Member # 49375
Long Travel Rear Suspension 96+ runner
Just put a Total Chaos front suspension on the runner and am looking for ideas for the rear. Any suggestions out there?
________ God Speed, Steve Hanson Chaplain Racers For Christ Rockcrawlers For Christ -www.teamrfc.org- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - special thanks: BFGoodrich|TRD|Total Chaos|Sway-A-Way|Trail_Gear|Twisted Customs|Spidertrax|Bassani Xhuast|ARB |
#3 (permalink) | |
Member # 49375
Sorry, what is the ttora board? I know of race_dezert and desert rangers. Thanks for input.
Member # 10229
www.ttora.com
look in the LONG TRAVEL SUSPENSION forum... LT isnt that popular on this forum... suprised the flames havent come out
Member # 49375
Done!
Strapped at 13" just like front.
Member # 22080
damn!!!! kick ass dude. i will be starting my LT truck soon. I will most likely be going with the GEN 2 caddy kit only because i want to keep my 4wd, but the GEN 3 caddy kit makes my mouth water!!!! But then i lose 4wd, so that sucks. For the rear i will be going with the 62" deavers, until i can save up for coilovers and a 4 link
Got custom cab? |
#7 (permalink) | |
Member # 49375
Front pic.
________ God Speed, Steve Hanson Chaplain Racers For Christ Rockcrawlers For Christ -www.teamrfc.org- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - special thanks: BFGoodrich|TRD|Total Chaos|Sway-A-Way|Trail_Gear|Twisted Customs|Spidertrax|Bassani Xhuast|ARB Last edited by Chaplain; 12-13-2007 at 09:13 AM. |
Member # 67202
[QUOTE=Chaplain;7605788]Done!
Strapped at 13" just like front. Definately can't flame that! very nice work.
[COLOR="Red"][SIZE="5"]2JZGE supra engine for sale!!![/SIZE][/COLOR] [url]http://www.pirate4x4.com/forum/showthread.php?p=6440768#post6440768[/url] |
Member # 2242
Looks great Steve, I definitely have suspension envy on my 4Runner.
Harry Situations Harry Wagner Freelance 4WD Writing & Photography Vehicle Features, Tech, & Trail Reports |
Member # 49375
Always feels good not to get flamed on here. Thanks, but I can't take too much of the credit. I weld like a grade schooler, but I can draw on napkins well.
> Twisted Customs (see Dec Dirtsport MIM) made the upper/lower control arms and panhard bar. They utilized heims with their special spacers on axle end, and bushings on the frame end to free up all the bind. I know there are beefier looking arms out there but these are the same as their competition rigs. > Sway-A-Away 2x10 emulsion shocks with the addition of high capacity remote reservoirs to keep things cool. Brian Bell, of SAW valved them to perfection. > Light Racing's 6" Jounce controls the uptravel. >Spidertrax provided the wheel spacers to keep things from rubbing and allows the rear to track inline with the wider front. > Downey swaybar extender and coils. Harry, all you need is a good shock. Call SAW up and order up a pair.
________ God Speed, Steve Hanson Chaplain Racers For Christ Rockcrawlers For Christ -www.teamrfc.org- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - special thanks: BFGoodrich|TRD|Total Chaos|Sway-A-Way|Trail_Gear|Twisted Customs|Spidertrax|Bassani Xhuast|ARB Last edited by Chaplain; 12-14-2007 at 09:39 AM. |
Member # 6892
Looks pretty sweet!
Do you have any more pics you can post of the rear suspension setup?
Yarr! I've been to the Hammers... There in the tool section at Home Depot. Rally for The Hammers post #141 Rally for Tellico post #100 |
#12 (permalink) | |
Member # 49375
#13 (permalink) |
Member # 6892
No nothing in particular really, just wanted to see some more pics. I love pictures!
#14 (permalink) |
Member # 49375
Pictures Pictures pictures. If it weren't for picture I would have never learned to read.
![]() The frame was notched slightly to reset the Light Racing mount deeper keeping things away from the tires. If this is too much work or you don't want to cut into your frame then get the 3" jounce and bucket mounting kit. I wanted more controlled up travel (6" jounce) and easier acceptability to make adjustments. This placement measures out perfect for up-travel contact. Also notice how the cross brace thing (technical term) was sleeved to tie the two hoops together for additional strength. ![]() Ignore the length of the upper arm bolts. I wanted the strength of longer shanks but was too lazy to crawl back up there with the sawzaw. Its embarrassing seeing all those threads so I'll get back under there. The Twisted Custom panhard bar is adjustable using treaded heims at both ends. ![]() Twisted Custom machined misalignment spacers to fit the factory mounts. All I had to do was drill out the holes for larger bolts. Removing the shock mount bolt is a tight fit past the lower arm mount, but it does come out. Could have used a little more room (up or down) here but that is where the tape measure said to put the shock mounts. ![]() Another shot of Twisted Customs work strapping the bushing housing for additional strength and fitting the factory mount perfect. ![]() Other options/improvements could be made to get more articulation and/or travel out of the rearend. I didn't want to reinvent the Toyota protractor or cut up my cargo area, at the end of the day its just a 4Runner and a daily driver.
#15 (permalink) |
Member # 49375
Here is a pic I took the other night with the tire almost all the way stuffed. As you can see there is still an inch before any tire rub on the shock. (this is the stuffed tire).
![]() I increased my tire size from a 265 to a 285x70x17 (33") BFG KM2's so I had to do some cutting. The added tire size was going to work havic on the fenders so out came the cutoff wheel.:saw: I was able to trim a good 1" out of the fenders without getting into the door. BEFORE: ![]() AFTER: ![]() I covered the sharp edges and hacks with a small piece of trim.
#16 (permalink) | |
Grocery Getter
Member # 59
Looks to me like you've still got a LOT of compression to go though. The bumpstop isn't touching, let alone compressed. That would tilt the axle more, moving the tire more towards the shock...I'm also curious how close the shock body gets to the frame on the drooped side? I plan on mounting my shocks upside down so that there is only shaft showing on the drooped side, giving a little more frame clearance. They'll be a little closer to the frame I think. |
#17 (permalink) | |
Member # 49375
Light Racing makes a mount that puts the jounce inside the coil bucket. I would only go with this mount if you have the smaller of the two jounce shocks. I wanted more controlled up travel so I went with the larger of the two sizes. I'll try and get some better articulation pics posted soon.
#18 (permalink) |
Member # 49375
UPGRADE to bypass
Finally figured out how to squeeeeeeze Sway-A-Way www.swayaway.com bypass in the rear and also added Trail-Gear's new frame support. http://www.trail-gear.com/tacoma#box
#20 (permalink) | |
Member # 49375
It is a mid-travel DD so in-comparison to a purpose built prerunner its not going to win any 'number' bragging rights. My theory on this build; since travel is very limited, has been to build it in a matter that is very tunable. That is why I am running a jounce and have switched to the bypass'.
________ God Speed, Steve Hanson Chaplain Racers For Christ Rockcrawlers For Christ -www.teamrfc.org- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - special thanks: BFGoodrich|TRD|Total Chaos|Sway-A-Way|Trail_Gear|Twisted Customs|Spidertrax|Bassani Xhuast|ARB Last edited by Chaplain; 10-17-2010 at 10:28 AM. |
#23 (permalink) |
Member # 49375
Sorry, but WMS?
#24 (permalink) |
Member # 16522
Wheel mounting surface to wheel mounting surface. 4runners should be the same as Tacomas so I'm guessing 60-60.5"?
-Brian 01 4 door Taco- soon to be 3 link on tons with 40's |
