e-locker question... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-05-2007, 09:57 PM   #1 (permalink)
Member # 22773
I'm looking to buy a Double cab 4x4 and am trying to find out if TRD Off Road package is worth the money or just to buy a TRD e-locker from someone and add it later.
If I go with the TRD Off Road package, can the e-locker be modified to work above 5 mph and/or in 4W High?
If not, since I plan on lifting it anyway, seems like a waste of money to go with the TRD package. I rather put that money towards Donahoe/All Pro/Total Chaos lifts...
Any input is greatly appreciated. Thanks!
My 85 4Runner was stolen, had a 94 4Runner - cat stolen1 Now have 92 LC that I park in the garage
camdsgn is offline   Reply With Quote Quick reply to this message
Old 05-06-2007, 09:04 AM   #2 (permalink)
Member # 42503
Not sure about 05+ but on older tacomas the bolt pattern for the 3rd member on non-TRD axles is different than TRD. (swap whole axle if you want a locking 3rd)
For use of the e-locker above 5mph search on gray wire mod
http://www.4x4wire.com/toyota/minutemods/greywire_mod/
Spork is offline   Reply With Quote Quick reply to this message
Old 05-16-2007, 04:10 PM   #3 (permalink)
Member # 7968
Don't know about the new ones (05+) but on the pre-2005 the diff drain plug is on the wrong side. On the bottom of the diff it is on the left for e-locker axles and on the right for non-e-locker. If anything you would probably be better off swapping the whole axle, but then you have to deal with wiring it up also.
Pony up and buy it already set-up.
1983 Toy PU, a few mods, Marlinized, lockerized
Hooligan is offline   Reply With Quote Quick reply to this message
Old 05-16-2007, 07:22 PM   #4 (permalink)
Member # 31736
Save your money and just put in an ARB. Then you don't have to swap housings or deal with wiring.
If you do go with the e-locker make sure you run aftermarket ring and pinions, the stock gears shred teeth off the ring gear pretty easily.
Jason, Nor Cal Marauders
wheelerless, 04 F250, CC, SB, SCT, 4"X, Airaid, 35" Nitto's
FIREBALL is offline   Reply With Quote Quick reply to this message
Old 05-19-2007, 09:18 PM   #5 (permalink)
Member # 22060
Wow, never heard of the grey wire mod. Maybe someone already did it to my truck, but I don't think I have a 5mph restriction, nor do I have to be in 4wd.
Now I'm going to have to check.
sparky2 is offline   Reply With Quote Quick reply to this message
