outside. 40 bucks. Figured that was better to keep my taco starter than a cheap auto-zone remanufactured knock off.
#16 (permalink) | |
Member # 75683
MY DAD |
